Old 06-10-2004, 08:20 AM   #6346
rtypec's Avatar
Default Re: Asphalt Rubber Set-up
Originally posted by KDagh1
Sorry if this has been posted elsewhere within this thread, but I was not able to find it . Does anybody have a good asphalt rubber set-up for the EVO III SE?
thanx
Here's DJ's setup from last year's Reedy Race. I've tried it, it's very good...
rtypec is offline   Reply With Quote
Old 06-10-2004, 08:57 AM   #6347
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Originally posted by dsrbltoys
When building the Tamiya shocks, I have found it easiest this way.
Fill shock
Remove air bubles with piston at top
Pull piston down (to make sure no more bubbles)
Fill to level with top of shock with piston midway to 2/3 to top
Then set the bladder on top, and press it in a little with a screwdriver.
Then add the oring or sponge to suite track
Then add the top plastic to the top
Gently set the top cap over the plastic snap
Press firmly on the plastic while screwing cap down.
This gives me shocks that last a LONG time
If the piston is in 2/3 when you assemble. The shaft moves the same from top as it does from bottom (same rebound). If you build it with the piston in middle of stroke then you have more compression then rebound.
These are my findings, but should make it easy to duplicate the builds...
You are dead on the money!! Tamiya shocks are the best I've ever owned or built! This is exactly the method I use and my shocks will last for months until the o-rings begin to drag. I would like to add that you need to rebuild your shocks with new o-rings every 2-3 months because they will begin to drag and get inconsistent. It's hard to feel without knowing what you are feeling.
BigDogRacing is offline   Reply With Quote
Old 06-10-2004, 09:13 AM   #6348
I strongly dissagree..
Plastic shock collars self-adjust (graise it with my elbow and my ride height is GONE)
Bottom cap (which is REALLY not needed) comes off in hard crashs
Need frequent re-building
I like the Losi shocks a lot. Easy to fil and work very well
Tamiya shocks are somewhere in the range of TC3 Racer kit shocks on my list
The Black Kat is offline   Reply With Quote
Old 06-10-2004, 09:16 AM   #6349
LOLOLOLOL HELLLLLLLLLL NO
trf's are so good, you must be doing something wrong becasue none of thats happened to me before... or maybe im just inexperienced
Anyway my evo3, full spec kitted out with spares and extras hits Ebay in 4 hours.
be sure to check it out
Tarnjit
Evo_Uk is offline   Reply With Quote
Old 06-10-2004, 09:26 AM   #6350
TRFS are WAYYY over-rated
I might try filling them up by his ^^^ method for more life but the bottom caps (still, not needed) come off in crashes and the shock collars SUCK
They do look good though
Old 06-10-2004, 09:28 AM   #6351
KDagh1's Avatar
Send a message via AIM to KDagh1 Send a message via MSN to KDagh1
Huh....???
I built the EVO III SE exactly per kit directions and my shocks work beautifully. No leaks, no air, smooth as butter, and consistent. Honestly, they are the BEST shocks I have ever built. I used the Duratrax brass shock shaft tool to install the bottom shock end without scratching the shaft -- highly recommended.
KDagh1 is offline   Reply With Quote
Old 06-10-2004, 09:28 AM   #6352
rtypec's Avatar
TRF shocks are the bomb-biggity. You can purchase the hop-up aluminum shock adjusters...they have a large o-ring that holds your setting. Or if your find your adjusters WAY too loose, you can take an exacto and put a small nick in the threads of the plastic adjuster, that'll give it enough bit. I usually don't.
I'm sure we all know that the Black Kat is opinionated and has no problem sharing his thoughts. This is the same racer who won't recommend a Stratus 2.0. A similar kind of body that recently won the reedy race.
Old 06-10-2004, 10:06 AM   #6353
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i was gonna say.. they guys at my track raved about their new "low friction " yokomo shocks till they grabbed my TRF flourines... all they could say was WOW!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 06-10-2004, 12:24 PM   #6354
trf shocks are the best.smoothest,leak free,etc.
they should be industry standard!
there as smooth as silk and the easiest to build and maintain.
only thing is they are a bit of a nuicance to keep stripping them to change pistons but i always use 3 pots anyway!
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 06-10-2004, 12:26 PM   #6355
dont forget the bent hinge pins rod
Old 06-10-2004, 12:39 PM   #6356
I don't like the Strat as much as I like my MG...Only way you can change that is give me a Strat you like...
They are smooth & consistant but they have that un-needed bottom cap and self adjust. Those two cons override the pros IMO
Yes I'm not afraid to voice my opinions. Whats your point?
Old 06-10-2004, 12:49 PM   #6357
wots the mg like compared to alfa 2?
i didnt like mazda 6 as i felt it was more lazy then the alfa 2.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 06-10-2004, 03:38 PM   #6358
Turbonium's Avatar
I They are smooth & consistant but they have that un-needed bottom cap and self adjust. Those two cons override the pros IMO
what bottom cap is unneccessary? i cant remember anything not needed there.
Wes
Team Novak
Old 06-10-2004, 03:49 PM   #6359
Theres a bottom cap to the shock. It is UNNEEDED...I found out about it when it came off during a crash. I should just solder it on
I have no idea how an Alfa handles
Old 06-10-2004, 05:22 PM   #6360
dsrbltoys's Avatar
Oh! on my shocks I used a solder iron to bugger up the threads, this acts like a locking ring!
dsrbltoys is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
