Old 01-31-2003, 02:38 AM   #631
hawker's Avatar
well its a johnno 540 but thats the class i'm running so i can't change the motor, my o4-r went a lot faster, though it seems to be getting faster the more i use it, so i'll see how i go, anyone got tips on ratios though?
other than spped the car is wonderful, handles so much better
hawker is offline   Reply With Quote
Old 01-31-2003, 06:23 AM   #632
fabolousRC's Avatar
Send a message via AIM to fabolousRC Send a message via Yahoo to fabolousRC
yeah..run smaller pinion. 34/90 is a bit TOOO much for a johnson 540. If you can get a hold of smaller pinion under 30, that'll be better.
I don't know what's the standard final gear on EVO III is. For comparison, I ran my TB01 with tamiya's stock setup (metric 48 pitch) 16/61 and the car have a lot of acceleration with a stock 540 especially with the Nimh batteries. Now, I don't know what's the conversion from the metric 48 pitch to the metric 64 pitch (can someone help me with that?). Since I figure (sorry don't have EVO III yet) 90T spur is the largest spur gear that Tamiya gave you for the kit, you might want to start by using 20 teeth pinion.
You also have to remember that EVO III is slightly heavier than TA04R so you want a gearing that has more acceleration (to pick up the weight) and lose a bit of top speed. Once EVO III goes, it goes, man! It just takes more than belt driven cars.
Hope that helps (and does not confuse you)
Tamiya DB01 Durga\Kyosho Lazer ZX-5\Kyosho Turbo Optima
Lex Tyler Paints \ Norcal Hobbies \ Bay Area Peninsula R/C Club
fabolousRC is offline   Reply With Quote
Old 01-31-2003, 06:24 AM   #633
jedi's Avatar
Default Chaange youyr gearing
Hawker,
you might want to go to a 38 or 39 tooth pinion to get the right speed out of that motor.
jedi is offline   Reply With Quote
Old 01-31-2003, 08:01 AM   #634
foampervert's Avatar
Send a message via MSN to foampervert
Default chassis twist ?car pulls to right or left....
Salutations Earthlings!
i do have a evo3 but i have noticed that the car pulls sharply to the side<i can't remember whether its left or right...>.is this a characteristic of a shaft driven car or is it because of the front one way? i have been told to use HARD springs to counter this but it only diminishes slightly...
the car is also very fond of skidding around when i try to turn. or brake.
HEEEELLLPPPP!!!!!
-FP
p.s.yes.......i know jack shit about car tuning......
foampervert is offline   Reply With Quote
Old 01-31-2003, 09:34 AM   #635
Aluma's Avatar
any word on a front ball diff for the evo3 yet?
Aluma is offline   Reply With Quote
Old 01-31-2003, 10:02 AM   #636
Trader Rating: 49 (100%+)
Send a message via AIM to weaponx
foampervert make sure your diff. is not to tight. that might be your problem
weaponx is offline   Reply With Quote
Old 01-31-2003, 10:04 AM   #637
SpeedTech's Avatar
KINGZJ,
Thank you for your recommandation, I appreciate it
Hawker,
Aside from getting the right gear ratio, you might also want to switch the rear suspension blocks to "AA" setup, instead of the kit recommanded "AC" setup. The kit setup's got 3 degree of rear toe-in, which is way too much for touring car racing. With the AA block setup, you'll have two degree of rear toe-in and with a 540 motor as your powerplant, you should still have plenty of rear traction and stability.
foampervert,
what kind of motor are you running? Torque steer is a part of the shaft drive car, but only when you are running hot modified motors. If you're running stock and your car is torque steering under hard acceleration, you car might be tweaked.
Aluma,
The best way I found to put a diff together is by using the following parts:
* TA04 complete ball diff kit (you'll use all the diff internal components in this package, except the outdrives and diff rings)
* TBEVOIII Outdrives
* F201 Diff Rings
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 01-31-2003, 01:47 PM   #638
rayhuang's Avatar
Default hhhmmmmmm....
Well guys,
Its seems I cannot unload my car as easily as I thought, so I may keep it and see if I cannot free up the drivetrain enough to make it competitive. That and modify the rear of car to get rid of all the flex in it. I still think-even if I get the car fast in a straight line-its too flexible for high bite carpet and foam tires-but time will tell!!!
Ray
Old 01-31-2003, 02:30 PM   #639
KINGZJ's Avatar
Send a message via AIM to KINGZJ
I have the same problem with my tc3 it pulls sometimes. I think it is due to the one-way. Now that I put the spool in it for foams it is pretty much a straight liner.
KINGZJ is offline   Reply With Quote
Old 01-31-2003, 11:12 PM   #640
black-knight's Avatar
R/C Tech Charter Subscriber
more good TB Evo results: http://www.rczone.net/modules.php?na...rticle&sid=324
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 02-01-2003, 01:37 AM   #641
hawker's Avatar
hi guys got some pics of my new evo3 and shell
watcha think?
Old 02-01-2003, 01:38 AM   #642
hawker's Avatar
another
Old 02-01-2003, 01:38 AM   #643
hawker's Avatar
3 more to go
Old 02-01-2003, 01:39 AM   #644
hawker's Avatar
second last
Old 02-01-2003, 01:39 AM   #645
hawker's Avatar
last one......for the moment eheh
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
