Old 10-14-2004, 11:46 PM   #6676
HPZ
Hey guys i was just wonder that when you speak of your wheels having a free spin of like 10 or so secs, i was wondering what is the method to do it...do you spin it with your hand or do you run it with your motor or what?
thanks
Tamiya TRF417x
Futaba 3pk + Spektrum
HPZ is offline   Reply With Quote
Old 10-18-2004, 06:17 PM   #6677
DJB
DJB's Avatar
Trader Rating: 16 (100%+)
hey guys, are ceramic bearings really worth all that money to make the evos drive train more free?? If they arent what is the way to get the best out of the drivetrain??
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Old 10-19-2004, 02:41 AM   #6678
EVOtech's Avatar
For an EVO 3 or 4, definitely.
For a Surikarn, no. Better quality bearings in it.
EVOtech is offline   Reply With Quote
Old 10-19-2004, 02:43 AM   #6679
EVOtech's Avatar
Originally posted by scorpia
Hmmm,
I have the same problem. I have a JR XS-3 radio and with 3 different servos I have had the same problem. i used a s3003, JR570?, and the S9550 (currrent.)
I also upgraded to a new kimbro servo saver at the time i changed radio's.
I thought there was something with the radio but just last week i found the ball cup was hitting the servo at full throw.
It seems that the kimbro servo save is thinner than the Tamiya one. I am going to try and change the side that the ball is on.
If anyone else has any comments i would be happy to hear them.
Regards
Peter
Thats what you get for not connecting the servo and getting it centred with the car and radio on.
Old 10-19-2004, 03:00 AM   #6680
I was centered but because of the thinner servo saver when i turned left the arm would hit the top of the servo instead of going between the servo and the arm.
Its all fixed now by putting it further out on the arm.
Scorpia
scorpia is offline   Reply With Quote
Old 10-19-2004, 03:29 AM   #6681
DJB
DJB's Avatar
thanks for the advice
one more question. have any of you guys tried the new lightweight arms set?? And what is your feedback on it. Worth it or worthless??
Old 10-22-2004, 09:42 PM   #6682
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Default Need some set up help
Hopefully someone can help me out with a problem I have.
I run my EVO 3 on carpet and my car tends to have a push going into the turns and them gets loose off power. I have softened the rear springs and stiffened the fron springs but I still get loose off power. It seems anything I do the front stays softer than the rear. Any help would be greatly appreciated.
Thanks,
Larry
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|Tamiya TRF 415|TA05 v2|TA05|TL01RA|TL01|M06|F104 Pro|F103RM|RM-01
Custom Racing Stickers
2012 TCS Race #170 "The Track" @ Harbor Hobby Best of Show Mini Pro
f1larry is offline   Reply With Quote
Old 10-23-2004, 07:59 AM   #6683
WC
WC's Avatar
Trader Rating: 28 (100%+)
Default Re: Need some set up help
Thanks,
Larry
Are you running the 1-way upfront, or twin diffs?
Most furry racers seem to use a front diff.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 10-23-2004, 08:51 AM   #6684
hierog's Avatar
Default carpet racing
i ran carpet for the first time last year and I was told that the car must be stiffer all the way around. I was using my SE and used blue springs all the way around and seemed to have great steering and traction. I also used the yellow sways in front and back. Granted, i run stock, so i don't know if this setup will work for 19 turn or mod
vic
hierog is offline   Reply With Quote
Old 10-23-2004, 09:32 PM   #6685
f1larry's Avatar
Default Re: Re: Need some set up help
I have run it both ways and seem to get the same result.
Old 10-24-2004, 01:00 PM   #6686
Send a message via AIM to A-Ko
F1Larry,
What is your detailed setup? Motor, Gearing, Shocks, droop, etc...
We could spend 20 questions getting to the heart of your problem.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 10-24-2004, 03:31 PM   #6687
f1larry's Avatar
Originally posted by A-Ko
F1Larry,
Last time I ran this is what my setup was:
Front;
Outer shock position on shock tower
Outer shock position on lower arm
front diff (last run went with one way)
-1 degree camber
0 degree toe out
.5mm under front suspension mount
Hard Stabilizer
3mm upper arm support
white spring, 2 hole piston, 50 weight assoc. shock oil, 1 urethane bushing
5mm ride height
2mm over ride height droop
6mm wheel hex
Rear;
middle shock postion on shock tower
inner shock position on lower arm
1.5mm under both suspension mounts. (A front C rear)
No stabilizer
-1 degree camber
no spacer on upper arm support
yellow spring, 2 hole piston, 40 weight assoc. shock oil, 1 urethane bushing
5mm ride height
6mm wheel hex
Old 10-24-2004, 09:07 PM   #6688
Front;
-1 degree camber
0 degree toe out
Hard Stabilizer
5mm ride height
6mm wheel hex
Rear;
No stabilizer
-1 degree camber
5mm ride height
6mm wheel hex
F1Larry,
Usullly with the Evo3 I have stuck with 1.5 camber F/R indoor & outdoors. Should give you a little more in corners.
I think your rear Droop should be at least 3 if not 4 mm. With the soft spring/oil you get a fast weight transfer in the rear making you loose with that short of a droop.
Your rear camber length should be as long as possible. I use the innermost hole on the alum upper deck mount and I put 6mm of shims under this mount. This will settle down the back more.
Your ESC dial out most of your brakes. I think I am around 15 to 30% once you find that fine line I use my brake curve to dial in or out brakes from track to track from the radio. More brakes can give you more cornering but also can make you loose.
The push in the corners could indicate your front is too stiff as far as spring goes and/or that your back end is too soft when it finally settles it gets better traction than your front. I would lighten up the front or swap your front/rear springs.
I usually don't use the urethane insert. It soaks up oil like a sponge. I either use 2 black o-rings or none.
I have been using the As with Med/soft insert up front and soft in the rear. A stagger seems to work better unless you can get a Med soft F/R setup to work. I would stick with the 1-way, a ball diff setup is nice but I have usually lost 3 to 5 tenths per lap with it.
Also make sure your chassis is not tweaking. I ended up countersinking my top plate.
Hope this helps,
A-ko
Jeffrey
Old 11-04-2004, 05:33 PM   #6689
JDXray's Avatar
Send a message via AIM to JDXray
Anyone know of any good websites with EVO III Parts. I had my Surikan laying around and decided to put it back together but i am missing a few things.
Also some place that has a nice 19t Carpet setup.
Jon
JDXray is offline   Reply With Quote
Old 11-04-2004, 06:50 PM   #6690
pink pac man's Avatar
do you rekon aus$270 is a good deal for a evo3 surikarn with the carbon shaft sum spares and wheels
pink pac man is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
