Old 06-04-2004, 12:22 PM   #6331
V12
V12's Avatar
Im sorry I wrote it in a wrong way but I meant it the same way as jeffreylin.
as an A-block is used for the front block in the manual I used this as a fixed point. The A-D blocks were meant just for the rear block.
... block + rear upright was meant as overall toe in.
I wonder if anybody tried anything other than two A blocks for the front axle and an A plus any other for the rear axle?
so overall going for a wider track as used for the 415.
V12 is offline   Reply With Quote
Old 06-04-2004, 01:41 PM   #6332
stonedgti's Avatar
Trader Rating: 15 (100%+)
So
A=0
B=0.5
C=1
D=1.5
right?
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 06-04-2004, 02:18 PM   #6333
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
I think it goes as follows
A = 0
B = 1
C = 2
D = 3
with the rear 2 degree upright you get a 4 degree toe in using the c suspension mount.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|Tamiya TRF 415|TA05 v2|TA05|TL01RA|TL01|M06|F104 Pro|F103RM|RM-01
Custom Racing Stickers
2012 TCS Race #170 "The Track" @ Harbor Hobby Best of Show Mini Pro
f1larry is offline   Reply With Quote
Old 06-04-2004, 02:20 PM   #6334
V12
V12's Avatar
Originally posted by stonedgti
So
A=0
B=0.5
C=1
D=1.5
right?
youre right if you just care for the angle of the suspension shafts and the front block is an A block each time.
Old 06-04-2004, 02:23 PM   #6335
Hebiki's Avatar
Trader Rating: 26 (100%+)
on the 415.. it has D-Blocks.. so the track is much wider than the EvoIII (per instructions). but some drivers were switching to the A bridge block (for belt clearance) and using a C block up front. for toe out. ive toned my down a bit..and ive switched it to B / A on the front to see what happens.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-04-2004, 02:23 PM   #6336
jeffreylin's Avatar
So
A=0
B=0.5
C=1
D=1.5
right?
Yes if you kept A block in front. But you still have to add 2 degrees of the upright so:
AA=2.0
AB=2.5
AC=3.0
AD=4.0
However, it's the difference between the blocks that matters. For example, you can get 2.5 by using A front and B aft, or B front and C aft. The B&C set up give you wider track though.
jeffreylin is offline   Reply With Quote
Old 06-04-2004, 02:32 PM   #6337
stonedgti's Avatar
Thanks for clearing it up guys.
It gets confusing sometimes.
Old 06-05-2004, 01:17 AM   #6338
taj
taj's Avatar
question does kick up or anti squat change the way that the bevel pinion and ring gear mesh. if so is it a concern?
IMCC-Illawarra model car club inc.
The Formula for fun is 9 Corners
quality not quantity
taj is offline   Reply With Quote
Old 06-05-2004, 01:24 AM   #6339
jeffreylin's Avatar
No, your arms are independent from your drivetrain.
Old 06-05-2004, 05:07 AM   #6340
devil's Avatar
can someone tell me how to do the shock oil in the shocks as when i do and you move the shock init becomes pressurrised and it is pulled out it becomes a vaccum (using 60wt oil)
devil is offline   Reply With Quote
Old 06-06-2004, 12:17 AM   #6341
dsrbltoys's Avatar
When building the Tamiya shocks, I have found it easiest this way.
Fill shock
Remove air bubles with piston at top
Pull piston down (to make sure no more bubbles)
Fill to level with top of shock with piston midway to 2/3 to top
Then set the bladder on top, and press it in a little with a screwdriver.
Then add the oring or sponge to suite track
Then add the top plastic to the top
Gently set the top cap over the plastic snap
Press firmly on the plastic while screwing cap down.
This gives me shocks that last a LONG time
If the piston is in 2/3 when you assemble. The shaft moves the same from top as it does from bottom (same rebound). If you build it with the piston in middle of stroke then you have more compression then rebound.
These are my findings, but should make it easy to duplicate the builds...
dsrbltoys is offline   Reply With Quote
Old 06-06-2004, 08:59 PM   #6342
KDagh1's Avatar
Send a message via AIM to KDagh1 Send a message via MSN to KDagh1
Default Asphalt Rubber Set-up
Sorry if this has been posted elsewhere within this thread, but I was not able to find it . Does anybody have a good asphalt rubber set-up for the EVO III SE?
thanx
KDagh1 is offline   Reply With Quote
Old 06-07-2004, 07:53 AM   #6343
My setup
F/R
Springs: White/Blue
Oil 40/40
Droop: 4/3 (on the associated droop guage)
Shock Position: 3/3 (look @ the Evo3 setup sheet....tamiyausa.com)
Roll Center Spacers:5mm/2mm
Tire: CS-27
Front One-way
Works good...Still playing around with it a little bit
REALLY shines on a big flowing layout....Having a little trouble getting a perfect balence on the technical section but its fairly good all around
Took 3rd in a really competative stock race this weekend after starting 7th
The Black Kat is offline   Reply With Quote
Old 06-07-2004, 09:46 AM   #6344
KDagh1's Avatar
Thanx Black Kat.
I am going to start racing on asphalt at our Chicago R/C club events with a mod motor. I'll give it a try and if I find something that works really well, I'll post it back here.
Old 06-10-2004, 03:58 AM   #6345
DJB
DJB's Avatar
Trader Rating: 16 (100%+)
hey guys
while were on setups can u guys give me a basic concrete tight setup. car needs help. power on understeer especially.
thanks
djb
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
