Tamiya TB-Evolution III
#542
The stainless are just as strong - more resistant to stripping then aluminum or titanium and alltogether as a kit weights 1oz or less more then titanium. Stainless is also more cost effiecient - you would be paying at least double for titanium
#545
Hey Jeff,
Bone stock with a Cyclone and Personal Transponder-car weighed 3.4. Not too bad. GT7 speed control, aluminum and Ti screws and maybe alum. driveshafts and I am sure I can get it underweight with Panasonics!!! GP3300's I think its gonna be a tad overweight.
I'll know a lot more about the car after Sat. practice day. IT is really, really smooth and easy to drive and nearly silent!!!
Ray
Ray
#546
Evo3 Race Results and Weight
My Evo3 weighs in at 1289g race ready but not including transponder. The lightweight hopups I used include ti screws, aluminum ball studs, universal shafts, and just about every light weight thing you can trow at the car. Servo is the Futaba 9550 and the esc is a Quantum Comp. As you can imagine, the electronics don't add too much extra weight.
As for racing: I raced it for the first time last night at Socal. I was thinking of entering prostock but since this was the first outting with the car, I entered sportsman. I ended up winning both of my qualifiers (lapped the field twice in the 2nd qual) to get a TQ that was a few seconds faster than the prostock TQ (good job rbf) In the mains, lapped the entire field in my main (sorry for the hack corey, I was getting egged on to lap you). And this was done with what I consider not my best driving The car is smooth and has a ton of acceleration and good top speed. And with any car of this caliber, it can be dialed to suit your track.
#548
rtypec is right his car was very fast. He pulled away from on the backstrait. just barley When I get the cash I will be racing with evo power.
#549
Evo3 Setup for Tight High Grip Indoor Ashpault
Since Joven probably already forgot the setup I was using hehe and Izzy was curious to what it was, here is what I did:
Track: SoCal Raceway, Huntington Beach, CA / Banked Oval into Infield Section
Temp: ~70F
Surface: High Bite Ashpault
Tires: Sorex 36R
Inserts: HPI Green
Wheels: Tamiya 0mm Offset Dish w/two holes drilled
Motor: Monster
Gear Ratio: 96/34
Batteries: Sanyo HV
Front
Camber: -1 degree
Kick-Up: Standard (0.7mm front 0mm rear)
Toe: -0.25 degree each side
Susp Blocks F/R: AA
Wheelbase Spacers: Standard
Ride Height: 5mm
DownTravel: 1mm
Springs: Yellow
Shock Oil: 50W
Shock Position Top/Bottom: Oustide/Standard
Stabilizer Bar: Yellow
Camber Link Positions: Standard
Rear
Camber: -1 degree
Antisquat: 0 degree (2mm spacers under both susp blocks)
Toe: 2.5 degrees
Susp Blocks F/R: AB
Ride Height 5mm
DownTravel: 5-6mm
Springs: Yellow
Shock Oil: 50W
Shock Position Top/Bottom: Outside/Standard
I'm sure I'm missing something but this should help.
Temp: ~70F
Tires: Sorex 36R
Inserts: HPI Green
Motor: Monster
Gear Ratio: 96/34
Batteries: Sanyo HV
Front
Camber: -1 degree
Susp Blocks F/R: AA
Ride Height: 5mm
DownTravel: 1mm
Springs: Yellow
Shock Oil: 50W
Rear
Camber: -1 degree
Toe: 2.5 degrees
Susp Blocks F/R: AB
Ride Height 5mm
DownTravel: 5-6mm
Springs: Yellow
Shock Oil: 50W
#550
rtypec did you find your 414 or the Evo3 faster?
#551
Well the 414M2 is setup to run at the Tamiya Track so it isn't fair to judge the two based on how they are currently set up. I believe that for a tighter track like SoCal, a shaft driven car would be ideal and that's why I'll use the Evo3 there. However, I'm sure I can get the M2 just as good but it's gonna keep its TA settings so I can prepare for some upcoming events.
#552
Isn't the stock setup on the 414 preaty close for most tracks? The resaon I ask is because I might be able to get one.
#553
Front one way gear
Hi,
Just would like to know is the front one-way gear for F201 suitable for TB evo 3?
Thanks!
Thanks!
#554
TeamAE: Yes the stock setup is pretty close for most tracks and it only takes a couple of things to get it dialed
#555
SET-UP?
RTYPEC,
In your set-up, what do you mean by down travel of 1mm for the front? Thanks.
