Old 07-07-2004, 06:47 AM   #6436
hierog's Avatar
Originally posted by DJB
hey hierog what is the part numbers of those thick tamiya gears your talking about?? My gears strip quite a bit so this might be a help to my problem
same part number that is in the manual. I think they figured this was the "fix" to the stripping problem.
The fix for me was to buy the Jurgen pieces, but now they are so thick they don't fit. I can only use the stock one way now, even the penguin back plate makes it too thick!
Anybody find a spool that works with these new gears?
hierog is offline   Reply With Quote
Old 07-07-2004, 07:16 AM   #6437
Registered User
Mabuchi's Avatar
Send a message via AIM to Mabuchi
Originally posted by madjack
Pretty basic set-up:
Blue 3mm upgrade chassis kit
counter sunk upper deck w/ Square center brace
Speedtech hardened steel spool
geared 96/44,
e brush, niftech springs - 11.5+, 11.2-
Mazda 6
Front:
C, A blocks
40wt, 2 hole, Assoc. blue
3mm droop, Worlds sway bar - Yellow
4.5mm ride height
long camber links, 6mm spacers
-1' camber
Rear:
A, C blocks
30wt, 2 hole, Assoc. Silver
2.5mm droop, red sway bar
5mm ride height
med. camber link, 3mm spacers
Alloy rear hubs, outside hole
-1.5 camber
madjack- you mention 96/44- is this for a 19turn? if so what 19turn did you use?
Mabuchi is offline   Reply With Quote
Old 07-07-2004, 08:51 AM   #6438
none of the EVO4 parts may be useful ot the Evo 3,
BUTTT
im sure the new tamiya gas cars graphie gear boxs look handy !!!!
Evo_Uk is offline   Reply With Quote
Old 07-07-2004, 09:15 AM   #6439
jeffreylin's Avatar
R/C Tech Charter Subscriber
BUTTT
Evo3 can use the new suspension of the Evo4.
jeffreylin is offline   Reply With Quote
Old 07-07-2004, 12:06 PM   #6440
madjack's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to madjack
It was the handout 4 mag Reedy motor geared at 5.67 (not sure that I would gear that tall for other 19t's but the Reedy seems to handle it ok)
madjack is offline   Reply With Quote
Old 07-07-2004, 12:10 PM   #6441
madjack's Avatar
BUTTT
From what I hear the EVO 4 uses the motor mount and center brace from the EVO 3...samples arrived yesterday at Tamiya America. Which, if history is correct the kits should be stateside in about 2 to 3 weeks
I know speedtech has been taking pre-orders for the kit...with a little luck we should be testing at the end of July.
Old 07-07-2004, 12:18 PM   #6442
Registered User
Mabuchi's Avatar
was the com full or did you cut it down small?
I had a chat with Blackstock about gearing these up, he said to cut the com very small and gear up to get the speed. Whats your opinon on this
Old 07-07-2004, 12:36 PM   #6443
madjack's Avatar
I would listen to Mike on that...he has a direct line to the Race dept.
(by the mains I had cut my com 5 times...guess you could say it was on the smaller size, I'll try to find the motor and give you a measurement)
Old 07-07-2004, 01:44 PM   #6444
Registered User
Mabuchi's Avatar
5.6 wow that's a tall gear, how hot does it get? My Reedy 19 now comes off the track at 155 deg and that is geared at a 7.0. Our straight away at Scotty's track, er ( Trackside) is shy of a 100ft. What is the length of the Tamiya track?
Old 07-07-2004, 08:45 PM   #6445
WC
WC's Avatar
Trader Rating: 28 (100%+)
Just buy the "415 Reversible Suspension upgrade pack".
You need the longer 'bones, new knuckles and 950 bearings.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 07-07-2004, 09:00 PM   #6446
jeffreylin's Avatar
All of that comes with the kit. No need to buy separately.
Old 07-07-2004, 11:42 PM   #6447
WC
WC's Avatar
yep, buy the set.
Have heard some guys trying to get #51104 Suspension Arm sprue separately.
www.PandaGFX.com
www.MelbRC.org
Old 07-15-2004, 04:18 AM   #6448
DJB
DJB's Avatar
Trader Rating: 16 (100%+)
Default transponder holder
hey guys for the tamiya tb evoulution three is there an option for a transponder mount?? Ive seen some little bits of carbon pointing out of other peoples cars so are these bits options or custom made. Any ideas on how to make one?? Any pictures?? drilling holes into my shell stuffs the look of the body
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Old 07-15-2004, 07:35 AM   #6449
jiggen5354's Avatar
may be its me but the transponder mounts you speak of looks like the the carbon graphite battery tie down strap cut in half and stuck to the top of the servo
jiggen5354 is offline   Reply With Quote
Old 07-15-2004, 09:20 AM   #6450
jeffreylin's Avatar
Default Re: transponder holder
evo4 comes with a plastic transponder mount piece that you are supposed to tape on your servo. Which means that you will be able to buy it as evo4 part when it becomes available. I'd say just tape the actual transponder on the servo.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
