Old 01-18-2005, 05:39 PM   #6766
DJB
DJB's Avatar
Trader Rating: 16 (100%+)
If you're talking about the front, the HD outdrives for the one-way are p/n 53590.
thanks for that
whats the best way to shim your gearbox... where do u put the shims... behind the bearings?? and how many do u install??
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Old 01-18-2005, 05:47 PM   #6767
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
The shims go behind the bearing. To tighten up the mesh, use shims behind the bearing on the same side as the gear.
As for exactly how many or how thick...it depends on the gearbox and the bearings. One car I have takes more shims than the other to get about the same lash.
Turbo Joe is offline   Reply With Quote
Old 01-18-2005, 06:41 PM   #6768
rayhuang's Avatar
Default Re: Re: best remedy for oneway probs
Originally posted by Turbo Joe
Just get the lightweight shaft and shim it so there isn't much play and they hold up MUCH better. I used to kill one or two each raceday, now it's down to one every 3-4 days. Even then, they never really get messed up bad...you have to look really close to see any damage at all.
I run the standard Tamiya gears.
No problem-yeah-I meant that you cannot turn the diff gear-at all, but the wheels still rotate very free.
Old 01-18-2005, 07:06 PM   #6769
Charlie O's Avatar
Default reinforced bevel gear backing plate
Try that also, it's a carbon fiber reinforced bevelgear backing plate they have them at speedtech.com, that with the lightweight longer main drive shaft i havn't broken a front one way gear yet!
Charlie O is offline   Reply With Quote
Old 01-18-2005, 07:13 PM   #6770
loopedeloop's Avatar
Thanks guys
i have emailed steve@speedtech.
Just one more question
What is the advantage of spool vs diff vs one way?
Cheeeers
loopy
loopedeloop is offline   Reply With Quote
Old 01-18-2005, 07:20 PM   #6771
taj
taj's Avatar
i made myself some shims by reaming out a hole in some polycarbonate scrap left from a body shell to a diameter so that it slipped on tight over the end of the oneway and then trimed it down with sissors.I found the waste poly. thats edged around the actual shell was thicker than the poly. at the wheel centres thus giving you 2 thickness. Then just placed 1 off them to the gear side of the 1 way which took up all the play. This has worked wonders
taj is offline   Reply With Quote
Old 01-19-2005, 12:27 AM   #6772
DJB
DJB's Avatar
Thanks for your help
a spool has good braking ablity and a diff is good when you first dirve the car.. i think a one way is faster going on what others have said although i havent tried a spool does anyone know where to get an evo 3 one?? do speedtech sell them?
Old 01-19-2005, 12:36 AM   #6773
Thanks for your reply
this is the spool http://www.speedtechrc.com/store/ebp...id=322&id=1553
cheers
Old 01-19-2005, 06:06 PM   #6774
Aluma's Avatar
anyone wanna buy a NEW never used front one way for a evo3?
gears, cups, everything....complete.
Aluma is offline   Reply With Quote
Old 01-21-2005, 10:27 AM   #6775
jhigga15's Avatar
Any one looking to sell their Evo 3...I am looking to get into electric and I think that this looks like a great car to start with. Please PM or e-mail me at john@copalatina.com if you are looking to sell...
jhigga15 is offline   Reply With Quote
Old 01-21-2005, 11:20 AM   #6776
rayhuang's Avatar
Man did I have a pleasant suprise last night at practice. A little background. I had some of the very first evoIII's to hit the USA. I was very impressed with the build quality and materials untill I hit the track. Handled like a dream, but neither my buddy nor I could get any rip off the corners whatsoever.
SO back to today-I buy a used evoIIISL and TB02 package-interchangeble-only for a TCS race-but I decide I am gonna run this on foam tires for a month for fun and then switch it over to rubber tires.
I dont know where it came from-but this cars got plenty of rip!!! I dont know what was wrong two years ago or so-but this is nothing like the original car I had. I dont know what was wrong with my buddies car and mine-but we tried everythng (diff motors, diff esc, rollouts, no rear toe-in-you name it-even putting the motor and battery in my TC3-which just flew!!).
The ony diff between then and now is a front one-way then and a front diff today. Weird as a one-way should have more pull off corners or from a dead-stop.
Anyways-babbling like I always do-but this is crazy-but a pleasant suprise.
Old 01-21-2005, 05:08 PM   #6777
Aluma's Avatar
LOL... I've never run my evo3 without the front diff... and I always wondered why everyone said the evo3 sucked when mine was ripping up the track with ZERO problems... hahahaha.
Old 01-21-2005, 10:34 PM   #6778
DJB
DJB's Avatar
how hard did you set the diff in comparison to the rear?? How much softer/harder did you put it??
Old 01-22-2005, 08:30 AM   #6779
rayhuang's Avatar
Well-that might have been part of the problem back then. Maybe my rear diff wasnt tight enough.
Now? my front diff screw is bottomed out (full tight) and my rear id backed off maybe 1/16 of a turn from locked.
That might be the difference for sure!!
Old 01-22-2005, 09:26 AM   #6780
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Ray how are you making out with your EVO III since you have had a few weeks?
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
