Old 01-28-2004, 08:40 PM   #5446
RCGaryK's Avatar
Thats what I had tried. Hmm, I guess I'll have to give it another shot.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 01-30-2004, 07:29 AM   #5447
Can someone tell me the setup on how to use tc3 gears thanks.
al jones is offline   Reply With Quote
Old 01-30-2004, 11:20 AM   #5448
TC3 gear conversion: http://members.cox.net/randy316/
Mr_Orange is offline   Reply With Quote
Old 01-31-2004, 04:37 AM   #5449
Send a message via ICQ to TRF Germany
Can somebody tell me which color the following new Tuning Parts for TB EVO III have:
53686 TB EVOLUTION 3 LIGHTWEIGHT PROPELLER SHAFT,
53687 TB EVOLUTION 3 ALUMINUM REAR UPRIGHT,
53688 TB EVOLUTION 3 SUSPENSION MOUNT(E),
Perhaps someone can post some pix!
Thx
TRF Germany is offline   Reply With Quote
Old 01-31-2004, 04:42 AM   #5450
Send a message via ICQ to Cobra81li200
they're not anodized.
Cobra81li200 is offline   Reply With Quote
Old 02-02-2004, 08:24 AM   #5451
hemi426's Avatar
Hi everyone, new to this forum and even new to the Evo 3.
I'm from Germany and I got mine from the US last month. When I used it during a run for the Tamiya Euro Cup I noticed the problem with the front gears stripping after a crash. I think I'll try the mod from BigDogRacing. Thanks for that.
But I noticed another thing. When I hold the car in the air and accelerate, one of the front one-way joint (MJ6) moves slightly out of the one-way (2-3 millimeters). Is this normal or should I do something against this e.g. putting an o-ring inside the joint? I have 4 washers MD3 on each side.
hemi
hemi426 is offline   Reply With Quote
Old 02-02-2004, 09:10 AM   #5452
V12
V12's Avatar
Hi Hemi
Welcome to the forum. I´m using an o-ring inside the outdrives with each of my oneway cars so with the EVO3 also.
Regarding the washers I can´t say currently how much I´m using but it´s one less than in the manual.
Regarding the onewaygears there is a problem when you are running the Tamiya Euro Cup as you are not allowed using any custom parts or modifying any Tamiya parts. This is one reason why I´m not running Tamiya Cup.
V12 is offline   Reply With Quote
Old 02-02-2004, 09:25 AM   #5453
hemi426's Avatar
Thanks V12, thanks for the answer. I will try an o-ring inside the joints.
I've another question. To use side by side cells in the Evo, you have to dremel out the lower chassis. This seems to be allowed.
And there is a carbon plate part from Tamiya to reinforce the front one way gear. I really doubt that the modification from BigDog will be seen as a forbidden tuning method but I will check that out.
Hemi
Old 02-02-2004, 09:30 AM   #5454
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by hemi426
Thanks V12,
Hemi
Hi Hemi, welcome!
There is a carbon plate which comes with the Surikarn edition, but it doesn't stop the gear from stripping. Having said that, mine survived quite a long time before I had to replace it - even with some reall big crashes.
But now I've change to a Jürgen one-way and an Alu one-way gear - both of which aren't allowed in the Tamiya Cup - one of the reasons why I don't drive there either!
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 02-02-2004, 09:41 AM   #5455
V12
V12's Avatar
be careful with the battery slots. You only have to remove a little so I wouldn´t use a dremel but a little file. Otherwise your batteries are sitting to low in the chassis.
Mark is right about these custom parts. Both are working extremly well. Maybe Tamiya will allow using the aluminium gear as they got a batch produced for them on special order. But I´m not sure about this but you could ask at the Tamiya support.
Old 02-02-2004, 10:15 AM   #5456
markp27's Avatar
Hi V12,
Are you using the Alu-Gear and the Jürgen one-way, too? Does using the Alu-Gear not cause the gear on the drive-shaft to wear out?
Cheers, Mark.
Old 02-02-2004, 10:20 AM   #5457
RCGaryK's Avatar
Hemi, stateside Big Dog's pinning trick is not allowed because it's seen as re-engineering the chassis so I don't think it would be allowed in the Eurocup either. Sorry
HorizonHobby.Com
Old 02-02-2004, 10:28 AM   #5458
V12
V12's Avatar
Hi Mark
I´m using the Jürgen oneway only. I sold my aluminium gears as I had no need for them as this oneway works so extremly good.
You can´t use the aluminium gear with the Jürgen oneway without modification.
From what I know the aluminiumgear doesn´t cause the pinion gear to wear out if centered correctly.
But as the aluminiumgear is so strong you may damage the piniongear now in a very hard crash. But the chance for this is way less than the original onewaygear problem.
Old 02-02-2004, 10:31 AM   #5459
markp27's Avatar
And with the Jürgen one-way, do you see any wear on the one-way gear at all?
Mark.
Old 02-02-2004, 10:33 AM   #5460
hemi426's Avatar
Talking
I see. It would cost tamiya a lot, since the sales of one way ring gears and pinion gears would drop dramatically
One more thing: I've seen a lot of people here using selfmade battery holders (or xray parts) to keep the batteries in their 414s in place (instead of tape). Would this be considered TCS or TEC legal?
I use two selfmade alumium posts with the original carbon battery plate and I wonder if this would be ok (I threw out all the plastic battery holders including the center piece.
Hemi
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
