Old 02-25-2004, 11:45 AM   #5686
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by V12
Exactly there I got mine!
Just ordered an Alfa and a Mazda via Ebay
Looking forward to trying them out
markp27 is offline   Reply With Quote
Old 02-25-2004, 01:04 PM   #5687
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Surikarn
anyone interested in a surikarn evo III? (it comes with a lot of spares) I got one for sale.. check the link in my signature.. or go to the for sale forum. thanks for reading guys!
mark.. you'll like the mazda... more steering but stable like a stratus. guess it has the steering of the alfa but the stability of the stratus its all i run for my cars now.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-25-2004, 03:56 PM   #5688
Trader Rating: 24 (100%+)
Hey gents,
Posted some time back but I still need your help. I'll be running the EvoS for the first time and the course is a tight , technical , asphalt track. Tires will be CS27 and motor will be MVP, Core Stock or Peak Hellfire. NO ONEWAY allowed. Anybody out there have a good setup they can recommend ??? I have one ( Thanks Aurra Sing) but I could use a couple more. Thanks in advance !!!
Evoracer is offline   Reply With Quote
Old 02-25-2004, 05:56 PM   #5689
rtypec's Avatar
Hey Evoracer. Here's a setup from the Dave's at Tamiya. I hope this helps...
Also, with this setup, you'll need to grind the top corner of the front rear suspension block a little bit so that they do not interfere with steering.
rtypec is offline   Reply With Quote
Old 02-26-2004, 01:12 AM   #5690
jiggen5354's Avatar
does any one have both the tb-02 and a surikarn? I want to compare the driveshafts in both thes cars
According to people at my local track If you use the hole the pin goes through for the spur gear adapter as a reference point you will find the tb-02 shaft is a bit longer in the front than the evo3 shaft.
can any one comfirm this?
If this is true then I should be possible to stop the stripping of bevel gears without having to resort to pinning the front bevel gear. stripping the ring gear is not a problem for me, just the occasionaly bevel gear and ballhead king pins which I am having trouble finding.
does any one have a part number for just the ball head kinpin on its own?
thanks
jiggen5354 is offline   Reply With Quote
Old 02-26-2004, 02:21 AM   #5691
jeffreylin's Avatar
R/C Tech Charter Subscriber
thanks
If you are stripping your bevel gear, check the notch on your shaft. If it's worn then replace your shaft. It is a cheaper and longer lasting fix than replacing the bevel gears. Before I replaced my shaft my bevel gears last for about 4-5 runs or less. I noticed that I am replacing the bevel gears more and more frequently even though I been more careful with my driving with less crashes. After I replaced my shaft last week I have had 10 runs or so and there has been no wear on the bevel gears whatsoever.
jeffreylin is offline   Reply With Quote
Old 02-26-2004, 02:40 AM   #5692
Registered User
maverick's Avatar
Default shaft lengths
putting the evo3 (SE and Lim Ed) side by side with the TB02 shaft it will be noted that the TBO2 shaft is longer by about 2mm. blue version and the tb02 are of the same length.
maverick is offline   Reply With Quote
Old 02-26-2004, 05:50 AM   #5693
jiggen5354's Avatar
thanks for the info maverick
I will look into getting a TB-02 drive shaft
jeffreylin
So far I have partially stripped the "d" on 2 bevel gears but this is due to the fact that the drive shaft is too short in my opinion as the end of my drive shaft is still good with no noticable wear.
i think i can get away with using the damaged bevel gears in the rear diff as the driveshaft extends ouf far enough to stick out of the bevel gear.
Old 02-26-2004, 09:21 AM   #5694
Hebiki's Avatar
thanks
i have both cars.. ill compare the length of both drive shafts tonight. ill let you know what i find.
Hebiki Design Works
Old 02-26-2004, 06:51 PM   #5695
jeffreylin's Avatar
Default Re: shaft lengths
You are right! both the new light weight propeller shaft and the blue shaft are slightly longer than the red surikarn shaft. Is this Tamiya's fix for the problem? Thus far the light weight propeller shaft performs great with no damage in any of the gears after 10-12 runs.
Old 02-26-2004, 07:03 PM   #5696
Barry White's Avatar
An other option is this.
Tech Racing have a new impoved lightweight floating shaft for the TB02 with all parts made of aluminium and o rings for self centering and less chatter.
Barry White is offline   Reply With Quote
Old 02-26-2004, 08:32 PM   #5697
hierog's Avatar
is there a website for tech racing? if not, where can I buy or see some of their products?
vic
hierog is offline   Reply With Quote
Old 02-27-2004, 06:05 AM   #5698
V12
V12's Avatar
Are there any pictures of the new light weight propeller shaft?
And how much is the weight difference to the stock propeller shaft?
V12 is offline   Reply With Quote
Old 02-27-2004, 09:01 AM   #5699
jeffreylin's Avatar
vic
They have a website but it's in Japanese. I tried emailing before but never heard back from them.
Old 02-27-2004, 09:04 AM   #5700
jeffreylin's Avatar
They are just thinner in the middle than the regular aluminum shaft. Saves just a few grams.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
