Old 04-25-2004, 10:48 AM   #6091
Originally posted by ngo8
yes it is 2mm longer trf racer .
thanx.
trf racer is offline   Reply With Quote
Old 04-25-2004, 11:07 AM   #6092
Originally posted by WC
There is a great "Seach/Display By Posts" function above...
I'm not stupid Cheif....I didn't find much info using that than what you told me. I wanted to know if A)What can I get INSTEAD of the TA04 diff and B) Will a TB-01 diff work?
I find out both in time....When I get the car. I'll try the diff out of the TB Evo & if that doesn't work I'll lube it back up and put it back. Then I'll get some TB-02 outdrives/F201 D-rings and whatever else I may need & frankenstien it from a TC3 diff....If that fails I'll get the TA04 diff and piece it together
The Black Kat is offline   Reply With Quote
Old 04-25-2004, 04:30 PM   #6093
jiggen5354's Avatar
the tb-01/tb-10 ball diff will not work in the evo 3 as the ring gear is physically bigger. about the only thing in the tb-01/tg-10 ball diff you could use in it are the diff balls. The method suggested by WC is your best bet.
jiggen5354 is offline   Reply With Quote
Old 04-25-2004, 05:55 PM   #6094
WC
WC's Avatar
Trader Rating: 28 (100%+)
Lightbulb
Hiya Chen! Didja end up getting that diff off Luis?
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 04-25-2004, 06:17 PM   #6095
Can I just get the nessesary outdrives/d-rings and put the one-way gear in there....pull the screw, bearing, spring and nut out of a TC3 and whoosh! Instant-diff
Or (easiest route) Shoe-goo the one-way into a spool. How will a spool effect this car's handling....I've never run a spool before on anything....
Old 04-26-2004, 01:57 AM   #6096
losispeed's Avatar
Hey I just got my Evo III SL, and Love it but...... I was at the track today and I noticed a clicking noise... Well it got worse when I stuck a KR in to keep up with everyone else... Anyhow So I did a number on my front oneway gear. Is there any way to prevent this gear from shreading? I bought this car used and when I went over it, it seemed to be in Awsome shape.. Its has the square racing center shaft on it.. Do I need to shim the drive train some place to prevent this in the future.. Thanks for the help...
losispeed is offline   Reply With Quote
Old 04-26-2004, 04:52 AM   #6097
DZ
Shimming the drive train is a good start...But i believe tamiya have just released a new one way gear almost double as think... not to sure if you can buy them yet but it shouldn't be to long...
seen this in a japanese mag
DZ is offline   Reply With Quote
Old 04-26-2004, 07:43 AM   #6098
jiggen5354's Avatar
got it, installed it and ran it. funny thing is it feels so much slower than a one way but the lap times are about the same. consistency is better no doubt due to a ring gear that has all of its teeth intact.
Old 04-26-2004, 07:48 AM   #6099
I got the TB-02 outdrives...Thrust bearings, F-201 d-rings & diff screw from Speedtech R/C last night.....I couldn't get the beveled gear or the 3mm diff balls (out of both)
Where the hell do I get a bevel gear...I don't think I can use the one off the one-way Will the Pro-4 or the TC3 bevel gear work?
Old 04-26-2004, 07:53 AM   #6100
WC
WC's Avatar
I am sorry (again) to have to say its a good idea to sit down and
read all the past 200 past pages of this thread... its just not
possible to condense all our past gear-stripping cures into
a simple one-paragrapher...
Different methods work for different ppl... right now I haven't
replaced a gear for a very long while now - I have tried everything
other than buying the alloy Square gearboxes.
As DZ mentions Tamiya has brought out a thicker gear.
But... I also have an example of this gear with 8 missing teeth!
So evidently that is not the cure.
I'd go buy the longer shaft first though.
www.PandaGFX.com
www.MelbRC.org
Old 04-26-2004, 07:57 AM   #6101
WC
WC's Avatar
If you're lucky your car might come with some spares...
The kit gave 3 of each gear, plenty of spares.
When you buy spare bevel pinions you'll also get the diff gear.
No you can't use the one-way's gear on the diff, hole too big.
(but you can cut the diff gear to fit onto the oneway if needed)
www.PandaGFX.com
www.MelbRC.org
Old 04-26-2004, 08:07 AM   #6102
WC
WC's Avatar
Ya wierd!! I find it frustratingly *slow* with a diff too!
Its as if there's no punch out of the corners, no fun at all.
I have no explanation for it. I have tried many combinations of
tight front, loose back diff and viceversa, still no cigar.
(even wierder, I retrofitted oneway to a TA04 but it didn't
give it any extra punch like it does to an EvoIII)
I like the oneway better.
(Handbrake turns thru tight corners is handy sometimes too!!)
Stripping never stranded me in a race ever, so I don't have
any hard feelings about the diff gear. I open the front gearbox
every so often just to have a checkl if there's any dented teeth
I clean them up with the knife and reinstall it. I'd only replace
the whole gear when there's like 10-12 teeth gone, or more
than 3 in a row.
My twin-diff EvoIII is doing drift duty now.
The other grip racers run oneways.
www.PandaGFX.com
www.MelbRC.org
Old 04-26-2004, 08:14 AM   #6103
http://i23.ebayimg.com/03/i/01/b1/a5/6e_1.JPG
Theres the picture of the extra parts that come with the car...it looks like it came with a few extra gears
You count fast WC
Old 04-26-2004, 08:24 AM   #6104
Default Spool
Does anyone know where i can get a spool in the UK as i dont want to order from America or Japan for just one item.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 04-26-2004, 08:28 AM   #6105
WC
WC's Avatar
From the looks of it, methink you'll be getting SIX diff gears!!!
And one spare bevel pinion.
First thing I'd do on receiving the car... check the hingepins.
(take them out, roll them on your ultra-flat setup board)
I have a dire feeling you'll be finding at least one bent one.
Buy new ones & keep lots spare, they're dirt cheap anyway.
www.PandaGFX.com
www.MelbRC.org
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
