Old 03-01-2004, 09:32 AM   #5731
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by V12
Donīt know, I think we wonīt get the shaft here in a short time.
Maybe I will order something from Asia.
But Iīm not shure about the Tamiya shaft. The Team Bomber Graphite shaft looks very good also.
Have you heard good things about the Graphite shaft? Is that also only available in Asia?
markp27 is offline   Reply With Quote
Old 03-01-2004, 09:35 AM   #5732
V12
V12's Avatar
Default Re: Tyre Traction Fluid
Originally posted by markp27
Hi Guys,
After you've left the tyre traction fluid on for a while, do you clean it off with anything. The guys at my track use a break cleaning fluid - is this common?
Cheers, Mark.
Usually Iīm using brake cleaner for removing dust and rubber parts from the tires. But this is before applying traction compound not afterwards.
Iīm removing the traction compound that hasnīt dried about 5-10 minutes before I go to the track using a paper towel as used in the kitchen. The one from Aldi works very good.
V12 is offline   Reply With Quote
Old 03-01-2004, 09:43 AM   #5733
V12
V12's Avatar
Originally posted by Rick Draper
I have brought a bomber racing carbon center shaft, a shed load of light weight evo shafts and all a load of evo renforced gears from champ. Japan is cheap as hat. Rick
Rick as you have both the Team Bomber shaft and the light weight Tamiya shaft now which one do you like better? Also how much is the weight of these in compare to the stock EVO3 shaft?
How much costs the Team Bomber shaft? Did you find any other interesting parts for the EVO in Tokyo?
Old 03-01-2004, 09:45 AM   #5734
markp27's Avatar
Default Re: Re: Tyre Traction Fluid
Unashemed advertising! I'm off to Aldi
Thanks for the info!!
Old 03-01-2004, 01:04 PM   #5735
I would rather have the Tamiya lightweight item as its lighter than the bomber racing item but just does not look as good. No other interesting evo bits, i really wanted the milled chassis but i cud not find one anywhere. Rick
Rick Draper is offline   Reply With Quote
Old 03-01-2004, 01:08 PM   #5736
so which greese to use in my little diff bearing?
bearing oil?
diff grease?
bushing oil?
Evo_Uk is offline   Reply With Quote
Old 03-01-2004, 01:20 PM   #5737
V12
V12's Avatar
Rick
Thanks for the information. If possible could you please post a picture of the shafts and how much lighter they are?
Saw a very small picture of the Bomber shaft but you couldnīt see very much and no picture at all from the Tamiya leightweight one.
Old 03-01-2004, 01:30 PM   #5738
V12
V12's Avatar
bearing oil?
diff grease?
bushing oil?
EVO UK
You talk about that thrust bearing?
Iīm using the Associated black grease now I think it works best from the different I tried.
But I have to say usually my rear diff only works for about 10 -15 runs. Tried carbide diffballs but thatīs not very different. Iīm not sure yet but I think itīs because the diffrings are a little on the soft side or the onepiece thrustbearings maybe isnīt that good as the thrustbearings from other cars.
I have to say the diffs from my TC3 and XXX-S worked for much longer without rebuild.
But thatīs the only problem I have currently with the EVO3.
Old 03-01-2004, 02:08 PM   #5739
hemi426's Avatar
Rick
I will get the lightweight shaft 53686 in a few days. I could make a photo with the stock shaft next to it. Weigth difference is 4g, but keep in mind thats rotating mass.
TRF 416, Cyclone S, TT-01E, Evo III SL, TamTech GT01, Slash, M18 Pro, M03-R
hemi426 is offline   Reply With Quote
Old 03-01-2004, 02:21 PM   #5740
markp27's Avatar
Where are you getting the shaft from?
Old 03-01-2004, 02:41 PM   #5741
hemi426's Avatar
A guy who also drives in the Tamiya Euro Cup Series offered one in the German rcweb.de forum.
But there are several lightweight shafts for sale on ebay.com from sellers from Hongkong (for the same price).
Old 03-01-2004, 04:03 PM   #5742
Rick
Tomorrow i will get weights of all 3 props and take pics pf them all then post them up. Rick
Old 03-01-2004, 05:26 PM   #5743
ngo8's Avatar
Send a message via ICQ to ngo8
evo_ uk i use this grease called JUDY BUTTER ITS USED FOR MOUNTAIN BIKES but it works great the only thing its expensive
but good i use it for my diff also .
ngo8 is offline   Reply With Quote
Old 03-01-2004, 05:46 PM   #5744
madjack's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to madjack
Post updated parts
Has anyone run the alloy rear uprites that Tamiya recently released? If so what was the change in handeling?
thanks,
JC
madjack is offline   Reply With Quote
Old 03-01-2004, 06:29 PM   #5745
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: updated parts
thanks,
JC
I suppose this is the one used in trf415. I wonder what is the purpose of making it alloy since the old plastic one works just fine. The alloy one should be heavier than the plastic one and that will add unsprung weight to the car.
jeffreylin is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
