Old 06-30-2004, 10:20 AM   #6421
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Default Re: Broken uni
Originally posted by E.J. Evans
Hey JC, actually I figured it wasn't all temp! I looked at my car wednesday night for the first time after the reedy and found a broken universal joint (front left).
I guess that would explain why that car went from dialed to terrible!! If the tires pointed straight the drive train was fine, when turning the wheels it would lock up the drive train.
either way Charlie drove awesome!! There is always next year.
If anyone wants the setup pm me. The car was dialed until it broke. LOL
Yo EJ, its Mike Patterson, you have a PM
=MisFitz= NuKe is offline   Reply With Quote
Old 06-30-2004, 10:51 AM   #6422
stonedgti's Avatar
Trader Rating: 15 (100%+)
Default red Square hubs
I have these red rear hubs made by square. Are they the same ones to the blue one that tamiya makes?
http://www.allspeedhobbies.com/catal...roducts_id=925
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 06-30-2004, 10:54 AM   #6423
The Tamiya Blue Aluminum Rear uprights are 1 degree the square looks like its 1/2 a degree. How everything else mounts looks right.. I like how the square carrier had a setscrew for the hingepin.
JC
tiggersz is offline   Reply With Quote
Old 06-30-2004, 10:58 AM   #6424
work's Avatar
What's the part number of the new lightweight shaft? and what gearing do you suggest if i run the monster stock? I have a couple of 96T 64P spurs and some 33T and 34T 64P pinions
work is offline   Reply With Quote
Old 06-30-2004, 11:30 AM   #6425
V12
V12's Avatar
lightweight shaft is part# 53686.
V12 is offline   Reply With Quote
Old 07-01-2004, 10:18 AM   #6426
hierog's Avatar
Default BEARING MAINT
I just took apart my car and sprayed my bearing with motor cleaner, but now i need to lube em back up! what do you guys suggest? btw, i have th surikarn edition with the blue rubber sealed bearings
thanks
vic
hierog is offline   Reply With Quote
Old 07-01-2004, 10:53 AM   #6427
markp27's Avatar
Send a message via ICQ to markp27
Default Re: BEARING MAINT
thanks
vic
I use Serpent's bearing lube - pretty light and lets the bearings run really smooth.
http://shop.the-border.nl/customer/p...47&cat=&page=1
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 07-01-2004, 11:36 AM   #6428
hierog's Avatar
Default bearings
thanks for the input Mark, i'll check into it. I was also thinking about buying a set of the ceraminc Acer bearings. Are they worth the $100?
Old 07-01-2004, 11:38 AM   #6429
markp27's Avatar
Default Re: bearings
Can't comment on those bearings I got my bearings from a friend at the circuit - but I don't know the manufacturer.
I'm sure someone else can answer this question for you
Cheers, Mark.
Old 07-01-2004, 11:43 AM   #6430
jeffreylin's Avatar
R/C Tech Charter Subscriber
I got ceramic bearings for my 415 and they are definitely freer and smoother than the metal ones. The only down side is that they seems to be more fragile too. I have never broke the blue bearings that came with the Evo3 SL but I broke a couple of the ceramic ones in a nasty crash.
jeffreylin is offline   Reply With Quote
Old 07-05-2004, 08:23 AM   #6431
hierog's Avatar
Default free drive train
anybody have any tips on making the EVO III drivetrain more free? I have the SE and I can't get it to spin even one revolution when spinning the spur gear. it's catching somewhere. I've rebuilt the rear diff, changed all the gears, cleaned and re-lubed the stock bearings, but ???
HELP!!
Old 07-05-2004, 09:18 AM   #6432
hierog's Avatar
Default one more thing
okay, i just realized that the new one way gears i recieved from Tamiya are really thick. How are you guys using these things? they are way to thick to fit in the gear box. I've been using the Jurgen one way and his spool. I even put on the stock oneway with the new gears but it still won't fit!
I'll read back to see if anybody has already addressed this too
thanks for the help again
vic
Old 07-05-2004, 08:56 PM   #6433
WC
WC's Avatar
Trader Rating: 28 (100%+)
Default Re: free drive train
HELP!!
Brand new gears need to be run-in to be smooth.
Stick a 540 in there and run it for a few hours.
Runs-in faster if you have no lube on the gears.
But as long as there's nothing notchy about the drivetrain, it
doesn't affect laptimes noticeably so I don't bother running-in
anymore.
Hope you've shimmed your diffs accordingly.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 07-06-2004, 06:02 PM   #6434
WC
WC's Avatar
Sorry guys, you won't be able to upgrade TBe3 to TBe4.
About 95% of the parts will be different!!
Only thing recognisable on the TBe4 manual are the J-parts (battery holder) and the spurgears.
Chassis plate is new, mounting points for new gearbox is different so these parts cannot be retrofitted to TBe3.
Can new bevel gears fit? Will have to wait till they ship... but seem to be *both* sold with bevel pinions in the bag.
51109 TBe4 ONE WAY GEAR SET gives 2x Oneway Ring Gear, 2x Bevel Pinion gear
51110 TBe4 BALL DIFF GEAR SET gives 2x ball diff Ring Gear, 2x Bevel Pinion gear
TBe4 suspension hingepins now sold separately... 51093 (46mm), 51097 (10mm screw pin), 51098 (22mm screwpin) & 51099 (25mm screwpin).
www.PandaGFX.com
www.MelbRC.org
Old 07-07-2004, 05:59 AM   #6435
DJB
DJB's Avatar
Trader Rating: 16 (100%+)
hey hierog what is the part numbers of those thick tamiya gears your talking about?? My gears strip quite a bit so this might be a help to my problem
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
