Old 09-06-2004, 11:31 AM   #6601
V12
V12's Avatar
Default Re: gears
Originally posted by hierog
why not, sparks would look sweet coming from the front of it!! LOL
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 09-06-2004, 12:48 PM   #6602
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by BigDogRacing
I was under the impression that the EVO4 ring gear has a different number of teeth?
No, they are the same number. I thought they were different too until I counted and they are the same.
jeffreylin is offline   Reply With Quote
Old 09-06-2004, 04:14 PM   #6603
f1larry's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
I beleive the bevel gear has a different amount of teeth than the origanal bevel gear from the EVO III
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Tamiya TRF 415|TA05 v2|TA05|TL01RA|TL01|M05|M06|F104 Pro|F103RM|RM-01|RM Mk.5
Custom Racing Stickers
2012 TCS Race #170 "The Track" @ Harbor Hobby Best of Show Mini Pro
f1larry is offline   Reply With Quote
Old 09-06-2004, 07:24 PM   #6604
jeffreylin's Avatar
Yup, the Evo4 bevel gears has 2 more teeth but the ring gears are the same.
Old 09-07-2004, 11:23 PM   #6605
bubbles's Avatar
After viewing the past two pages in this thread, I did not see anything about running the EVO4 suspension on the EVOIII. Is this possibal/worth it? I know of a few that use the EVO4 suspension on their 415's, but would it help the EVOIII?
Is it just me, or does the EVOIII push? I ran Rod's setup at SoCal, and could not get rid of this little pushing problem with the car. With each adjustment I have made, the car seems to steer a little better, but it's still there.
There IS an "E" block for the car, right?
bubbles is offline   Reply With Quote
Old 09-07-2004, 11:35 PM   #6606
jeffreylin's Avatar
Bubbles,
The new (evo4) suspension kit works for evo3 as well. In fact, if you got the limited production conversion kit it has instruction for both the 415 and the evo3.
Which one of Rod's set up did you run? After having ran the evo3, 415 and the evo4 at SoCal, I would say that the push could be dialed out. Try yellow all around with red sway bars and 30W oil. That's my base setup for SoCal and I don't think the car pushes. The Tamiya cars do drive different from the other cars and suspension changes affect the car differently sometimes. But the cars are certainly fast. In fact, maybe you are pushing because the car allow more speed at the corners?
Old 09-08-2004, 01:35 AM   #6607
bubbles's Avatar
Rod's setup was something like...
Springs - yellowF yellowR
Oil - 50wt
Ride Height - 4.5F/R
Droop - 6F 7R
Camber - -2 all around
Toe - 0F +2.5
Swaybar - yellowF yellowR
Mine now is something like...
Springs - Associated RedF Associated RedR
Oil - 50wt
Ride Height - 4.5mmF 5mmR
Droop - 6F 5R
Camber - -1F -2R
Toe - -1F +1.5R
Swaybar - yellowF GoldR(I forgot the size, but it's a little thicker than yellow. Not Tamiya)
I might change EVERYTHING back to his setup, and just start from ZERO again... The car is OK as is, but I just want a LITTLE more steering mid corner, and it will be SET!
Old 09-08-2004, 02:12 AM   #6608
jeffreylin's Avatar
Well, I tried 40wt oil and like 30wt better for SoCal, since it's quick transition I am looking for. Also the the sway bars and springs might be too stiff. What I've learned was that this car needs to roll more than the others in the corner to turn. You would think a stiffer rear will give you more steering but in fact it takes the steering away since the car does not roll enough to turn in a tight circle. I was struggling with this until Steve Weiss pointed it out to me.
Old 09-08-2004, 02:21 AM   #6609
bubbles's Avatar
I'm using the three hole pistons though, which makes the dampening(sp) softer, so you counter with thicker shock oil.
Scuba Steve to the rescue huh...
Shortening the camber links would help the car rotate through the corner as well, right? I'll mess with it some more and see how things turn out.
Later
Old 09-08-2004, 02:33 AM   #6610
jeffreylin's Avatar
Later
Yeah, I am referring to the 3 hole piston as well. In fact, that is the factory set up (3 hole with 30wt F/R)
The other thing that makes quite a bit of difference is the spacers you use on the wheel hubs. try making front wider or rear narrower.
Old 09-08-2004, 03:18 AM   #6611
I have the new suspension mounted on my Evo3. I also put an old reartower up front to be able to stand the shocks up more. The geometry and battery placement is now exactly the same as the evo4 (measured it on my brothers evo4) so I can use evo4 setups right off. You only have to add 2 mm under the camberlinks to get the correct height of the links noted in the evo4 settings.
Mr_Orange is offline   Reply With Quote
Old 09-08-2004, 11:27 AM   #6612
no it has same number of teeth.
i think!
there is no aluminium input gear but if you shim it itl be ok.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 09-08-2004, 12:03 PM   #6613
think the EVO IV ones are 2 teeth larger or so i have been told.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 09-09-2004, 05:34 AM   #6614
work's Avatar
So basically installing the evoIV alum 1way gear and shimming both the 1way and the bevel gear fixes the stripping?
work is offline   Reply With Quote
Old 09-09-2004, 06:19 AM   #6615
rough512's Avatar
How about weight of the metal gear?
I was able to reach 1365 grams racing weight at last weeks race. I replaced the steel dogbones with aluminum ones from the TA03 kit. If I install the carbon prop shaft and Ti screws, I can lighten the kit even further. Maybe even lose the one way in favor of a delrin outdrive?
What's the lightest evo3 ever assembled?
rough512 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
