Old 03-29-2004, 11:47 AM   #5926
the track i race on has JUST recently been resurfaced, only had one meeting on it
www.bedworthrc.com
so its kinda ungrippy in place but in some places super!
I think i may try a front ARB, but which one to choose? i have no idea
thanks for the help
Tarnjit
Evo_Uk is offline   Reply With Quote
Old 03-29-2004, 11:59 AM   #5927
V12
V12's Avatar
Last outdoor season I was using blue rollbar front and yellow rear in general. Springs were Tamiya blue or Associated silver front and rear. Only at one race (German Champs) I was using yellow rollbar front and no rear with yellow springs front and rear.
V12 is offline   Reply With Quote
Old 03-29-2004, 03:47 PM   #5928
ngo8's Avatar
Send a message via ICQ to ngo8
for foam/carpet i use associated springs/and oil they work great .
ngo8 is offline   Reply With Quote
Old 03-29-2004, 06:43 PM   #5929
WC
WC's Avatar
Trader Rating: 28 (100%+)
Default Re: Help
Originally posted by devil
Does anyone know how to stop the binding in the gears, I have the Tamiya light weight shaft (2mm longer), the new front gears and a brand new gear case but the binding is still there.
Spent some hours on exactly this meself, last night.
First work out *what* is binding.
Is it your bevel pinion? Turn the shaft by hand... if it clicks once every revolution then its the pinion - It will be at the same spot all the time. Note where the rough spot is.
If it jams once every 2.6 turns, its the spur.
Then open up the gearbox carefully, don't pull the gears out yet. Look inside and take note of which teeth are touching between the 2 gears & mark them. Take out the gears and inspect their teeth around the touch point, you may have to clean out any molding excess etc.
If your centre shaft has been dropped on a hard floor before... you could have dented the tip also.
Sometimes just over-tightening the gearbox cover's 3 screws is enough to cause binding. Back them out a half-turn and try again.
Each car needs its own individual finessing, but it does work.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 03-29-2004, 07:47 PM   #5930
gcooper's Avatar
What were the conditions that got you down to yellow springs and yellow front swaybar only? Was it rain?
Coop
gcooper is offline   Reply With Quote
Old 03-29-2004, 10:47 PM   #5931
devil's Avatar
Default Re: Re: Help
yes it is the bevel gear binding and it doesen't matter how many gears you put in its still there, i've also tried different shafts and still nothing.
I think the problem is the bevel gear is slightly made badly and it is of centre and i was wondering if anyone knew how to solve this
devil is offline   Reply With Quote
Old 03-29-2004, 11:08 PM   #5932
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: Help
Not sure if you meant if you tried a new bevel gear. If not, I will try that first. If you did that already, maybe your bearing is broken or not fitted correctly inside the gear case.
jeffreylin is offline   Reply With Quote
Old 03-29-2004, 11:43 PM   #5933
Hey i got down to those conditions, my winter setup here in the UK when its very cold and yes rain too in some cases, havent tried the front sway bar but will give it a shot
Old 03-30-2004, 12:51 AM   #5934
devil's Avatar
Default Re: Re: Re: Re: Help
Yeah i tried a few new bevel gears and the binding was still there, i tried another bearings and still it was binding. I just thought of trying something i tell you if it works.
Old 03-30-2004, 06:31 AM   #5935
gcooper's Avatar
Default Re: Re: Re: Re: Re: Help
Have you tried using one of the bevel gears with the back cut off? It was part of the fix for helping with the mesh on the 1-way to keep it from stipping.
Coop
Old 03-30-2004, 06:54 AM   #5936
jeffreylin's Avatar
Default Re: Re: Re: Re: Re: Re: Help
Coop
That is a terrible idea. It would weaken your bevel gear and make it wobble.
Old 03-30-2004, 07:07 AM   #5937
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Wow!!! got 198 pages to read.
I have 1 question about the Tbevo3.may be some one post this before.
Just for a quick one.
what is the common problem of this tbEvo 3?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 03-30-2004, 07:23 AM   #5938
Ooj
Send a message via ICQ to Ooj Send a message via MSN to Ooj
How to get rid of some binding
One of the reasons why the people using the Tech Shaft have very smooth and "bind-free" drivetrain is that it requires the use of an extra bearing in the front plastic upright that the shaft goes through. Using the same idea, just buy a bearing the same size as the one that goes in the motor mount, put a thin layer of CA on the edge and stick it in the plastic upright. I have done this and there is no high spot anymore when using the standard shaft and it is as free as when I used the tech shaft
Ooj is offline   Reply With Quote
Old 03-30-2004, 08:57 AM   #5939
V12
V12's Avatar
Coop
Never had to race in the wet since I have the EVO3.
No it was a very large track with a high speed sweeper and I needed more overall grip there for being fast. Tires were limited to one Spec tire so I had to change setup according to track conditions.
Old 03-30-2004, 11:11 AM   #5940
i just sold my tech racing 3 piece, just thought it was too heavy and if u inspect very carefully u will find there is the slightest binding actually there, i think its covered up a bit becasue of the weight of the thing.
I think im gonna put the front bearing back in though.... but it means getting rid of my shiny red one
Tarnj
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
