Old 02-21-2004, 11:57 AM   #5656
Tag
Tag's Avatar
Trader Rating: 30 (100%+)
hey thanks , i will be sure to look for you this afternoon
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 02-21-2004, 03:13 PM   #5657
hawker's Avatar
Hey guys,
My EVo's are still ripping it up, quick question though, is anyone else having weight problems with the standard evo?
My surikan weighs it at around 1470 grams, but my standard weighs in at 1560-70 depending on battery. I think I might have to invest in some Titanium screws and the such, but I can't see where the extra weight is, this is what I have in the stand evo.
Evo 111 Chassis
Johnno 540
Futaba S9550 Short Digital Servo
Futaba HRS Receiver
Futaba MC800 Pro Speedie (the small sucker)
Fukuyama 3300 Cells
Chrysler 300M Body shell
My surikan edition has all that except for the speedie which is a LRP Super SPort I think, one of em anyway which is bigger and heavier. Any ideas on lowering the weight?
THanx guyz
hawker is offline   Reply With Quote
Old 02-21-2004, 09:59 PM   #5658
RCGaryK's Avatar
aurra, are you running the 2 degree blocks with the b block then?
Originally posted by Aurra Sing
Try my carpet setup:
Front:
Camber: -1deg
Toe: 0deg
Droop: 2mm
Oil: 60wt
Spring: White
Piston: 3-hole
Upper link spacer: 6mm
Upper shock mounting hole: middle
Stabilizer: yellow
Tires: Sorex 28R
Rear:
Camber: -1deg
Toe: 3deg in
Droop: 3mm
Oil: 50wt
Spring: Blue
Piston: 3-hole
Upper link spacer: 2mm
Stabilizer: none
Tires: Sorex 24R
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 02-23-2004, 10:38 PM   #5659
Windtalkers's Avatar
Send a message via ICQ to Windtalkers
ever since i replaced the front one way to a ball diff, wholla... no
Windtalkers is offline   Reply With Quote
Old 02-23-2004, 10:39 PM   #5660
ever since i replaced the front one way to a ball diff, wholla... no more stripping bevel gear....
however, come to my dismay, the small bevel gear gave me problems... the gear has some how came to a spiral effect..... any1 has this problem???
perhaps, my stock motors had too much torque to bear with.....
Old 02-23-2004, 10:59 PM   #5661
jeffreylin's Avatar
R/C Tech Charter Subscriber
I've just replaced my drive shaft with the new tamiya light weight shaft. After I removed the old one I realized how worned out the notch in the front is. I think that was part of the reason why I start to wear out the bevel gear more and more often. You might wat to check yours too.
jeffreylin is offline   Reply With Quote
Old 02-23-2004, 11:13 PM   #5662
markp27's Avatar
Send a message via ICQ to markp27
Is there a way of adjusting the caster on the EVO III?
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 02-23-2004, 11:14 PM   #5663
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Originally posted by Tag
could anyone be more specific about this problem and is there anyway to fix it ? by the way, i also need some gearing suggestions, i will be running/racing mostly at socal raceway...any info will be appreciated.
You strip the Gears in the box's. Solution... Let off when you hit things. Speaking of not hitting things, Rod, any word yet on when the "High performance racing skills kit" will be in Stock?
Gearing, Monster Stock with 96 spur and a 34-36 pinion.(around 7 overall)
Bubblestc3 is offline   Reply With Quote
Old 02-23-2004, 11:16 PM   #5664
Tag
Tag's Avatar
Hi Jeffrey ! it's nice meeting you last saturday, thanks for the help with the TB III, i have finished rebuilding the car , can't wait for the next race ! I found the car has some torque steering issue which is understandable as being a shaft driven car..well, i guess i will see you this coming saturday , i will be looking forward to a tight battle
Old 02-23-2004, 11:19 PM   #5665
Tag
Tag's Avatar
one more quick question, for the rear toe block, i currently run a " B " what degree of toe in does it represents ? what do you guys usually run for a relatively tight track like socal ? thanks
Old 02-23-2004, 11:22 PM   #5666
Tag
Tag's Avatar
Hi Bubble , thanks for the help, well i guess i will start with 35, will make adjustment when it hit the track this saturday.
Old 02-23-2004, 11:42 PM   #5667
ngo8's Avatar
Send a message via ICQ to ngo8
when i got my evo 3 i didnt get a manual i was wondering what the A B C toe in blocks are i would apreciate the help
ngo8 is offline   Reply With Quote
Old 02-23-2004, 11:44 PM   #5668
jeffreylin's Avatar
Hi Tag, it was nice meeting you too. I currently run the C block which supposedly give you 3 degree of toe in but it's closer to 2.5 according to my set up station. B should give you 2.5 but I don't know what it actually is.
I have tried smaller toe in angle and it seems to give a little more top speed but you trade stability for it.
Old 02-23-2004, 11:47 PM   #5669
ngo8's Avatar
has anyone seen the trf-415 rear hubs those nice blue ones tat are stand up ? i was wondering if anyone has a part # for those cause i have seen pict of those on an evo 3 i would love to try them.
Old 02-24-2004, 01:35 AM   #5670
hemi426's Avatar
Originally posted by hawker
Hey guys,
Evo 111 Chassis
Johnno 540
Futaba HRS Receiver
Fukuyama 3300 Cells
THanx guyz
I would also like to see how much weight can be saved by using titanium turnbuckles and screws. My Evo now has a total weight of 1517g with the following components
Evo 3 Chassis
Tamiya 11T Super Modified
Quantum Competition ESC
Schulze Alpha 440 Receiver
JR DS8025 Servo
GP3300 Cells
Tamiya Modena Body
I removed the plastic battery mount and replaced it with two aluminium pieces. And I have the alloy upper arm mounts from the Surikarn. I hope to get closer to the 1500g barrier when I replace the one way with another ball diff.
Hemi
TRF 416, Cyclone S, TT-01E, Evo III SL, TamTech GT01, Slash, M18 Pro, M03-R
hemi426 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
