Old 06-16-2004, 03:31 PM   #6391
DJB
DJB's Avatar
Trader Rating: 17 (100%+)
Hey madjack what do you mean by the Blue 3mm upgrade chassis kit?? is that like all the red stuff that comes std on the surikarn edition?? And whats the number for the speedtech hardened spool??
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Old 06-16-2004, 04:50 PM   #6392
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Originally posted by BigDogRacing
Madjack- that looks like a great setup!! I'm going to try it on our local parking lot races. My soft asphalt setup is very similar but I ran yellow Tamiya springs and red swaybars (less traction and no sugar water)
Hope it works well for you. It is a VERY similar to the set-up that used by E.J. Evans to TQ in 19T at Reedy last month...
madjack is offline   Reply With Quote
Old 06-16-2004, 04:56 PM   #6393
WC
WC's Avatar
Trader Rating: 28 (100%+)
The BLUE UPGRADE kit 49335 does not come with any chassis, the box is too small. Buy it separately (53629 TB EVO 3 SURIKARN Hard Main Frame 3.0mm).
The kit only gives you all the stock car's green bits in blue, except no blue motor heatsink. You do get 2 blue servo mounts instead, and 2 blue lightweight uni shafts (53502 42mm Aluminium Rear Shafts).
The blue shaft is the updated longer version, but not "lightweight".
The blue motor mount plate is a the HopUp *finned* 53684 style.
You also have to buy separately two packs of alloy blue upper arm mounts (53628 TB EVO 3 Upper Arm Aluminium Mount Set) as kit does not include them.
Also no blue ball ends and ball nuts (ok so Surikarn's ain't red) nor spare set of blue hexes for your axles (Surikarn's are red).
In all a bloody expensive exercise in the name of vanity.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 06-16-2004, 05:03 PM   #6394
madjack's Avatar
It was a kit that was produced to allow the orginal EVO3 owners a chance to "upgrade" their chassis to Surikan specs. (guess I was incorrect...thought mine came with a chassis and alloy camber link mounts also?)
I generally don't run a spool unless the race rules mandate it. I'm not sure what the part number for the Speedtech spool is, I will say this....the thing is bullet proof. It showed no wear after a week of testing and the race weekend.
(be aware that your u-drives & axles will suffer when running a spool)
I would call Steve at Speedtech or visit his web site. (great on-line shop to deal with for the serious RC racer)
Speed Tech R/C
675 Brea Canyon Rd. #11
Walnut, CA 91789
Tel: 909-869-9443
Fax: 909-869-6535
http://www.speedtechrc.com/
Old 06-16-2004, 08:02 PM   #6395
Agreed....
I like the red better anyway
Evo3 Drivers...The few, The proud, The brave (hey! that sounds like something I ripped of some american marines television comercial)
The Black Kat is offline   Reply With Quote
Old 06-16-2004, 08:58 PM   #6396
madjack's Avatar
Originally posted by The Black Kat
Agreed....
EVO3 for another month....then it's off to the land of the EVO4 for me
Sadly, the evo3 will be parted out for the "TB02 from hell" with the Tamiya Nationals just around the corner, it should make for a very competitive car in the GT2 class...I hope, would love another chance at the podium
Old 06-16-2004, 09:35 PM   #6397
WC
WC's Avatar
... the crazy, the foolhardy, the Tamiya addicted...
I've been voted "Home for lost EvoIIIs" (go figure).
Its been a crazy 12 months since May 2003 when I first discovered EvolutionIII - I was a late arrival.
2nd EvoIII arrived in June. This one clocked average 70km/h over 4 mins.
Got to race in TCS in Oct 2003 which was quite exciting... EvoIII will be fondly remembered for that. Raced 2 green cars, bought 1 red kit.
Another red came at xmas 2003; runs great at 74.5km/h.
And the next red one appeared in April 2003... after doing mod tour of duty at Reedy Thailand. A few battlescars but has been restored back to great condition.
The last (a green one) turned up 3 wks ago, with the BLUE kit. Car was parted out for spares & to hopup the TB02... plus a silly 'project' (shaftdrive 4WD in a 225mm wheelbase?).
In recognition of the 1st green beast's 1st anniversary in my care, I gave it the full BLUE works last month. Only ran it once at TCS and the only original bits left are the dogbones & topplate.
225mm frankenstein project is ready to roll.
TB02 (already with alloy motor mount, alloy steering & SSG strip) got its EvoIII implant... but I couldn't feel ANY improvement. Bugger! So I just rebuilt it with the stock plastic parts - and it handles just the same!!
Hmm... I think I won't be buying an EvoIV.
(Yeah right.)
www.PandaGFX.com
www.MelbRC.org
Old 06-16-2004, 10:11 PM   #6398
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
wow... and i thought i was overloaded... i have 2 EvoIII kits, 3rd one with Kai chassis, 2 TRF415's, 2 trf414m2's and a trf414m!!!
hi... my name is Wes...and i am a Tamiyaholic....
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 06-17-2004, 03:18 AM   #6399
DJB
DJB's Avatar
Go us Tamiyaholics thanks madjack for that imput. Do you (madjack) reckon its a good idea to run a spool on concrete?? or stick with the front one way.
Old 06-17-2004, 07:50 AM   #6400
madjack's Avatar
Post spool or one-way...
The choice would be a function of what level of grip the surface has....and of course driving style. Personally I run a one-way the majority of the time to gain corner speed.
My baseline set-up's tend to have quite a bit of steering by most standards, so for me a one-way works well, as I rarely use much brake to get the car to turn in....while on my way off track...only to burst into flames...
Old 06-17-2004, 01:09 PM   #6401
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Hey, does anyone know what the Tamiya yellow springs are rated at in lbs?
Old 06-17-2004, 03:22 PM   #6402
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
13.33lbs Mr.Caster
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-19-2004, 09:09 AM   #6403
prodrive's Avatar
Default tb evo III manual
where can i download tb evo III surikarn edition manual? anyone?
prodrive is offline   Reply With Quote
Old 06-19-2004, 09:29 AM   #6404
tomdav's Avatar
Trader Rating: 41 (100%+)
Default spring rate chart
Thanks to Ling Kang Tong
File Type: txt spring rate chart..txt (667 Bytes, 147 views)
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 06-23-2004, 08:18 AM   #6405
work's Avatar
What spur gears & pinions do you guys use on your car? 48P or 64P? thanks
work is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
