Old 07-15-2004, 10:16 AM   #6451
Send a message via Yahoo to heftybone
"Chassis plate is new, mounting points for new gearbox is different so these parts cannot be retrofitted to TBe3."
Are the gearboxes "on piece", or can we just mount them in the holes that the Evo III has and pray the diff and one-way fit.
Hefty
heftybone is offline   Reply With Quote
Old 07-15-2004, 10:58 AM   #6452
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Default Re: Re: transponder holder
Originally posted by jeffreylin
evo4 comes with a plastic transponder mount piece that you are supposed to tape on your servo. Which means that you will be able to buy it as evo4 part when it becomes available. I'd say just tape the actual transponder on the servo.
i think thats the one that comes with the TB-02... just a piece of plastic with the "tamiya" logo, with a hole on the end, meant to tape to the top of the servo.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 07-16-2004, 10:55 AM   #6453
Aluma's Avatar
why? tape falls off after a while or a hard hit.
if you're using the big handout transponders, get a LONG body pin that goes through both posts, some fuel line between the posts, and voila... an upfront transponder holder that fits perfect and doesn't fall off.
Aluma is offline   Reply With Quote
Old 07-16-2004, 10:59 AM   #6454
Aluma's Avatar
hey guys...totally off left field here... I was reading RCCar mag and they had an article on roll center.... just trying to make sure I'm understanding right...correct me if I'm wrong...
IF, track has high traction ... you should go high roll center with softer springs and harder antiroll bars.
IF, track has low traction(dusty) ... you should go low roll center with harder springs and softer antiroll bars.
Old 07-16-2004, 11:00 AM   #6455
Hebiki's Avatar
Trader Rating: 26 (100%+)
is the article online? id like to read it also.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-16-2004, 09:15 PM   #6456
hierog's Avatar
Talking acer bearings
just to let you all know, i replace the SE Tamiya bearings with Acer Ceramics - WOW!! what a difference!!
can't wait to get out there are race her next weekend!
hierog is offline   Reply With Quote
Old 07-17-2004, 08:10 AM   #6457
WC
WC's Avatar
Trader Rating: 28 (100%+)
Hefty
The alloy gearbox comes in several pieces bolted together.
It bolts to the chassis via 3 holes, vs 4.
Somehow I suspect by the time it becomes available as a sparepart, it probably won't be cheap. Probably more worthwhile to just get a whole new EvoIV kit.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 07-19-2004, 04:20 AM   #6458
supersonic's Avatar
Default steering
I would like to know what is the centre distance between the two steering post.
supersonic is offline   Reply With Quote
Old 07-20-2004, 05:08 PM   #6459
DJB
DJB's Avatar
Trader Rating: 17 (100%+)
Hey tamiyadriver a few replies ago in this forum you said there was a transponder mount for the tb-02. what is the part number for that particular part??
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Old 07-20-2004, 07:54 PM   #6460
Turbonium's Avatar
let me see if i can find the manual... its on a parts tree. ill post later when i find...
Wes
Team Novak
Old 07-21-2004, 09:19 AM   #6461
prodrive's Avatar
Default tb evo manual
does any body know where i can download tb evo 3 sl manual? any tips on gearing for 23t and 8turn motor
prodrive is offline   Reply With Quote
Old 07-22-2004, 09:27 PM   #6462
hierog's Avatar
Post one way gears
does anybody have any new one way gears (the older, thin style) that they'd be willing to trade for NIP one way gears (the thicker style)? the thicker one way gears won't fit in the gearbox when I mount it on the Jurgen one way or his spool!!
thanks in advance
vic
Old 07-22-2004, 09:38 PM   #6463
Aurra Sing's Avatar
Default one way
Sorry I can't help you there but what you can do is make one-way gears out of ball diff gears. To do this you need enlarge the hole in the middle to fit the one-way. People use a reamer to ream the hole bigger, but it's hard to center the hole perfectly which often leads to tight spots in the drivetrain. If you have access to a machine shop it's the best method to accurately make the hole. You also need to drill 2 extra holes for the screws but that's easy.
Also, we found the new thicker one-way gears to be just as bad as the old ones.... the material feels too soft... arghhh!
I tried mounting an extra 6x12 bearing in the front plastic center piece and it significantly reduced driveshaft wobble and the amount of strippage. I took this for granted, I wish I knew about this earlier!
Aurra Sing is offline   Reply With Quote
Old 07-22-2004, 10:00 PM   #6464
work's Avatar
why not boil the one way gears? Ive read it somewhere that it makes it more durable and less brittle but i think it only works for nylon though
work is offline   Reply With Quote
Old 07-22-2004, 10:44 PM   #6465
hierog's Avatar
Default Re: one way
i stripped the new ones just as easily too!!
I will try making the holes bigger on the ball diff gears, that might just work. BTW, if I can get the screw holes dead on, it shouldn't matter if the middle hole is off a tad, i would think. the screws should hold it in position.
just a thought
also, how did you get the bearing to sit in the front plastic center piece? CA glue
thanks for the advice!!
vic
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
