Old 04-22-2004, 05:45 PM   #6076
losispeed's Avatar
Default Re: Spool
Originally posted by weekendracer_uk
Does anyone know where i can get hold of a spool here in the UK ??
Here's a noob question but what is a spool?
losispeed is offline   Reply With Quote
Old 04-22-2004, 06:16 PM   #6077
Tek Nickal's Avatar
A spool is a locked diff, no diff action at all.
Tek Nickal is offline   Reply With Quote
Old 04-23-2004, 12:30 PM   #6078
Out of curiosity....I know the Reedy Race of Champions mandates full time 4-wheel drive (no one-ways), yet there were some Evo III Surikarn Limited's in the fields. Whats the part number/where can you get an Evo III ball diff? Is a TB01 or a TB02 ball diff assembly compatible?
The Black Kat is offline   Reply With Quote
Old 04-23-2004, 01:11 PM   #6079
ngo8's Avatar
Send a message via ICQ to ngo8
a rear diff will fit the front diff on a evo3
ngo8 is offline   Reply With Quote
Old 04-23-2004, 01:23 PM   #6080
I know...but where do I get/whats the part number for one?
The lightweight outdrives alone are like $17
Old 04-23-2004, 02:16 PM   #6081
rtypec's Avatar
Pick up a spool from Steve at Speedtech RC. They use the older style oneway-gear (thin ones?) and have been lightened extensively. DIALED.
Edit:
Here's the link to the speedtech page: Spoolio
rtypec is offline   Reply With Quote
Old 04-24-2004, 03:32 AM   #6082
work's Avatar
Anyone here tried using torque rods ala Ta04-R? What benefits will it bring to the car? Thanks
work is offline   Reply With Quote
Old 04-24-2004, 04:43 AM   #6083
Wency_TA03R-PRO's Avatar
Exclamation Re: New car
Originally posted by DJB
Hi guys
i just bought a new tb evo 3 surikarn edition can u guys give me some tips to make it go faster?? i only run 540 stock motors and ive geared it properly but i still need a bit more speed. also the shaft seems to be sloppy. will i need the option on-53686 or what should i do? I race on concrete at nite with tamiya A tires and an LRP V7.1 speedo. Any help would be greatly appreciated.
dan
Bro have you tried running modified motors??! Try it on your suricarn edition.. definitely you will find it too fast if your just a beginner in RC world...
Try reedy modified motors the TI, PT, and KR.. or try the LRP brands fusion is the best...
Wency_TA03R-PRO is offline   Reply With Quote
Old 04-24-2004, 04:47 AM   #6084
Exclamation
Originally posted by GFXmania
GP3300 can charge more than 3600mah already. Do you think you really need to have the new cells? Just a thought.
Was these cells already released???!! I'd love to put this on my kit... so far Im using GP3300..
Old 04-24-2004, 09:39 AM   #6085
WC
WC's Avatar
Trader Rating: 28 (100%+)
If you've read thru some of the previous pages, you'll have known
that Tamiya does not sell any EvoIII diff kit - need to build it from parts.
Get:
1x TA04 ball diff kit
1x EvoIII outdrives
1pr F201/EvoIII diff rings
2x 850 bearings
1x EvoIII diff gear
For your front diff buy the BLACK outdrives.
The white (dearer) ones are too brittle.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 04-24-2004, 12:06 PM   #6086
can anyone tell me for sure if the new light weight prop for the evo3/tbo2 is longer then the standard evo3 sl?
is it 2mm longer?
thanx
trf racer is offline   Reply With Quote
Old 04-24-2004, 12:17 PM   #6087
ngo8's Avatar
yes it is 2mm longer trf racer .
Old 04-24-2004, 07:16 PM   #6088
Get:
1x EvoIII outdrives
2x 850 bearings
1x EvoIII diff gear
Bro, I don't have the time to read through 200 pages
Do I really have to get the TA04 diff kit? Can't I just piece it together using the TB-02 Diff outdrives, Evo III diff gear, and some TC3 diff parts
BTW: I don't have the car yet...what are the 2 850 Bearings for?
Can I just slap one of these in http://www.carttonic.com/catalog/ind...=0,13203,16711
EDIT: I just need the cheapest way to build a ball diff...keep in mind I have parts from the TC3 if that will ease any cost (ie...trust bearings...diff screw/sping/nut) Anything that will cut the cost is a big help as of I have NO cash and need to basically save my lunch money for this... I can't drive a car with a front one-way so its not even gonna touch the track until I get a differential in the front of that car
Old 04-24-2004, 07:28 PM   #6089
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
So meaning the Ta04 delrin diff holder (white)can be use in the TBIII?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 04-24-2004, 07:58 PM   #6090
WC
WC's Avatar
EvoIII outdrives is different to TA04 outdrives.
There is a great "Seach/Display By Posts" function above...
I don't know if TC3 bits will fit, guess you can go find out. You need to source the long M2 centre screw, the thrust bearing, the M2 nyloc nut, the tension spring & the diff balls.
850 bearings are used in the diff, when you get your car & manual it'll be self explanatory.
www.PandaGFX.com
www.MelbRC.org
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
