Old 01-22-2005, 11:36 AM   #6781
rayhuang's Avatar
Originally posted by wyd
Ray how are you making out with your EVO III since you have had a few weeks?
Hey,
Only ran it 6 packs Thursday night. It was a dream to drive. I will race it this Sunday and possibly next weekend at the Ohio Sate Championship race at Platinum Hobbies. I talked t my buddy Difuser and he gave me some ideas of more set-ups to try to achieve different thngs!! Looking forward to tomorrow!! HOpe weather doent keep too many racers away tomorrow!!
Ray
Old 01-22-2005, 01:56 PM   #6782
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Ray - any carpet set-up (with foams) ideas?? I have 1 on the car, but and looking for a couple more ideas just in case my idea don't work....
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 01-23-2005, 10:27 AM   #6783
Default Drive train LOUD!!!
Hi everyone!
I don't manage to make my drive train sound quiet, do you have any tips?
Also I'd like to make it free and spin as mutch as possible witch in a way should decrease the sound of it
I found that the bearings run better after being soaked with motor spray and without any bearing oil/lube, is it because the bearings are sealed?
I found that putting grease on the gears doesn't really make the noise decrease and it doesn't help the drive train to get more free....
Any help would be appreciated!!
THANKS!
Tbevofreak is offline   Reply With Quote
Old 01-23-2005, 10:16 PM   #6784
loopedeloop's Avatar
Default Re: Drive train LOUD!!!
Originally posted by Tbevofreak
Hi everyone!
Hi
Running bearings with no lube will make them noisy and kill them quick!!
My evo3 makes a clattering noise when the fr oneway is stuffed.
What type of noise is yours making????
loopedeloop is offline   Reply With Quote
Old 01-24-2005, 12:42 AM   #6785
DJB
DJB's Avatar
Trader Rating: 16 (100%+)
Oil your bearings with some light lube light trinity royal oil or fantom stuff.... and sometimes you might need to shim the gearbox to make sure the gears in there are meshing correctly that takes down the noise!!
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Old 01-24-2005, 03:00 AM   #6786
Default NOISE
I think most of the noise comes from the mesh of the gears but I don't have the proper shims....do I HAVE to get the tamiya 10mm shim set or can I find some in a "tool" shop??
My one way doesn't make that much noise much since I have the lightweight shaft and the square gearbox
I think I'm gonna lube my bearings now, Didn't know it will harm them
I use LRP oil for bearings, probably not the best but its made for it so it should work ok....
On my way to find those 0.1/0.2 mm shims....hope i'll find some quickly...
SEE YOU LATER GUYS!!!!!!!!!!!!!!!!!
Old 01-24-2005, 03:53 PM   #6787
Trader Rating: 24 (100%+)
Hey folks, need a few setup suggestions for my Evo3S on parking lot asphalt with CS27's and 27t stock motor. If anyone has one they want to share, just PM or E-mail me. If you have suggestions for "search" terms I can look them up in the thread. I've tried "evo III setup" and "evo3 setup" but not a whole lot comes up.........I know there were lots of them posted. I'm goin' blind trying to read the entire thread. Thanks for any help.
Evoracer is offline   Reply With Quote
Old 01-24-2005, 05:06 PM   #6788
Aluma's Avatar
I'm currently running a monster stock motor...geared at 72/25 for a 90ft straightaway and technical track(twisty) blue front springs, yellow rear springs, yellow sways for both. 50wt oil in both, outter mounts on arms, middle mounts on towers, stock setting blocks on chassis(no spacers) -1camber all around, 0 toe front. go to 72/29 or 72/30 for larger tracks...gives you more top speed.
If you want to drift around the corners beautifully, go copper fronts with blue rear springs...rest of settings the same...its a trip
Aluma is offline   Reply With Quote
Old 01-24-2005, 05:16 PM   #6789
Hey Aluma, Thanks ! Been a while since I spent any time here but I'm back to running and enjoying Tamiya.
Can you tell me what tension rates apply to each color of Tamiya sway bar?? Also, not familiar with copper springs, which set do they come with?? And what are the tensions Or tell me where to find such info.
Old 01-24-2005, 08:53 PM   #6790
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
What would the steering change be if you switch the front uprights from one side to the other. I know there is a difference just need to know if it will make the steering more agressive or not.
thanks
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Tamiya TRF 415|TA05 v2|TA05|TL01RA|TL01|M05|M06|F104 Pro|F103RM|RM-01|RM Mk.5
Custom Racing Stickers
2012 TCS Race #170 "The Track" @ Harbor Hobby Best of Show Mini Pro
f1larry is offline   Reply With Quote
Old 01-24-2005, 10:32 PM   #6791
DJB
DJB's Avatar
im not to sure what tension the springs actually are in lbs but they have as many "windings" or bits of spring as a tamiya yellow spring..... which is about 13-14 lbs i think well by squeezing them they feel much the same... the copper a tad harder
correct me if im wrong
Old 01-25-2005, 05:48 PM   #6792
Aluma's Avatar
LOL...oops sorry, copper associated springs. (from TC3 spring set) and the only reason I dont go yellow front is because I dont have an extra set...and dont really need more steering at my track.
Old 01-25-2005, 07:32 PM   #6793
DaNieL_KuO's Avatar
Send a message via AIM to DaNieL_KuO
Hi everyone!
THANKS!
I think the noise is from your gear mesh in your diff and bevel gear.You can shim it closer .either that your bevel gears could be worn or stripped. I sugggest getting new bevel gears, diff gears and reshim everything replace.then walla should help....
DaNieL_KuO is offline   Reply With Quote
Old 01-25-2005, 07:35 PM   #6794
DaNieL_KuO's Avatar
I run 64 pitch, I use a 97 spur and 35 tooth pinnion, sometimes 37 tooth or 34,33 depending on the track layout.
Old 01-28-2005, 09:01 PM   #6795
therealshark's Avatar
what are these square gear boxxes and who makes them. i have an evo 3 SE and have ordered the light weight shaft also the manual says to grease the diff gears.does this help to save the gears?
therealshark is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
