Old 01-20-2003, 03:27 PM   #496
rc-zombies's Avatar
What's the part no. for those one-way gear..so I can order alot of spares the same time I order the car. thanks,...
Old 01-20-2003, 03:32 PM   #497
I am using a special body for my evo III - can the rear body posts be mounted on the chassis (i will drill the holes) or will this affect performance or cause the body to roll.
capricess is offline   Reply With Quote
Old 01-20-2003, 03:43 PM   #498
Cool
What's the part# for those one-way gears?? I'm ordering my Evo III right now and I want to order some with it.
Trying Tamiya for the first time since 1993!! I'm tradeing in my Yokomo MR4-TC Special going into the Icelandic nationals... I'm going to win this year! Not satteling for 2nd place again..!
Yokio is offline   Reply With Quote
Old 01-20-2003, 04:08 PM   #499
Wilfred's Avatar
I'm a die hard Tamiya belt fan, have a ta03,04, and m2 but wen i saw the evo3, using m2 suspensions, got me wanting one, but when i saw that motor mount again, it changed my mind. Why dont Tamiya make the motor mount easier like the TC3, its evo3 already and still they didnt change that motor mounting, maybe on the evo4, hoping.....
Wilfred is offline   Reply With Quote
Old 01-20-2003, 04:13 PM   #500
rc-zombies's Avatar
Yes I agree..TC3 motor mount is the best I've seen.
Even on the upcoming HPI Pro4...motor mount is similar to the EVO-III.
anybody have those part # for the diff gears that keep on stripping...
Old 01-20-2003, 04:21 PM   #501
Trader Rating: 49 (100%+)
Send a message via AIM to weaponx
someone said the part number is 50979 i beleive on the page prior to this one, you might want to double check just in case
weaponx is offline   Reply With Quote
Old 01-20-2003, 04:30 PM   #502
Default 50979 TB EVOLUTION III ONE WAY GEAR
Yeb! Found it on the other page - thanks! I've placed my order!
Old 01-20-2003, 04:34 PM   #503
Default Re: 50979 TB EVOLUTION III ONE WAY GEAR
If anyone is planning to buy the Evo3, make sure you get a few of these, you will need them.
Does anyone know why David Jun runs his Evo 3 with a raised (2mm) rear roll center??? Thinking of trying this out but would like to know the idea behind it.
itchynads is offline   Reply With Quote
Old 01-20-2003, 05:40 PM   #504
Aluma's Avatar
hey, what motors/gearing/tire diameters you guys running?
can i just get the same gearing from my evo2 and still be as fast or faster?
Aluma is offline   Reply With Quote
Old 01-20-2003, 05:56 PM   #505
rough512's Avatar
Default Re: Re: 50979 TB EVOLUTION III ONE WAY GEAR
Raising roll centers lessens chassis rolls on corners. When you lessen roll, you lessen weight transfer from inner wheel to outer wheel (this is during cornering). Lesser normal force (weigh on a wheel) equals less traction. Overall, your chassis starts to slide around sooner.
Usually this is done to add steering. Raising the roll center is similar to installing roll bars...
rough512 is offline   Reply With Quote
Old 01-20-2003, 09:31 PM   #506
KINGZJ's Avatar
Send a message via AIM to KINGZJ
I have found with rasing my roll center on my TC3 that it helped the car rotate better mid corner. It seemed the same entering and exit just rolled better in the middle of the corner.
KINGZJ is offline   Reply With Quote
Old 01-20-2003, 09:55 PM   #507
rtypec's Avatar
Jun's car has 2mm raised roll center in the rear. I believe the front is stock. Also, he moved the upper shocks to the outside position and is running 40weight oil I believe.
Did some test runs today with the Evo3 and got the car to turn much better through the tight infield at Socal. Unfortunately, I roached the front gears and will have to do a rebuild before I take it out again. When i disassembled the front gear box, I noticed that the four screws holding the gear in place have backed out. Did anybody else experience this? Other than that, the car is almost dialed, it's the nut behind the wheel that needs help.
rtypec is offline   Reply With Quote
Old 01-20-2003, 10:23 PM   #508
Trader Rating: 28 (100%+)
Exclamation screws
That is why your gear failed.The one way screws loosen aand that extra play when stressed causes the failure.The tolerances of the front box has to be perfect.....When you take a hit in the front and power is applied,then your gear strip or break teeth.Been through 3 already.Finally got it figured out and haven't had a failure since. I race on carpet with some pretty unforgiving track rails.
racenut123 is offline   Reply With Quote
Old 01-20-2003, 10:29 PM   #509
racenut123 what do you need to do to avoid the gears stripping in the front end. i would like to avoid the problem if at all possible. i will be building the kit within the next couple of days and would like to nip that problem in the butt. thanks
Old 01-20-2003, 10:54 PM   #510
over gear's Avatar
Trader Rating: 15 (100%+)
What's wrong with Evo3's motor mount?
over gear is online now   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
