Tamiya TB-Evolution III
#6721
Originally posted by EVOIIIM3
I've never seen a CF shaft for the E3. Just get the Tamiya light weight one, it's like $10.
vic
#6722
yeah but i heard that teh CF shaft is slightly longer and helps with spur stripping problems that have been the mian problem with the evo3
#6723
#6724
any body got the part number of teh longer shaft or wat colour is it?
#6725
The Tamiya one is about 1.5mm longer also, and yes it does help, but you still have to shim and reinforce the bevel gear.
Ray
#6726
I don't have the number handy...but it's the stock EVO III gray/blue color.
Edit: Here ya go...Click Here
#6727
Originally posted by hierog
team bomber is the only company that i know of that made a carbon shaft for the evo III and it was a limited production. Hebeki or JDM, do you still have one of these?
vic
vic
#6728
yeh i thought it was green.. so its the lightwight shaft that is slightly longer.. thnx guys
#6729
TB-EVO gear ratio.
What is the best gear ratio used for the TB-Evo?
48 pitch, asphalt, high speed track, Novak Brushless sytem.
#6730
hey secret weapon
7.91 is a high gear ratio (using a 70 tooth spur and 23tooth pinion) but u might not get enough top end out of that
6.27 is a lower one(using 70 tooth spur and 29 tooth pinion) and that might get you the top end you want...
somewhere in the middle there
mainly depends on how large you track is and also how big your tires are
#6731
#6732
My evoIIISL will be made track ready tonight!! Can someone tell me where to strat on wheelbase (shims front and rear) for modified/foam tires on this ride?
I have them set so that the cars shortup front and middle in the rear.
Also-what about innner arm sweep up front? Anyone tried it on foam tires yet? What did it do for the car?
Ray
Ray
#6733
I have no experience with foams or mod...but I run mine full short w/b on both ends, with "d-a-a-a" blocks (f--->r).
It had a pretty bad on-power push with a-a up front and going to the bigger block up front seems to REALLY help with the turn-in. To me, it's very nice to drive...and I've been told the same by several other people who actually know how to drive.
If you're interested, I can give you the whole setup as a starting point. I run it at SoCal (high-bite asphalt, rubber tires).
Best car I've ever had (probably because I'm too cheap to buy an EVO 4 ), but I really like this thing.
#6734
Ive seen some setups that use a 2mm spacer behind the front arm and infront of the rear arm to give a 261 wheelbase.. but this was on asphalt with rubber tires... you could give it a shot especially if you run big foams
#6735
