Old 02-27-2004, 09:14 AM   #5701
hemi426's Avatar
Is the stock shaft of the standard EVO3 the same length as the Surikarn (short)?
Hemi
TRF 416, Cyclone S, TT-01E, Evo III SL, TamTech GT01, Slash, M18 Pro, M03-R
hemi426 is offline   Reply With Quote
Old 02-27-2004, 09:58 PM   #5702
rccarracer's Avatar
Hemi
Both shafts are the same length.....
rccarracer is offline   Reply With Quote
Old 02-29-2004, 01:00 AM   #5703
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Well, I raced my EVOIII for the first time today. I qualified third, in a three main class!!!(A-Main, B-Main, C-Main) The only problems that I had all night was motor and the car pushed slightly. I was passed on the outside going down the straight-away after I passed for the lead. The car COULD turn enough, but I would scrub too much speed, which there was almost none of to begin with, and I would be in deep(er). I got tangled with lap traffic towards the end, but overall, I was very impressed with how the car worked at SoCal.
Bubblestc3 is offline   Reply With Quote
Old 02-29-2004, 05:46 AM   #5704
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default New Shaft
The car now have about 20 runs and 2 full races with the new improved shaft that is 2mm longer. All the gears are still looking as new with no wear whatsoever.
jeffreylin is offline   Reply With Quote
Old 02-29-2004, 07:15 AM   #5705
markp27's Avatar
Send a message via ICQ to markp27
Default Re: New Shaft
What's the part number for the new shaft?
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 02-29-2004, 07:30 AM   #5706
V12
V12's Avatar
What colour is the new improved shaft?
Is it titanium grey or is there also a blue one?
V12 is offline   Reply With Quote
Old 02-29-2004, 07:36 AM   #5707
markp27's Avatar
Hey, V12, I tried out the Jürgen one-way - not problems with the gear now but I find the bearings don't run so free like the Tamiya one is it the same for you?
BTW: Got my Mazda body now look really good!!!
Mark.
Old 02-29-2004, 10:43 AM   #5708
V12
V12's Avatar
Mark.
Yes it´s the same for me. Jürgens uses some longlasting bearings which aren´t that free as the usual ones. But that´s not a big problem for me. I like this more than replacing them after a short time as I can´t do this myself.
But it´s a good idea using the Serpent Oneway Lube also. Works for every oneway. Don´t use brakecleaner for degreasing as this could damage the onewaybearings just use the lube.
Old 02-29-2004, 10:48 AM   #5709
markp27's Avatar
I thought I'd be the only one using Serpent Oneway Lube
When the bearings are worn, where can they be replaced? Does Jürgen do this?
Old 02-29-2004, 11:18 AM   #5710
hey guys,
raced mod indoors for the first time yesterday. Had problems with my diffs just tightening themselves. i got ceramic diff balls in them.
any help is apprietiated
cheers
Tarnj
Evo_Uk is offline   Reply With Quote
Old 02-29-2004, 12:27 PM   #5711
grease on the little bearing inside the diffoutdrive
gizmo is offline   Reply With Quote
Old 02-29-2004, 01:28 PM   #5712
V12
V12's Avatar
If you would be the only one using it Serpent wouldn´t make very much money on the lube.
But not too much people racing electric doesn´t know this stuff.
yes, Jürgen will be able replacing the oneway bearings but I haven´t heard any of his have failed since now.
Old 02-29-2004, 02:42 PM   #5713
Gizmo , i didnt quite understand what you meant. what shall i do to the little bearing? avoid greese on it , is that casueing it or grease the bearing?
Old 02-29-2004, 02:50 PM   #5714
ngo8's Avatar
Send a message via ICQ to ngo8
EVO_UK i run my evo3 on carpet and i have the same problem i found out that you dont need alot of diff grease on them just a little otherwise they slip you need to run them rough just the way it is .
ngo8 is offline   Reply With Quote
Old 02-29-2004, 03:35 PM   #5715
you must grease the little bearing otherwise it will lock up,so will your diff
the little one gets stuk in the diffoutdrive so it will screw/or unscrew your diff by movement
just a drop of ball-diff grease or if you have green slime (trinity)
and its oke.
if you got a black diff replace it in time for a white one they are much better
while your at it check the movement of the diffplates as well
NO movement in those two
building and mantaining a diff takes time!!!!!!
don`t rush it take that time (saves money)
greetings
gimzo
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
