Old 10-03-2004, 04:00 PM   #6661
HPZ
hey guys,
I was wondering what is the largest 48 pitch spur and pinion that would fit the evo3?
thanks
Tamiya TRF417x
Futaba 3pk + Spektrum
HPZ is offline   Reply With Quote
Old 10-04-2004, 03:40 PM   #6662
Aluma's Avatar
I have a 72 tooth spur in there...maybe can squeeze in a 73 or 74, but dont know if they actually make those sizes....
for pinions, monster stock motor....24 to 30 tooth pinion sizes.
Aluma is offline   Reply With Quote
Old 10-06-2004, 07:22 AM   #6663
Default Parts
Guys,
I have just had a bad night down at the track and need some new parts.
Most of the parts i have under control but i cant find the part number for the carbon battery holder.
Also does anyone know if the TB-02 battery holder will fit an evo 3?
I also have seen that rc-square has the front c-hubs in alum. has anyone tried these/Have any feedback?
Regards
Peter
scorpia is offline   Reply With Quote
Old 10-06-2004, 08:29 AM   #6664
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
The Tb02 battery holder does not fitt in the EvoIII.
tb02 has a longer bar.
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 10-06-2004, 11:20 AM   #6665
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Default Battery Hold-down
The number in my manual is 4305513...
Turbo Joe is offline   Reply With Quote
Old 10-07-2004, 02:01 PM   #6666
Default Indoor Carpet Setup
Hi guys,
Can anyone out there let me know where I can find Marc's indoor carpet setup info? It may be here in this thred (I tried to find one here, but couldn't review all 200 something pages). So, any info is much appreicated.
Thanks.
Tamiya Virus is offline   Reply With Quote
Old 10-07-2004, 02:20 PM   #6667
V12
V12's Avatar
you can find it here http://www.rcworld.ch/pdf/evo3-ger-nats.pdf
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 10-07-2004, 02:50 PM   #6668
Thanks V12!!!
Old 10-08-2004, 05:39 AM   #6669
V12
V12's Avatar
No problem.
Old 10-09-2004, 03:27 AM   #6670
HPZ
Hey guys,
I know this isn't really the place, but i having trouble with my servo and steering. I have a JR XS-3 and just recently bought a KO PROPO FET 2015 servo and the problem that i encounter is that it doens't turn enough...i need to pump up the dual rate steering to my max which is 125% and when placed in my evo3 allows me to turn about 95% compared to my old futaba s3003 with a dual rate of only 100%.
Any suggestions will be appreciated Thanks
Tamiya TRF417x
Old 10-09-2004, 03:49 AM   #6671
Hmmm,
I have the same problem. I have a JR XS-3 radio and with 3 different servos I have had the same problem. i used a s3003, JR570?, and the S9550 (currrent.)
I also upgraded to a new kimbro servo saver at the time i changed radio's.
I thought there was something with the radio but just last week i found the ball cup was hitting the servo at full throw.
It seems that the kimbro servo save is thinner than the Tamiya one. I am going to try and change the side that the ball is on.
If anyone else has any comments i would be happy to hear them.
Regards
Peter
Old 10-09-2004, 07:01 AM   #6672
HPZ
My one servo horn doesn't touch at all, it just seems to me that the radio and certain servos are not as compatiable. Thats all i could come up with...
Tamiya TRF417x
Old 10-09-2004, 07:29 AM   #6673
I have now changed the servo saver. I didnt swap the side of the ball i just put it on a corner of the servo saver making it taller.
I can now hit just short of full steering, the uprights are almost hitting the c-hub on each side. I have had to use 120% throw. I think at 125% they would be hitting.
maybe its just a matter of using a longer horn.
Again i would love to hear if anyone else is having similar problems.
Scorpia
Old 10-09-2004, 11:31 PM   #6674
HPZ
scorpia,
If you placed the ball on the corner of the servo saver, doesn't that mean the angle you turn left and right will be different?
I'm thinking about drilling a hole above the middle hole so that the distance between the servo and ball is longer and gives more turning.
Tamiya TRF417x
Old 10-10-2004, 02:25 AM   #6675
I took the Servo saver off and recentered it so that the mnew hole was center.
It gives the same throw once it is centered.
It just saves drilling another hole. and you can also get it a little higher because its further from the center.
Let me know how you go.
Scorpia
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
