Old 12-22-2003, 01:45 PM   #5236
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
izzy are you going to tamyia on saterday ??
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 12-22-2003, 01:56 PM   #5237
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
Originally posted by mabucci
E.J. good thoughts!!
I must have posted the same time you did. saw your comments after the fact!
I'm running rubber on carpet, any setup suggestions?
Hey mabucci,
I have a good high bite carpet setup for rubber tires. I'll have to dig it up. I think racenut posted it on this thread a while back.
Jason C,
It's the rear diff that is melting, this is on carpet with foams. I've never had a problem melting them on asphalt.
E.J. Evans is offline   Reply With Quote
Old 12-22-2003, 02:01 PM   #5238
JasonC's Avatar
i have never ran on carpet before with my evoIII hopefully in a few months we will have one but till then i runnin on asphault.
Old 12-22-2003, 02:20 PM   #5239
izzyracer's Avatar
Trader Rating: 27 (100%+)
Most likely not, I need to make-up for some family time. New Years weekend for sure.
Izzy
izzyracer is offline   Reply With Quote
Old 12-22-2003, 02:36 PM   #5240
Aurra Sing's Avatar
I found it:
Carpet rubber setup:
Front:
Tamiya white
60W oil / 3 hole piston
middle hole on shock tower
6MM under camber link
middle hole for camber link
yellow sway bar
A/A blocks
stock spacer under front A block
2MM droop
1 degree toe out
-1 camber
5MM ride height
SOREX 28R's / HPI red
Rear:
Tamiya blue
50W oil / 3 hole piston
3rd hole in on shock tower
2MM under camber link
no sway bar
A/D blocks
no spacers under front blocks
3MM droop
-1 camber
5MM ride height
SOREX 24R's / HPI red
EJ - the changes you told me to make increased my lap times .5 sec... thanks I mounted the shocks on the outer most holes and used a 2.5 spacer under the rear upper link.
Aurra Sing is offline   Reply With Quote
Old 12-22-2003, 04:26 PM   #5241
stonedgti's Avatar
Trader Rating: 15 (100%+)
Aurra and I race at the same track, but I have a slightly different setting. The settings that are different is the front spring rate, oil weight, toe, rear oil weight and camber.
I started with Aurra's setting, but have found that my setting gave me a more neutral feel, and let's me swing the rear of the car around quicker mid corner.
Front:
Tamiya Purple (Ultra Hard Spring)
70W oil / 3 hole piston
yellow sway bar
A/A blocks
2MM droop
0 degree toe out
-1 camber
5MM ride height
Rear:
Tamiya blue
no sway bar
A/D blocks
3MM droop
0 camber
5MM ride height
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 12-22-2003, 10:00 PM   #5242
P2
P2's Avatar
Originally posted by Aurra Sing
I found it:
Hey, that's my carpet setup I gave to EJ when I raced at STRC last October.......I did quite well with it. EJ gets all the credit for all my hard work
EJ - Thanks for the motors and Redline Tee
P-deuce
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 12-23-2003, 12:16 AM   #5243
stonedgti's Avatar
Thanks PAUL!
Old 12-23-2003, 12:43 AM   #5244
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Originally posted by rtypec
Hey bubbles, merry christmas. Yeah, the Tamiya Track will be open this weekend.
Thanks, it was either the EVOIII, or the "Hi Performance Racing Skill Set", and I chose the EVOIII...
Which one would you have chosen?
Bubblestc3 is offline   Reply With Quote
Old 12-23-2003, 04:11 AM   #5245
Barry White's Avatar
Pic of the lightweight shaft:
Barry White is offline   Reply With Quote
Old 12-23-2003, 07:24 PM   #5246
when will release lei???
tsuiyuen is offline   Reply With Quote
Old 12-24-2003, 10:33 PM   #5247
black-knight's Avatar
Jan 30th 2004.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 12-26-2003, 02:15 AM   #5248
UHHH, Jason, how many ring and bevel gears have you gone through already with the EVOIII?
I think that I striped out a set, and I just finished building the car. My car sounds like a Barracuda when I spin the wheels!!!
Why are these gears sooooooooo soft?
Is there a solution to this problem?(I know that Rod strips out the gears too)
Old 12-26-2003, 06:20 AM   #5249
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Bubbles- Jason has the fix. He hasn't stripped one gear since he used it on his cars that I know of. I still haven't taken the time to type out the instructions. Kinda silly but Tamiya USA doesn't even care that I found the fix. They went to the trouble to build another car, well use another manufactuter's car and call it their own because of the gear problem, and they don't even care that the repair only takes a few minutes and would hardly need any new items. I suppose if they were to market the repair it would require a new driveshaft, pinion gear and front transmission housing or way to shim the play out of the front pinion gear.
BigDogRacing is offline   Reply With Quote
Old 12-26-2003, 07:14 AM   #5250
JasonC's Avatar
bubbles: my evo has only sounded like a coffee grinder once, i will show you the "FIX" this weekend
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
