Old 03-09-2004, 05:51 PM   #5836
DZ
The short springs come in Burgundy and grey as well. can't remember the part number.i know they exist because i have them got them from R10
DZ is offline   Reply With Quote
Old 03-09-2004, 05:56 PM   #5837
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
The purple (burgandy) springs and Grey are not the short springs. They are the same length as the regular on road springs.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|Associated B5M|TA05|TL01RA|TL01|F104 Pro|RM-01
f1larry is offline   Reply With Quote
Old 03-09-2004, 06:36 PM   #5838
DZ
don't mean to be rude but i have the short ones..
Here are the product codes
53635 TRF SHORT DAMPER SPRING(SUPER HARD SPRING:2pcs),
53636 TRF SHORT DAMPER SPRING(ULTRA HARD SPRING:2pcs),
like the other springs then come in the normal and short lenghts
Cheers Dz
Old 03-09-2004, 06:45 PM   #5839
RCGaryK's Avatar
The Golds are the same as the Tamiya 4 spring yellows.
No, they are different. You can feel a difference in fact. They are also a slightly different length too.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 03-09-2004, 06:47 PM   #5840
f1larry's Avatar
Cheers Dz
Your not being rude.
I have them as well and the package says short damper spring on it, but if you look at them they are longer than the short springs and are as long the regular on road springs.
Old 03-09-2004, 07:16 PM   #5841
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Woops, the three "sets" were for shock oil, not the springs...
Another question, when you countersink the upperdeck, does this make the chassis stiffer?(I was thinking this because there is more surface contact with the screw, and the screw will make the upperdeck stay put a little bit more)
Also, can a person buy a full set of the stock steel berrings?
Bubblestc3 is offline   Reply With Quote
Old 03-09-2004, 07:53 PM   #5842
Send a message via AIM to A-Ko
Well I guess if you want to be technical the Golds were 1% heavier than the Yellows so you are right but, converting them to pounds they are the same.
My bench testing showed they are the same even taking account of the different length. I also test the springs new and have heard that different batches can reveal different results.
It is nice that Tamiya finally broke 20 pound barrier with their Grey and Purple springs.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 03-09-2004, 08:33 PM   #5843
rtypec's Avatar
Hey bubbles, the shock oils come in packages of three 200,300,400 (53443) then there's 500,600,700 (53444)and finally 800,900,1000 (53445). They're all color coded and made with a very consistent synthetic oil. Good stuff. They're measured in metric so I don't know what their equivalent SAE rating would be (# weight)
The countersunk deck does help with stiffness a little but for the most part it's there to help prevent minor tweaks. The only catch is that you must have a bit that countersinks the right depth and diameter so that a countersunk screw sits right. Also, you need to make sure that the chassis is built perfectly flat and that ALL screw holes from the both bulkheads, motormount, center bracing, etc. line up perfectly or else you'll put a tweak into the chassis when you tighten things up. It's a chore but it can be done using shims between the gearboxes and upper deck mounts and trial and error method.
Stock metal bearings? errmmmm I'm not sure if they're available but you can always call Tamiya, or inquire with Speedtech, or check out acerracing.com
Hope this helps.
Edit: p.s. Why aren't you at Slocal? Oh snap, look at all the places I referred you to...they look like my sig haha Okay if you need batteries go to promatch!
rtypec is offline   Reply With Quote
Old 03-09-2004, 08:45 PM   #5844
Registered User
Suradaj's Avatar
Have anyone tried the SQUARE gear box? If so, still strip any gears?
I heard that the TB-02 shaft was longer? Is it better to put that into the EVO III?
Suradaj is offline   Reply With Quote
Old 03-09-2004, 09:48 PM   #5845
Hope this helps.
Hahahahaha, no SloCal tonight, that thing about waking up for school the next day came up between the mother and I, and I could not go... LOL, but acerracing is not in your sig...
Thanks for the help Rod
Old 03-10-2004, 12:40 PM   #5846
V12
V12's Avatar
Got my lightweight shaft today. Maybe trying this weekend.
Do I have to change the shims with the oneway using this shaft or keeping the same shims?
What if using the Square aluminium gearbox?
V12 is offline   Reply With Quote
Old 03-10-2004, 12:45 PM   #5847
jeffreylin's Avatar
I also use the square gearbox and Jürgen oneway. I had never shimmed my gears and with the new shaft, I have yet to have any problem with the gears.
jeffreylin is offline   Reply With Quote
Old 03-10-2004, 01:11 PM   #5848
V12
V12's Avatar
I´m not using shims with the gears but one 0,2mm shim on the Jürgen oneway toward the rightside 1510 bearing at the moment.
So you are not using any shims?
I´m not talking about problems as I´m still using same onewaygear since using the Jürgen oneway. But I think the drivetrain will run different with the longer shaft maybe less free so you have to adjust shimming to run as before. Maybe I´m completely wrong and it works different in regard of freeness.
What do you think?
Old 03-10-2004, 01:47 PM   #5849
jeffreylin's Avatar
What do you think?
I would suggest that you try to run without the shim. I think it's freer that way. I don't think it's necessary unless you have problems.
Old 03-10-2004, 02:28 PM   #5850
V12
V12's Avatar
Thank you. Will try that next weekend.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
