Tamiya TB-Evolution III
#5911
Anyone using non-Tamiya shock springs?
Hi Guys,
Tried some Associated Springs at the indoor carpet track today, as the Tamiya Springs weren't hard enough for what I wanted and the transformation was amazing!!! The car was much more agile, turn in was great and I could carry more speed through the corners. I used the Asso Gold Springs upfornt (20.5 pounds, I think) and Tamiya White at the rear. 600 Oil in all shocks and running Sorex 24R Tyres.
My previous setup was the same only with Tamiya White and Blue Springs (F & R).
I think I may try out the next springs up to see what affect it has.
#5912
I've been testing xray springs.. they also have been working really good..I've been using them on my foam asphalt setup. Which we run here.. I've been using xay white which is about 17lbs..This weekend i'm trying Xray blue on the fronts 22lb and xray light blue on the rear 20lb.. see how we go....Has any one tried running the car with out sway bars..
#5913
coop
#5914
Thanks..
I've been having trouble with the sway bars affecting my droop. As the foams true down to a smaller diameter the sway bars seem to hold the arms up. i was considering lengthing the sway bar brace that attaches it to the arms..has anyone already tried this..and help would be nice.
#5915
try to run harder springs it is on carpet so you have lots of traction hope it helps .
#5916
I'm also going to try the 22lb front springs and the 20lb rear. Strange that Tamiya don't make any harder springs
Are you running the Xray shocks? I'd like to try them as they'd provide a quicker setup option.
Cheers, Mark.
#5918
Cheers, Mark.
Cheers, Mark.
#5919
Help
Does anyone know how to stop the binding in the gears, I have the Tamiya light weight shaft (2mm longer), the new front gears and a brand new gear case but the binding is still there.
#5920
Re: Help
#5921
Re: Re: Help
Are you shimming the gears at all.. try shimming also replace the rear bevel and pinnion ...good the start a fresh...if it's still there try spraying out your bearings in the drive train.
#5922
Cheers, Mark.
Cheers, Mark.
Mark, I think the info Tamiya uses for the options, like springs, come from the factory Tamiya tracks. And unfortunatly the are all asphalt. I only know of one Tamiya Carpet track in Japan, and it is only set up for worlds.
#5923
#5924
Ive always only used softish springs on my car (red /yellow , yellow/blue ), how would adding roll bars let me carry more corner speed?
I also had that binding in my gears , i just rand my car in and it went away itself
#5925
An anti-roll bar doesn't allow you to carry more speed, but it would give you a better steering response (front anti roll bar). Also, the front anti-roll bar will take away front traction and increase rear traction.
A rear anti-roll bar would also allow the car to react quicker to steering responses, but then it takes away rear traction and increases front traction.
If you're running on a smooth circuit with lots of grip, it is better to go for stiffer setup, i.e. springs and dampers.
I actually like to start off with a very stiff car, to the point where it hasn't enough grip and then come back (i.e. make it softer) until I'm happy with the balance, grip and response of my car - it is all a balancing act to get it right.
