Old 01-15-2004, 11:04 PM   #5371
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Yeah Rod, I was talking to JasonC about the gear striping thing, and the free spin last weekend or so, and he said it was mostly about how you set the mesh in the box's. 20 seconds?!?!?!?! sweet , kind of like these ? lol
I was thinking of running/racing my EVO at SoCal... Good idea, or Bad idea?(but first I need to get some more gears for it and I don't want to mess it up too bad... You know how SoCal is )
Bubblestc3 is offline   Reply With Quote
Old 01-15-2004, 11:36 PM   #5372
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by Bubblestc3
Just out of curiosity, how many seconds of free spin should one have on the EVOIII? I have about seven seconds of free spin with rubber tires, and was curious to wheather or not I should get to work on it, or it was ok. Rod, do you have more spin time?
I wouldn't worry too much about that. As long as it's free it's fine. The fact that a belt car like an XRay can win in a stock race goes to show that it probably does not affect the car that much. For me, at the level I am competing, the speed of the car is NEVER the problem--my driving on the other hand...
jeffreylin is offline   Reply With Quote
Old 01-16-2004, 09:54 AM   #5373
rtypec's Avatar
Hi Bubbles, it's a good car at socal but an almost entirely different setup. A car that's good at the TA track will seem pushy at Socal. If you do plan on running it at socal, try moving all of the shocks to the outermost hole, run 3 hole pistons with 50 weight all the way around, yellow springs f/r, yellow stab f/r, keep the inner camber links stock f/r (if you want more mid corner steering or more steering as you load up the tires during a turn drop the front inner camberlinks one hole), droop at 7mm f/r measured from setup board to lowest point on supsension arm (you'll notice there won't be much in the front) 4.5mm ride height with race tires (5mm with tamiya setup wheels) suspension block spacers stock, and a B block in the rear. I think that's it and adjust accordingly.
It's a good car to run but it depends on how much time you want to put into switching setups.
rtypec is offline   Reply With Quote
Old 01-16-2004, 11:42 AM   #5374
yeah also, the rotational mass on you car and drive train makes a big difference!! . your car could spin for 10+ but your resistance massive but it still spins due to rotational mas.. just a thought
Evo_Uk is offline   Reply With Quote
Old 01-16-2004, 12:00 PM   #5375
LeoChan's Avatar
Send a message via ICQ to LeoChan
Default Product D
Pic 1
LeoChan is offline   Reply With Quote
Old 01-16-2004, 01:31 PM   #5376
Registered User
Suradaj's Avatar
LeoChan....
Does that gear work pretty good? It doesn't strip the shaft gear? Where do you get something like that?
Suradaj is offline   Reply With Quote
Old 01-16-2004, 02:08 PM   #5377
hawker's Avatar
Default Re: Product D
Originally posted by LeoChan
Pic 1
yes tell alllllll!
hawker is offline   Reply With Quote
Old 01-16-2004, 05:04 PM   #5378
Thanks for the setup advice Rod.
Hmmm, I REALLY want to go to Tamiya ALL day tomorow, but i want to race at SoCal... Tamiya, or SoCal, Tamiya, or SoCal, Tamiya, or SoCal...
Old 01-16-2004, 05:22 PM   #5379
Hebiki's Avatar
Trader Rating: 26 (100%+)
Talking both dude!
bubbles, how about tamiya in the morning.. socal in the late afternoon, evening?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-17-2004, 01:35 AM   #5380
devil's Avatar
Default help:oneway
HI
dose anyone know how to pull the oneway apart or do you have to buy a new one?
thanks Peter
devil is offline   Reply With Quote
Old 01-17-2004, 05:55 AM   #5381
has anyone got a 48dp and 64dp gear ratio chart?
thanks
Tarnjit
Old 01-17-2004, 06:00 AM   #5382
T-man
Guest
Posts: n/a
I have a excelsheet for the TA04/TRF414. You can alter this if you like for the Evo III. The only thing you need to change is the diff reduction.
Interested? Mail me and i will send you this.
Marc
Old 01-17-2004, 08:50 AM   #5383
f1larry's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
thanks
Tarnjit
All you need to do is divide the pinion into the spur and multiply that number by 2.6 (Evo 3's internal ratio) to get your final drive ratio.
Example.
90 spur and 31 pinion:
90/31 x 2.6 = 2.9 x 2.6 = 7.54 FDR
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Tamiya TRF 415|TA05 v2|TA05|TL01RA|TL01|M05|M06|F104 Pro|F103RM|RM-01|RM Mk.5
Custom Racing Stickers
2012 TCS Race #170 "The Track" @ Harbor Hobby Best of Show Mini Pro
f1larry is offline   Reply With Quote
Old 01-17-2004, 09:43 AM   #5384
yeah i know that, its just i wanted to try something and to go it i got to read off alot of ratios
I remember seeing this chart somewhere and it was like
TB EVO 3 - gear ratio chart for 64 and 48dp
and it was like a massive list of ratios for both size gears.
i seen it on tftr forum but i cant get on that for sum wierd reason?
Old 01-17-2004, 10:13 AM   #5385
jeffreylin's Avatar
If you know how to calculate the FDR, just use Excel to put together the table.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
