Old 04-01-2004, 12:01 AM   #5956
WC
WC's Avatar
Trader Rating: 28 (100%+)
I have no problems whatsoever with the rear gears too.
All except for the 1 time when the bevel's 1280 bearing C-clip came loose and it fell into the teeth... got mashed into 5 pieces. The teeth still worked and I never discovered it until the next teardown, but the gears got a beating.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 04-01-2004, 07:19 AM   #5957
honestly, the square gearboxs dont weight much more then the stock boxs!! ill weight them up when i get some time.
The square rear uprights are lighter then the stock uprights!! how? i have no idea!!
i think im gonna install front bearing, im guessing that it will not only reduce wobble but also mean less weight on the front gearbox which will be good!!
But... ill have to ditch my lovely red support
Evo_Uk is offline   Reply With Quote
Old 04-01-2004, 06:30 PM   #5958
TFR
TFR's Avatar
Hey guys, just got my EVO III. I was wondering is the drive shaft suppose to be a tight fit to the gears? Does it move freely forward and back when install or its tight?
TFR is offline   Reply With Quote
Old 04-01-2004, 06:59 PM   #5959
hawker's Avatar
should be a bit of play
hawker is offline   Reply With Quote
Old 04-01-2004, 07:16 PM   #5960
TFR
TFR's Avatar
You mean when everything install, I should be able to move the shaft forward and backward freely?
Old 04-01-2004, 07:35 PM   #5961
hawker's Avatar
i just checked my two cars, there is about 1-2mm, works good for me
Old 04-01-2004, 08:00 PM   #5962
jeffreylin's Avatar
R/C Tech Charter Subscriber
There should be a little play. It also depends on which shaft you have in your car. The original shaft is about 2mm shorter than the new light weight shaft and has more play, whereas the new improved shaft should give you minimum play.
jeffreylin is offline   Reply With Quote
Old 04-02-2004, 04:44 AM   #5963
work's Avatar
which shaft is better the tech racing or the new lightweight shaft? And do i need the penguin plate for the Jurgen 1way? thanks
work is offline   Reply With Quote
Old 04-02-2004, 05:17 AM   #5964
V12
V12's Avatar
never had a tech racing shaft in the car but looked at it and it´s so heavy. Don´t want it in my car. So I would go for the lightweight shaft. I have one but yet have to try. Will go in my new second EVO3.
The Penguin plate won´t work with the Jürgen oneway but also there is no need for it as this oneway is using a very big backingplate nearly as large as the onewaygear.
V12 is offline   Reply With Quote
Old 04-03-2004, 02:37 AM   #5965
This questions for RtypeC
hey friend, ive tried and tried and tried, got my drivetrain super lightweight and free, flushed out the bearings and so on but i just cant get it "blow on spur free".
could you give me some tips on what other things i may need to do?
Im running ceramic diffs, bearings from the SE, alloy diff cases, lightweight prop standard axles and hubs
thanks
Tarnjit
PS any vids of you drive train spinning??
Old 04-04-2004, 07:08 AM   #5966
work's Avatar
thanks v12! never ran my evo3 yet still waiting for my electronics
Old 04-04-2004, 08:06 PM   #5967
rtypec's Avatar
Hi Evo_Uk, I believe the stars and planets were perfectly alligned during that particular rebuild because it was pretty sweet. It's been over a year since I've had a drivetrain that free and to be honest, I paid for it because the gear mesh was not tight enough and made "coffee grinder" noises when I got on throttle with a 19T on high traction asphault. Nowadays, I just make sure it doesn't bind anywhere and remove shims until I get the "grinder" then I replace the shim I took out Time is better spent on track than working on the extra wheel spin.
rtypec is offline   Reply With Quote
Old 04-05-2004, 01:43 AM   #5968
you know what guys, i think i might sell my gearboxs and go back to the stock ones, i think you have more option with shimming...
good idea?
Old 04-05-2004, 03:00 AM   #5969
good idea?
Just goes to show that just because they are nice and shiney it dont mean they are any better than the standard items by Tamiya.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 04-05-2004, 07:37 AM   #5970
well i dunno, they surely are presise. they hold the bearings ALOT better indeed to reduce any wobble. but they hold it so presise that it gets rid of any shimming u might want to do.
so if i used the stock gearboxs id have to find a way of holding the bearings in better then shim it.
ill have to experiment i guess
tarnj
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
