Old 12-26-2003, 07:29 AM   #5251
Originally posted by JasonC
bubbles: my evo has only sounded like a coffee grinder once, i will show you the "FIX" this weekend
Why dont you show US the "FIX" ???? I'm driving a coffee grinder right now and would like to know the fix too.
stumper is offline   Reply With Quote
Old 12-26-2003, 09:51 AM   #5252
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Stumper you must pin the front pinion to the driveshaft in the posistion that it normally sits in with a piece of .062" piano wire(hobby shop) using a .060" drill bit (also available from the hobby shop). Then you use a piece of battery tab material and correctly cut it to ALMOST wrap completely around the pinion bearing and insert it into the housing then insert the bearing to shim the front pinion bearing where there is no play left in it.
That may sound a little confusing but if you have the pictures and use a drill press then it's not very hard.
BigDogRacing is offline   Reply With Quote
Old 12-26-2003, 10:44 AM   #5253
Trader Rating: 49 (100%+)
Send a message via AIM to weaponx
Is it possible to post some pictures of the fix. Thanks in advance.
Rich
weaponx is offline   Reply With Quote
Old 12-26-2003, 02:13 PM   #5254
hawker's Avatar
Note to self. DON"T let your Dad drive your race car.
Lol, he drove it straight into a gutter, broke the ball screw on the knuckle, bent the suspension pin, I lost the one outdrive, BENT 2 brand new foam tires....the list goes on lol. I hit him with a bill though hehehhe
oh well, off to work to get spare parts.
hawker is offline   Reply With Quote
Old 12-26-2003, 05:07 PM   #5255
Steevo's Avatar
Hi BigDog.
One Question.......How can you fit the bearing into the original recess when it has a battery bar wrapped around it??? My bearing fits very snugly into the recess in the gear box so there is no way it will go.
steevo
Steevo is offline   Reply With Quote
Old 12-26-2003, 07:01 PM   #5256
JasonC's Avatar
Trader Rating: 120 (100%+)
steevo its a tab not a bar "
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 12-26-2003, 07:02 PM   #5257
JasonC's Avatar
installed
Old 12-26-2003, 07:03 PM   #5258
JasonC's Avatar
bearing installed
Old 12-26-2003, 07:05 PM   #5259
JasonC's Avatar
Old 12-26-2003, 08:58 PM   #5260
OK guys, I've had trouble making the actual webpage, so I uploaded the pictures and you can read a short version here. I suppose if you don't understand completely you can post your questions and I will try to explain better as well as update this post with the better explanation.
First of all, there were many attempts to fix the onweway gear stripping problem. Almost all failed. I had to send my car to a machinist to find out why.
I had previously installed the bearing shim but my car would still strip gears occassionally. After contemplating my plans to install TC3 gears, he simply asked why hasn't anyone just pinned the pinion gear to stop it from deflecting away from the ring gear? I replied-they have!! His answer was that I was 90% of the way to fixing it because I had already shimmed the bearing. The problem needed more than one repair. The shim didn't totally fix it and neither did pinning the pinion gear to the shaft, but together they make it as strong as any TC3 gears!! Actually, IMO, the Surikarn gear support or the Penguin R/C gear support should also be used because of the poor design of the gear mount on the oneway housing.
Now that we know how to fix it, here's the list of things you will need:
  • #53 .0590" drill bit
  • .0620" piano wire
  • dremel with good cut-off wheel
  • CA glue
  • dial or digital calipers
OK, now for the good stuff-
Step 1- remove your front diff or oneway leaving the pinion in place. Also remove the motor for easy access to the spur and spur adaptor.
Step 2- Using your dial or digital calipers and holding the driveshaft all the way forward with two fingers, measure the depth of the shaft in the pinion gear. Now push the driveshaft toward the rear of the car and take another measurement in the same fashion. Take your two measurements and average them together to get the center of the depth throw that the shaft uses.
Step 3- Now remove the motor mount screws and move the motor mount and spur gear forward enough to let the spur gear adaptor pin fall out of the driveshaft. This will allow you to remove the driveshaft completely from the car. Using your calipers to correctly set the pinion over the shaft in the same place it normally rides in the car (the measurement you came up with), CA the pinion into place with a very small amount of glue. If you have the time to wait for it to dry, use Shoe Goo. It is easily removed.
Step 4- Now use the #53 drill and drill a hole through the center of the pinion and shaft in the middle of the flat area where the pinion bearing rides. I personally drilled mine parrallel to the keyed area on the shaft, but I think it might be better to drill the hole perpendicaular to the flat keyed area. The pinion bearing will retain the pin you will install now.
*I went back and removed the pinion and slightly elongated the holes I drilled in the pinion to allow the pinion even more freedom to find a happy place. I do suggest you at least break the CA glue seal so the pinion gear isn't in a bind. This is the reason I stressed a SMALL amount of glue. If you have the time I would suggest using Shoe Goo instead.
Step 5- Now cut the pin with your dremel and grind the ends so it doesn't stick out past the plastic of the pinion gear just like the picture. Slide the pinion bearing over the shaft/pinion assembly to make sure it doesn't drag on the newly installed pin.
*******You have now pinned your pinion to the shaft.********
Next you must shim the pinion bearing so it doesn't "float" in the transmission housing. This is easily done with a thin metal tab used to build commercial and industrial battery packs. These thin tabs are usually spot welded to the ends of the batteries as opposed to the way we solder them. The spot weld is much stronger and more permanent. These weld tabs can be purchased at Radio Shack but I'm not sure they are the same size as the ones I have. I'll try to get by RS and check ASAP.
First cut the tab to 3mm wide (the width of the pinion bearing) and then wrap it around the bearing.
Now cut the shim so it doesn't quite wrap fully around the bearing. I left about a 3-4mm gap.
Drop the shim into the bearings's seat and then carefully work the bearing into place making sure the shim stays around the edge of the bearing.
*I worked mine in from the gap side and after it went in once and the shim took shape, the bearing goes in fairly easy now.
Now you can reassemble the drivetrain. Slide your shaft/pinion gear assembly through the shimmed bearing and through the motor mount/spur and into the rear diff housing. Now drop the spur adaptor pin into place and slide the spur back along with the motor mount and bearing. Reinstall the motor mount screws and front diff. If you have previously shimmed the diff so that it is tight against the pinion you must reshim it so there is a small amount of lash. This will free your drivetrain immensely.
Old 12-26-2003, 09:11 PM   #5261
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Nice pics Jason, do you have any on-track time with the car and mod yet? Hopefully it will work well..
Old 12-26-2003, 09:20 PM   #5262
Randy I've been running the car this way for three weeks on carpet with foam tires and a oneway and it hasn't hurt a tooth yet. I normally don't run a oneway on carpet but we've been running stock foams and I wanted to test it in extreme conditions. If it will last on foams with a oneway, then it won't have any problems with mod and a front diff!!
Old 12-26-2003, 09:23 PM   #5263
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
What did Surikan do to his when he was running it to keep from stipping gears? I can't imagine he didn't run into this problem during his running of the car and then for Tamiya not to fix it would even be more crazy.
Glad you figured it out. You shouldn't have to do Tamiya's work for them.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 12-26-2003, 10:24 PM   #5264
JasonC's Avatar
hey guys i have been running bigDogs drive train mod for almost, a month now. i have been running it with a novak BL and a Reedy 9x1 ti. i have not had any problems what so ever with the gears, i did however bend the center shaft, after hitting the infamous dog leg at tamyia in sothern Ca.
Old 12-26-2003, 11:41 PM   #5265
Thanks BIGDOG, nice explanation, and pics, awesome job!
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
