Old 12-27-2003, 09:29 AM   #5266
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by BigDogRacing
Randy I've been running the car this way for three weeks on carpet with foam tires and a oneway and it hasn't hurt a tooth yet. I normally don't run a oneway on carpet but we've been running stock foams and I wanted to test it in extreme conditions. If it will last on foams with a oneway, then it won't have any problems with mod and a front diff!!
Sweet Jason, good work I hope that is the perminent fix for the Evo 3
Old 12-27-2003, 11:06 AM   #5267
Originally posted by wyd
What did Surikan do to his when he was running it to keep from stipping gears? I can't imagine he didn't run into this problem during his running of the car and then for Tamiya not to fix it would even be more crazy.
Glad you figured it out. You shouldn't have to do Tamiya's work for them.
i dontthink he does anything!
i raced mod on carpet with no tansmission mods and havent had any trouble with the one way gear.
i also dont use any of the chassis braces as it is better without them
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 12-28-2003, 12:10 AM   #5268
lem2's Avatar
Default Check This Out
http://www.interq.or.jp/horse/race/rc/PA260139.JPG
lem2 is offline   Reply With Quote
Old 12-28-2003, 01:32 AM   #5269
black-knight's Avatar
R/C Tech Charter Subscriber
Well the RacingFactory has been working hard on their Evo3's, See the links below for Atomix and Black Knight Evo3 pics
http://www.racingfactory.org/evo3/WEBDUELEVO3.jpg
http://www.racingfactory.org/evo3/WEBBLUEEVO3.jpg
http://www.racingfactory.org/evo3/WEBBLUE2EVO3.jpg
http://www.racingfactory.org/evo3/WEBREDEVO3.jpg
Some of options used to enhance the cars,
Tech Racing: Turnbuckles, Bodyposts(YTBF)
Square: Heatsinks and Motor mounts
Team Bomber: Carbon center shaft
Tamiya TRF: Blue option parts
Both cars have been shimmed to perfection by Atomix, super smooth and reliable transmissions have been produced.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 12-28-2003, 01:37 AM   #5270
jeffreylin's Avatar
Default Re: Check This Out
That's just great. The front oneway gears will last about 5 minutes off road. just enough for the main I guess.
jeffreylin is offline   Reply With Quote
Old 12-28-2003, 01:42 AM   #5271
Default Re: Re: Check This Out
Tamiya had a 4WD offroad ready for sale earlier this year, but they canceled the project, it was belt drive. The body was just like the one pictured.
Old 12-28-2003, 02:07 AM   #5272
I have been running mine in mod and only suffer an issue after a heavy crash. Simple fix...replace the damaged gears....
My car has now been shimmed, just like all shaft cars require...even the new HPI Pro4 requires shims to obtain the optimin mesh, not just to prevent damage, but the correct meshing of gears improves the efficiency. The above mention "FIX" is not needed in my opinion, shimming does the same thing and is simpler.
What does Surikarn do??? Shims and replaces damages gears as needed (and does not crash lol) ohhh and drives a belt car!
Old 12-28-2003, 03:07 AM   #5273
Back in june i think it was the Tamiya Japan team had red bevel gears for in the gearbox, they claimed they were the same as the other gears but they gave my mate one and he swore it was different, it slid onto the bearing instead of having to be pushed on. Rick
Rick Draper is offline   Reply With Quote
Old 12-28-2003, 03:27 AM   #5274
i wud rather tamiya make a off road version of the 415 then the evo3 as no stripping gears.
but the 415 has open gearboxes.
tamiya should make some competitive off roaders.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 12-28-2003, 05:47 PM   #5275
TJ
TJ's Avatar
I talked to Surikarn in Noveber at the TCS worlds he said the only thing that he does is to do what you have been saying shim the bevel gears and stop the drive shaft moving forward.
Has any body been running the tech three piece shaft in there evos and does it fix the poblem? i tried to shim the gears after I installed it and all it did was to bound it up.
Castle Hill Raceway: www.castlehillraceway.com
Facebook: https://www.facebook.com/groups/121817254587521/
"Anything I say can or will be used against me at a later date":
TJ is offline   Reply With Quote
Old 12-28-2003, 06:17 PM   #5276
izzyracer's Avatar
Trader Rating: 27 (100%+)
Anymore info on this evo 3 off roader?
Izzy
izzyracer is offline   Reply With Quote
Old 12-28-2003, 06:55 PM   #5277
Steevo's Avatar
Default EVOIII PICS
Hi Guys,
Just thought I'd post a few pics after my latest rebuild......
Steevo is offline   Reply With Quote
Old 12-28-2003, 06:56 PM   #5278
Steevo's Avatar
Second Pic...
Old 12-28-2003, 06:57 PM   #5279
Steevo's Avatar
Third Pic...................
Old 12-28-2003, 06:57 PM   #5280
Steevo's Avatar
Last One
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
