Old 11-22-2003, 10:12 AM   #4906
And one more.
ARC MotorSports is offline   Reply With Quote
Old 11-22-2003, 10:15 AM   #4907
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Default Re: bevel gear?!?!
Originally posted by jeffreylin
With all the talk about the front one-way I thought for sure it stripped after the front started slipping. This morning I opened up the gearbox and found out it's the shaft notch of the bevel gear that stripped! Any suggestions on a fix other than keep replacing them (only 2 spares came with the kit...) THanks, Jeff
Drill it and pin it. You must accurately mark the driveshaft to be sure the pinion is in the correct place.
BigDogRacing is offline   Reply With Quote
Old 11-22-2003, 10:20 AM   #4908
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by ARC MotorSports
And one more.
I've checked out those antenna mounts, but never tried one, have you ever run into interfierence problems?
Old 11-22-2003, 10:22 AM   #4909
jeffreylin's Avatar
Default Re: Re: bevel gear?!?!
Really? I don't know if I am capable of that kind of workmanship lol. Is there like a titanium or aluminum aftermarket bevel gear out there or is that a bad idea? thanks.
jeffreylin is offline   Reply With Quote
Old 11-22-2003, 10:30 AM   #4910
Default Re: Re: Re: bevel gear?!?!
Adding titanium or aluminum will just make that already weak 1 way gear shred twice as fast...
Old 11-22-2003, 10:43 AM   #4911
jeffreylin's Avatar
Default Re: Re: Re: Re: bevel gear?!?!
Yeah you are probably right there. I also thought about replacing the one-way ring gear to a metal one as well but I guess the stress will now be transfered to the rear? But since the rear has a ball diff that's probably okay? Just wondering...
Old 11-22-2003, 11:50 AM   #4912
Default Re: Re: Re: Re: Re: bevel gear?!?!
You'd propably wreck a lot more front imput gears by doing that. Get the Penguin gear backing plate, or do the TC3 gear mod. I never stripped a gear while running the TC3 gears...
Old 11-22-2003, 03:23 PM   #4913
guys
Carbon 1 piece prop shaft
or tech raceing 3 piece prop shaft
What would u recommend i get?
cheers
Evo_Uk is offline   Reply With Quote
Old 11-22-2003, 07:48 PM   #4914
Nope. I race with a Futaba 3PDF and extend the antenna on the radio about 2/3 of the way, the car is setup as pictured. I have no glitching problems. Nice and tidy too.
Old 11-22-2003, 09:27 PM   #4915
f1larry's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
what is needed to run the tc3 gears?
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|Associated B5M|TA05|TL01RA|TL01|F104 Pro|RM-01
f1larry is offline   Reply With Quote
Old 11-22-2003, 09:35 PM   #4916
Cool, I definately think it looks nicer with the body on without the antenna tube...
Old 11-22-2003, 09:35 PM   #4917
I did a write up on it, but used a cheap-o server, and I have no idea what the URL is anymore, did anyone happen to bookmark it?
Old 11-22-2003, 10:12 PM   #4918
JasonC's Avatar
Trader Rating: 120 (100%+)
here ya go
http://members.cox.net/randy316/
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 11-22-2003, 10:17 PM   #4919
Originally posted by JasonC
here ya go
lol, thanks Jason
Old 11-23-2003, 09:24 AM   #4920
anyone try the tc3 gear. how dose it work? is the drive train free? any info would be helpful thanks
mugenracer is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
