Old 12-16-2003, 10:05 PM   #5176
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Dont know if you have a special battery strap that uses the body posts, but Tobee Craft makes some battery spacers that would go where your body posts are and they are designed to keep the battery in place. Speedtechrc.com has em in their MR4TCSD Tobee Craft section.
Old 12-16-2003, 10:31 PM   #5177
rtypec's Avatar
I would highly suggest that you file/sand/glue the sharp edges of the battery slots. A long while ago when racers first got their Evo's, many packs would short out on the chassis causing some sizzle and battery fizzle. I know it's a pain but it's worth protecting your investment. Atleast glue the edges with a liberal amount of CA
rtypec is offline   Reply With Quote
Old 12-16-2003, 10:35 PM   #5178
rtypec's Avatar
Originally posted by Evo_Uk
how does having a spool in the front compare to haveing a normal diff like the one in the rear?
i got one in the fornt i made but no matter what i do or how tight it is it will always slip i think it might be becasue of the round F201 diff rings im using in it.
anyone else got this problem?
thanks
Tarnjit
That sounds like you answered your own question hehe...get the diff plates with the "D" cut.
The spools gives you a little push entering the corner and the steering of a one-way on exit and on power. A diff may start "diffing" if you get on power mid corner to hard. A spool is a lot easier to drive and is kind of fun to have because you can glue yourself onto people's bumpers and freak em out hehe.
Old 12-16-2003, 10:35 PM   #5179
hawker's Avatar
yeah on one of my evo's i've had it done all ready, but on the other one (the one in the photo) i've just put a heap of CA on it
hawker is offline   Reply With Quote
Old 12-17-2003, 03:59 AM   #5180
VenomWorldOrder's Avatar
can somebody give me a good foam tire setup for the evo3 surikarn? it is for a fast flowing track with 2 quick "esses" in it. so it needs to be a setup that hasstable trasition of weight with the back end not kicking out.
thanks
VenomWorldOrder is offline   Reply With Quote
Old 12-17-2003, 12:26 PM   #5181
Default Re: My Cleveland Setup
VenomWorldOrder: try this.....
Originally posted by mcrisp
Back from Cleveland and someone was asking for my EVO III setup that put me in the A stock final. I have to say this car was perfect in my last qualifier, but my brain fade got between me and TQ with about 40 seconds left on the run - D'oh! .
In the main I gave my motor to troy from Fantom to tune and it was dog slow in the main. It was like I was running the Tamiya silver can 540 motor and everyone else was running the Trinity monster stock. I was able to do 11.7 and 11.8 second laps in the last qualifier and only managed 12.2 12.3 in the main, with the same setup and battery I used in the last qualifier. When I got the motor from Troy it was pulling only 4.5 amps at 2 volts. When I gave it to him it was pulling 11 amps at 2 volts. Oh well thanks to troy for his help, but I think I will stick to tuning my own motors from now on.
Here is the setup from what I can remember.
Front:
swaybar : Blue
Shock oil : 80 weight
Tires : Speedmind 35/52 shore multi compound
Springs : Assoc Copper
Camber : -1
Kickup/Anti-dive : None
Ackerman : agressive - connected linkage to hole on steering knuckle closest to the front of the car.
Ride Height : 5mm
UpTravel : 1mm
Shock Position : Outer holes on tower and A arm.
Wheelbase : The A arms are as far back as possible.
Diff : Normal diff slightly - a little more gritty and tight than the rear - I did not use antiwear grease as I have found the diff tends to slip more.
Toe out : 0
RollCenter : (low) I had the hing pin blocks on the chassis with no spacers. I had the upper links in the upper hole closest to the center of the chassis on the shock tower on the stock car (EVO III) and a 2mm spacer for the Mod Car (Surikan Edition)
Rear:
swaybar : Blue
Shock oil : 50weight
Tires : Speedmind 35 shore
Camber : -2
Anti-squat : none
Ride Height : 5mm
UpTravel : 1mm
Shock Position : Outer holes on A arm. Third hold in from outside on the shock tower
Wheelbase : one 2mm spacer from being all the way forward
diff : normal diff
Toe in : 1 degree (I ran the 2 degree uprights with the A block in the rear and the C block in the front)
RollCenter : (low) I had the hing pin blocks on the chassis with no spacers. I had the upper links in the upper hole closest to the center of the chassis on the shock tower on the stock car (EVO III) and a 2mm spacer for the Mod Car (Surikan Edition). I attached the upper link to the outside hole on the rear uprights.
Few! I hope I did not forget anything.
I used the same setup for both mod and stock and found it to provide a well balanced car. I also tried 1/2 degree of rear toe which helped the car not slow down mid corner but I changed back to 1 degree rear toe to smooth out the car in couple sections of the track.
Martin Crisp
ksrcracing is offline   Reply With Quote
Old 12-17-2003, 01:10 PM   #5182
fowlerJr68's Avatar
Can someone plz give me a good TCS setup for carpet?
thanx
Steve
fowlerJr68 is offline   Reply With Quote
Old 12-17-2003, 01:59 PM   #5183
what kind off tires you using on carpet
gizmo is offline   Reply With Quote
Old 12-17-2003, 02:38 PM   #5184
rtypec's Avatar
thanx
Steve
I'm not sure if this helps but here's a setup that DJ used at Trackside last year during the Novak race.
Old 12-17-2003, 08:49 PM   #5185
fowlerJr68's Avatar
Tamiya type a's because it's a TCS.
Steve
Old 12-18-2003, 05:57 AM   #5186
So..... ok
next question, where can i get D cut diff rings?!!?!?!
Also from what i hear Spools have got so much good news about them, is their any dissadvantage to useing them? can you still brake? is it worth getting one?
thanks alot
Tarnjit
Evo_Uk is offline   Reply With Quote
Old 12-18-2003, 08:56 AM   #5187
rtypec's Avatar
Check the back of your evo3 manual, it should have the part number. Also, the diff rings are the same from the F201 Lightweight diff joint set so you can use those as well.
Spool/Oneway...it depends on the track and how you want your car to feel.
Old 12-18-2003, 10:10 AM   #5188
cheers guys
Old 12-18-2003, 11:47 AM   #5189
P2
P2's Avatar
Trader Rating: 15 (100%+)
Default Steering knuckles?
Do you guys run the c1-c2 knuckles as the kit states or do you flip them over??
Thanks,
P2
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 12-18-2003, 12:53 PM   #5190
Default tires on carpet
fowlerjr68
did you run on that track yet ?? what did the car do?
if you using the A type try the use A harder insert in the front
en rais the rollcenter by at least 2 mm
clean your tires every run tires is 60% grip
let me no how it goes or went
greetz
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
