Old 11-21-2003, 06:44 AM   #4891
He suggested going 2mm higher in the rear only. It is a foam tire, carpet setup, so traction will not be an issue.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 11-21-2003, 07:31 AM   #4892
Trader Rating: 28 (100%+)
Default Re: Carpet set up?
Originally posted by Hebiki
do you guys have a good starting point for a carpet set up? ( i.e. tires, springs, tire type and compound?)
what tires hook up best? CS-22? CS-27? Sorex 36R?
ill be heading up to a carpet track to race. any help would be greatly appreciated.
OK EVO III guys, here is a good 19T carpet rubber setup.This is for Stockton Rc speedway and thats the track I am assuming your going to because it the only one in california right now.
Front:
Tamiya white
60W oil / 3 hole piston
middle hole on shock tower
6MM under camber link
middle hole for camber link
yellow sway bar
A/A blocks
stock spacer under front A block
2MM droop
1 degree toe out
-1 camber
5MM ride height
SOREX 28R's / HPI red
Rear
Tamiya blue
50W oil / 3 hole piston
3rd hole in on shock tower
2MM under camber link
no sway bar
A/D blocks
no spacers under front blocks
3MM droop
-1 camber
5MM ride height
SOREX 24R's / HPI red
The car is stable with the Stratus 2.0, and more agressive with the Alpha.
This is a good setup. The bite comes up fairly quickly as the day progresses so make sure you make appropriate changes if needed. By the way this setup was from E.j Evans/Paul Paras so the setup is money.
racenut123 is offline   Reply With Quote
Old 11-21-2003, 07:51 AM   #4893
V12
V12's Avatar
itīs similar to the German Nats setup that we use.
changes are
Front:
no spacer under front A block
no toe in or out
Rear:
60W oil
2nd hole in on shock tower
same tires and inserts front and rear
Stratus 2.0 only
sometimes additional changes:
3 or 4mm shims under front camber link
no shims under rear camber link
-1,5 camber
how do you measure droop? lowest part of arm to the setup board or uprights to setup board. Difference is about 1mm rear.
V12 is offline   Reply With Quote
Old 11-21-2003, 08:24 AM   #4894
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Gilroy Hobby World
im actually going to the carpet track in Gilroy. Hobby World to be exact. I ran my Evo III a long time ago in May. and forgot my set up.
i have a surikarn now..so things will be different.
Thanks for that set up. ill try it next friday.
how far is the stockton track from Fremont? or do you have a website.
racenut123 - thanks again for your help!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-21-2003, 08:50 AM   #4895
I live in Newark/ Fremont.The distance is almost the same for both tracks.If you want a laid back enviorment,gilroy is the place.If you want where the racing is Competitive and the program is topnotch and the carpet is really good,then Go to stockton.I forgot about Gilroy,my mistake. When are you coming up?
http://www.strchobbies.com/Welcome.cfm
Thats stocktons website.Personally I would go there.You can race friday night @ gilroy to help get your car dialed in then go to Stockton on saturday for real racing.Hope to see you there!
Old 11-21-2003, 11:41 AM   #4896
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Neither if I'm not mistaken... it looks as if he is measuring droop by measuring the actual uptral of the chassis. This is fast becoming the "norm" for droop measurements. Reason being that it is realtive to the ride height and tires size as opposed to the conventional "goofy" way of measuring where you must use math to figure out how much droop adjustment needs to be made withy every run of the car.
BigDogRacing is offline   Reply With Quote
Old 11-21-2003, 12:38 PM   #4897
anyone offer a good 12T setup for outdoors, the track has some long straights
www.bedworthrc.com fpr some pics.
for cold weather?
thanks alot
tarnjit
Evo_Uk is offline   Reply With Quote
Old 11-21-2003, 01:29 PM   #4898
Hebiki's Avatar
Default carpet racing
dang dude.. id love to race both places.. but i cant. thats thanksgiving weekend. gotta spend time with SOME family.
wanna try out my Surikarn on carpet.. thats why ill just go to Gilroy...since ill probably only race carpet when i go up there.
Stockton sounds like fun. maybe ill swing by there next time in the bay.
Hebiki Design Works
Old 11-21-2003, 01:31 PM   #4899
Stockton is carpet by the way.If you have a choice go to Stockton.If you can only go on friday then go to gilroy.Later!
Old 11-21-2003, 01:39 PM   #4900
rcfiend's Avatar
Trader Rating: 29 (100%+)
Hey does anyone know if the gears from the Yokomo SD and the TC3 are the same??? I can't find any replacement gears and I need some for tomorrow.
rcfiend is offline   Reply With Quote
Old 11-21-2003, 01:52 PM   #4901
jeffreylin's Avatar
Default Re: Re: Maybe a dumb question but...
Originally posted by markp27
This is a question I asked at first, too. Basically you have to balance the weight at the wheels and not on the chassis. The best thing to get is a tweak-station. http://www.schumacher.clara.net/tweakstation.htm
With this you can very simply and quickly adjust the balance of load on the tires by adjusting the pre-tension on the springs.
Cheers, Mark.
Thanks Mark. I see you are in Germany so I am not sure if you can help but I wonder where I can buy the tweak station--can't seem to find it in the internet...Thanks! Jeff
jeffreylin is offline   Reply With Quote
Old 11-21-2003, 02:00 PM   #4902
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Re: Re: Maybe a dumb question but...
Hi Jeff,
Not too sure where you'd get a MIP tweak station here in Germany - I got mine from www.rccarinternational.com. They're in Holland but their prices are good!
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 11-21-2003, 02:08 PM   #4903
markp27's Avatar
Oops! Hadn't read your posting carefully enough - you aren't in Germany
Here's a link page to dealers from the MIP website - hopefully you can find a dealer in your country.
http://www.miponline.com/links.html
Cheers, Mark.
Old 11-22-2003, 10:07 AM   #4904
jeffreylin's Avatar
Default bevel gear?!?!
With all the talk about the front one-way I thought for sure it stripped after the front started slipping. This morning I opened up the gearbox and found out it's the shaft notch of the bevel gear that stripped! Any suggestions on a fix other than keep replacing them (only 2 spares came with the kit...) THanks, Jeff
Old 11-22-2003, 10:11 AM   #4905
Here's my Evo III!
ARC MotorSports is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
