Old 05-05-2004, 09:30 PM   #6196
Thanks....
I got yellows all around ATM and Brandon's been telling me the G/S combo is great
I think I'll prefer the diff....got my roll centers set using the ride height guage (don't ask...lol...all I know is I got it right) I think i'll try Yellow all around with a yellow sway bar as a starting point but if that doesn't work I'll go Gold/Silver and if that fails I'll bum a pair of white springs off someone and try white/blue
Wait a sec...Marc...Your'e Marc Mendoza! right?
The Black Kat is offline   Reply With Quote
Old 05-07-2004, 02:43 PM   #6197
losispeed's Avatar
Default New oneway ring gears??
Well I got my order from Tamiya and Just got the chance to install a new ring gear, old one got striped last race... Anyhow I have the larger CF ring gear backing plate and it wont fit on the ring gear anymore. Had to go back to the stock one. The ring gear is now more beefy up top and is slotted for the stock CF backing plate. Anyone know how well these work?
losispeed is offline   Reply With Quote
Old 05-08-2004, 06:22 AM   #6198
devil's Avatar
Hi i've been using the new gears, the new longer shaft and carbon backing plate and it seem to stop the stripping for me. Dose anyone know what are some good bearings (i want performance without having to open it up all the time), are the blue shield bearings any good? how do you clean a oneway out, my one is fully of gunk, but i'm not sure if you can clean it with mess or something.
devil is offline   Reply With Quote
Old 05-08-2004, 08:25 AM   #6199
ngo8's Avatar
Send a message via ICQ to ngo8
you can get acer ceramic bearings those are the best .cant you clean the one way with motor spray ?
ngo8 is offline   Reply With Quote
Old 05-08-2004, 10:42 AM   #6200
jeffreylin's Avatar
R/C Tech Charter Subscriber
You can soak you beraings in motor spray and that will free them up. RC4Less has a grade 7 ceramic bearing set for EVO3. At $100 it's a good value and worthy investment to you car.
jeffreylin is offline   Reply With Quote
Old 05-08-2004, 10:52 AM   #6201
WC
WC's Avatar
Trader Rating: 28 (100%+)
Default Re: New oneway ring gears??
Well I've got an example of the beefy new gear with eight teeth missing, if that answers your question.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 05-08-2004, 11:04 AM   #6202
I think THE fix is the 2mm longer shaft.....
Can't you just slap a TB02 shaft in there & be safe?
Old 05-08-2004, 01:12 PM   #6203
losispeed's Avatar
Default Re: Re: New oneway ring gears??
Well I took the time to try the pin fix, Race day is tomorrow.... If I can sneak out long enough that is! If it holds up for the day Ill be happy...
Old 05-08-2004, 02:06 PM   #6204
V12
V12's Avatar
Yes that new gear isnīt much better than the old one as it still keeps breaking. But the problem isnīt the gear but the poorly designed oneway and the gearbox.
I got a prototyp oneway gear about half a year ago at the German outdoor Champs but I didnīt use it any time as it doesnīt fit the Jürgen oneway. Also I saw some guys breaking the proto gear which in fact is the same as the new production gear. This custom oneway works way better even if you see the fact the old gear is made of a very soft plastic.
We will see what Tamiya will do to the EVO4 regarding oneway and gearbox. For the moment there is the Square aluminium gearbox and the custom oneway so there is no need for me changing for any other car as the EVO3 still is very fast.
V12 is offline   Reply With Quote
Old 05-08-2004, 02:23 PM   #6205
markp27's Avatar
Send a message via ICQ to markp27
Hi V12,
Got my Square Gearboxes already But I had a bad night at the track After only a couple of batteries, I rolled the car - nothing special - and when I checked the car I found there was some damge to the chassis near the motor It's like a little piece of the carbon fibre is missing The chassis is ok, but it is really anoying!!!
Then the camber arm came loose and I hit the wall really hard - I lost my red spacers which were under the arm and my speed controller opened up My old one broke last week and now the casing of the new one is broken Fortunately I can use the old casing to fix this problem.
I went home after this, as I felt I couldn't drive that evening - somehow nothing work and I was driving like a beginner
Tomorrow it's Nitro car at the Nürnberg track Hopefully things will go better
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 05-08-2004, 02:34 PM   #6206
markp27's Avatar
V12, forgot to say - talked to Mr Kess about the 415 - couldn't talk long, but he didn't like it so much.
Cheers, Mark.
Old 05-08-2004, 02:40 PM   #6207
V12
V12's Avatar
Cheers, Mark.
I think he didnīt like it because he didnīt win at the nationals.
Maybe he should give it away..........cheap. I take it then.
But heīs the only driver I ever heard of not liking the 415.
I canīt say anthing in this regard as I never have driven a 415 by now.
Old 05-08-2004, 02:47 PM   #6208
I've heard VERY mixed reviews on this car.....If it handles/drives like the MR-4TC then I like the shaft drive/ball diff combo way better
Old 05-08-2004, 02:52 PM   #6209
V12
V12's Avatar
Mark
Those Square gearboxes look very cool.
And you really should take care of the screws going into any aluminium parts. I had some screws going loose a little but didnīt lost them completely. Usually I check before each run.
Do you have dry weather in Nürnberg? So have fun with the nitro.
I know this track from the old 1:10 onroad days. Pretty fast there. Did win one race there some years ago.
A friend of me is at the qualifying race for the 1:10 nitro nationals this weekend at the Türkheim track. Maybe they will have rain there as itīs here also. Not that much fun in the rain.
Old 05-08-2004, 02:59 PM   #6210
V12
V12's Avatar
I think nobody tried the 415 outdoors here yet. Maybe itīs a carpet car only. At least it seems working awesome indoors. We will see whatīs happening at asphalt tracks.
But the Pro4 will be released before the most important outdoor races like Worlds and European Champs so I think most Tamiya drivers will change again to shaft drive.
Canīt say anything regarding the MR-4TC as I left Yokomo after the old YR-4 M2 days. Didnīt like the plastic chassis.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
