Old 01-14-2005, 08:13 AM   #6751
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally posted by Tbevofreak
Try www.etamiya.com or look a couple of pages before there's a post with a link to a good tamiya spare parts website
thanks...they actually have the part
I've never had much luck with this place
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 01-14-2005, 10:13 AM   #6752
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
SpeedtechRC generally kicks ass for Tamiya stuff. Steve has lots of useful Tamiya experience...he does the TCS races and everything. You can even pick his brain about setups and stuff.
Turbo Joe is offline   Reply With Quote
Old 01-18-2005, 02:35 AM   #6753
DJB
DJB's Avatar
Trader Rating: 16 (100%+)
hey guys
my brother just bought an original evo 3 kit and i already owned a surikarn edition at the time...
i noticed in the front one way housing he had soem washers that came with the kit.. these didnt come with the surikarn edition and does anyone no why?
my car under full turning right and left makes a vibration noise somewhere near that area... im completely replacing the universals and drive cups and uprights and screws is there any other people out there that have heard/experienced my problem??
thanks
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Old 01-18-2005, 09:06 AM   #6754
Turbo Joe's Avatar
I think the washers go around the one-way outdrive to space it out. The Surikarn has HD outdrives that have the same dimensions as the original outdrives + washers.
Old 01-18-2005, 09:10 AM   #6755
rayhuang's Avatar
If any of you guys ahve a used, but in good shape SL rear shock tower-I'll buy it. Just PM me please. My rear shock tower is the narrow body post one.
Also-any way to get the white outdrive diff assy REALLY tight without locking the screw down?? MIne are 1/8 out from locked and they still turn. This wont cut it on carpet/foam-car will have no rip untill they are about locked.
Thanks,
Ray
Old 01-18-2005, 12:55 PM   #6756
rayhuang's Avatar
AAAAAAAAAAAAAAAArghhh--I was warned-but did I listen? NOOOoooo. I just snapped the diff screw in two on my front diff-!!! SOmetimes I really hate myself!! at myself!!
Old 01-18-2005, 01:37 PM   #6757
Turbo Joe's Avatar
Doesn't SpeedtechRC make a spool?
Here we go:
Speedtech spool
Old 01-18-2005, 03:31 PM   #6758
loopedeloop's Avatar
Default best remedy for oneway probs
Heyppl
I have just waded thru a couple of hundred pages of this forumlooking for the definative answer for the above problem.
I have seen 3 different cures and want to know which is the best fix.
I like the oneway and would prefer to keep it if poss, which of the following do you recommend:
a- Tb evo4 alloy gear
b- Xenon racing hard oneway gear
c- ball diff
As these are not easily available in NZ I want to make sure I purchase the BEST fix.
I run reedi Ti 9x2 , orion 12x2 on asphalt , foam tires.
I dont have a problem except when some newby does something stupid like last sunday ,one did a U turn on the main straight and I t Boned him at full speed.
So as a result I strip about one per racedayyour help is appreciated
cheers
loopy
loopedeloop is offline   Reply With Quote
Old 01-18-2005, 04:01 PM   #6759
Forgot to say I run the surikahn evo which already has the cf ring gear backing plate.
cheeeeers
Old 01-18-2005, 04:13 PM   #6760
V12
V12's Avatar
The problem isnīt the oneway gear in first place but the bad construction of the oneway. There were some different options but for me the only real fix is a custom oneway of completely different design. But this isnīt very cheap.
If you wanna go cheap just go with a frontdiff and you wonīt have any gear problems.
The Xenon gear isnīt too much of a difference to the original one. The aluminium oneway gear may be much better but the problem is the little pinion gear will break now.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 01-18-2005, 04:38 PM   #6761
DJB
DJB's Avatar
turbo joe what do you mean by hd outdrives.. the rear gearbox has lightweight delrin outdrives but the front are exaclty the same as the original evos except a lack of washers
Would the lightweight TA04 ones part number 53613 fit? Or would they get chewed out quicker?
Old 01-18-2005, 04:39 PM   #6762
rayhuang's Avatar
Here we go:
Speedtech spool
Turns out the center of the white outdrive broke. I replaced it with the black outdrives on Difusers recommendation and its pretty well locked up now.
a spool is illegal for TCS racng isnt it?
Old 01-18-2005, 05:16 PM   #6763
Turbo Joe's Avatar
If you're talking about the front, the HD outdrives for the one-way are p/n 53590.
The standard EVO-III cars I've seen have a slightly shorter outrive cup and they have a couple washers that space them out.
Old 01-18-2005, 05:18 PM   #6764
Turbo Joe's Avatar
I thought you were trying to lock up the front diff. I just assumed that a spool would be locked down pretty good.
You can't run a spool uless it's a Tamiya spool.
Old 01-18-2005, 05:21 PM   #6765
Turbo Joe's Avatar
Default Re: best remedy for oneway probs
Originally posted by loopedeloop
Heyppl
Just get the lightweight shaft and shim it so there isn't much play and they hold up MUCH better. I used to kill one or two each raceday, now it's down to one every 3-4 days. Even then, they never really get messed up bad...you have to look really close to see any damage at all.
I run the standard Tamiya gears.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
