Old 01-21-2003, 12:14 AM   #511
Trader Rating: 17 (100%+)
Send a message via AIM to AQuionIV Send a message via Yahoo to AQuionIV
It's tucked and closed in by the suspension stuff, that it's a little hard to get to. I haven't had mines yet, but if I'm not mistaken, the Evo2 motor mounts (I had an Evo2) are the same. You need a really long allen wrench w/ the short side shaved down to be able to fit it and tighten the motor mount. The TC-3 motor mount is great, as the screws come from the top instead of the side, making it very easy to get to. But then again, it's a weak mount, and the motor moves out of place very easily. I luved my Evo2 so much more than my TC-3. I just hope the Evo3 doesn't dissapoint when I it reaches my doorstep=)
AQuionIV is offline   Reply With Quote
Old 01-21-2003, 12:17 AM   #512
black-knight's Avatar
R/C Tech Charter Subscriber
Originally posted by over gear
What's wrong with Evo3's motor mount?
nothing!
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 01-21-2003, 01:06 AM   #513
EVO 3 will not disappoint you. It erase all the unnecessary feature exist in EVO 2 and definitively a wonderful car!
mr4-tc sp is offline   Reply With Quote
Old 01-21-2003, 01:13 AM   #514
Wilfred's Avatar
Overgear: Kind of difficult or takes time to change your motor, which is fast with my m2 n O4R, especially when u change ur motor after every heat.
Wilfred is offline   Reply With Quote
Old 01-21-2003, 03:48 AM   #515
Wink Reposition of body mounts
I want to use a special body and want to move the rear mounting posts to mount from the chassis instead of the shock tower. Will this cause a problem??? It is bad to do???? or is this okay and won't effect the car???
capricess is offline   Reply With Quote
Old 01-21-2003, 07:05 AM   #516
rayhuang's Avatar
Default body mounting
capricess-yes it will affect the handling of the car-but-if its the only place you can mount body posts-then I thnk you dont have a choice. Also-if its a special body-then every thing is thrown out the window anyways. Go ahead and mount it the way you have to and see what happens.
Old 01-21-2003, 07:10 AM   #517
how is the efect different then from mounting form the shock tower???
Old 01-21-2003, 07:22 AM   #518
rayhuang's Avatar
capricess-this is the best explanation I can come-up with-I hope it makes sense!!! Put your car on four scales. Place a welght on the rear shock tower and see what all four scales read. Now place that same weight somewhere else on the chassis-say further forward. Now read what all four scales read. They should all read different numbers now. Think of the body-and also the wind going over the body as weight (i.e. downforce). Thats why I say it will affect handling-but as I said-just changing body styles (Startus to Lexus or sedan to GTP car) or moving the same body forward or back a 1/2" can drastically affect handling!!!
Old 01-21-2003, 07:47 AM   #519
izzyracer's Avatar
Trader Rating: 27 (100%+)
Default Re: screws
Originally posted by racenut123
That is why your gear failed.The one way screws loosen aand that extra play when stressed causes the failure.The tolerances of the front box has to be perfect.....When you take a hit in the front and power is applied,then your gear strip or break teeth.Been through 3 already.Finally got it figured out and haven't had a failure since. I race on carpet with some pretty unforgiving track rails.
Will using a lock-nut adhesive to keep the srews from losening work?
izzyracer is offline   Reply With Quote
Old 01-21-2003, 07:57 AM   #520
rayhuang's Avatar
Default screws
Thats what I am going to do!! Put a dab of trusty old blue loctite. The screws were coming out on my one-way as well and I did in fact have bent and broken teeth!! I just didnt feel it notching because I had the motor in the car.BTW-Took the bearings out of car-cleaned them and oiled them-WOW!!!
Old 01-21-2003, 08:05 AM   #521
SpeedTech's Avatar
rayhuang,
I was reading your earlier posts about the car seems to be lacking a bit of "rip" off the line. Just curious, what rear toe-block are you running? The kit calls for the "C" block which gives you 3 degrees of rear toe total. I think that's a bit much. I'm going to change to the "A" block on mine, which I believe should give me 2 degress of toe. Let me know which block you were running so I can have a reference to
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 01-21-2003, 08:31 AM   #522
rayhuang's Avatar
Steve,
AA front and AA rear. Maybe going to 1.5 degrees of rear toe next practice day. Car is totally planted with 2-degrees rear toe in. I can definately benefit from less.
My GT7 showed up so I am putting that in-that should take care of the rip problem.
Ray
Old 01-21-2003, 09:01 AM   #523
Trader Rating: 28 (100%+)
Default blocks
I am running in the rear c /front and a /rear.Really frees up the car.I thought it was really good.I am running on carpet,so in other applications it may not work.Give it a try,especially if your racing stock.I think it gives me about 1 degree toe.
racenut123 is offline   Reply With Quote
Old 01-21-2003, 10:27 AM   #524
rayhuang's Avatar
Default Spur gear-Easy!!!
Hey guys,
I had to change my spur Sunday and thought-oh no!! But it was so fast and easy!!! Just remove the 6-screws on the top plate on rear tranny and motor mount and loosen almost all the way all the screws on center brace. dont loosen screws on front tranny case. Dont remove the center brace. Remove rear diff from car. PUll driveshaft back a touch and push out pin that holds the spur gear in place. Pull the driveshaft out. Lift center brace up a touch and remove spur gear assy. Replace spur gear and reverse process. Its like a 2 minute change!!! As fast and easy as the TC3!!! I guess the Kai conversion is NOT necessary to do fast spur changes.
Ray
racenut123-yes-I think CA would be 1 degree of rear toe. BA might be 1.5.
Old 01-21-2003, 10:30 AM   #525
rc-zombies's Avatar
Default EVO-III FIRST VICTORY
Race report at:
http://www.mytsn.com/publ/publ.asp?pid=7073
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
