Old 11-04-2003, 09:08 PM   #4711
stulec52's Avatar
Trader Rating: 26 (100%+)
Send a message via ICQ to stulec52 Send a message via AIM to stulec52
Hey Stonedgti :
Now, the reason it strips is because the shaft spins and strips out the inside of the small bevel gear, causing it to be out of round and in turn strips the big bevel gear. I'm ok with that, because it really took a beating before stripping.
I had that problem....
easy fix. put the front pinion on the shaft and drill right through the 2 of them ( pinion and shaft.) pin it in there and you'll be set.
just make sure the pin is short enough not to foul the bearing.
oh, and then you have to load everything in from the front, but that's not so bad, it won't spin the front pinion gear off the shaft again !!!!
www.pmhobbycraft.ca/store/
www.tamiyaclub.com/
stulec52 is offline   Reply With Quote
Old 11-04-2003, 09:18 PM   #4712
Originally posted by Evo_Uk
"There will be an EVO IV as the sticker sheet with all EVO's to date goes upto V if i remember rightly."
What do you guys think? Sound awfully wierd but yet pretty believeable at the same time!
Now where have i seen that line before ??
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 11-04-2003, 11:31 PM   #4713
stonedgti's Avatar
Trader Rating: 15 (100%+)
Thanks stulec52...I'll try that.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 11-05-2003, 01:08 AM   #4714
hawker's Avatar
thanx a bunch Pirvan, gave me a good place to get started, I'll be running a Core Stock, and am restricted to 04. module gears at the moment, but at least I have a good place to start, thanx a bunch!
hawker is offline   Reply With Quote
Old 11-05-2003, 04:28 AM   #4715
Pirvan's Avatar
Hi Hawker, no worries man. But if i were you, i would switch to 48p gears as Heavy is always there with available pinions....but only in 48p.
Even the box stock setup of yellows all round (spring/sway) is a good place to start, might not be aggressive enough for you, but will not get you into trouble. Play with 60-80t oils to provide enough damping.
Jeff
Pirvan is offline   Reply With Quote
Old 11-05-2003, 07:43 AM   #4716
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Default Re: Re: RSJ Raceways (formerly Venture Raceways)
Originally posted by gcooper
Just to be a nosybody why did they sell?
Coop
Rick is retired and has been working there off and on and he wanted a bigger role in running the track. So he approached Venture and asked if they wanted a partner and at first they said no then they asked if he was serious and sold him the whole thing. I think Rick will do a great job, he is dedicated to making the track the best around and he will be working to get some ROAR events.
Larry
f1larry is offline   Reply With Quote
Old 11-05-2003, 08:11 AM   #4717
gcooper's Avatar
Default Re: Re: Re: RSJ Raceways (formerly Venture Raceways)
Larry
Who knows maybe he will be able to run a Tamiya race? From what I hear they are not too far from Trackside and it would not interfear with his current schedule. I don't know the size but he probably be mobbed with TCS racers if he did this.
Coop
gcooper is offline   Reply With Quote
Old 11-05-2003, 08:34 AM   #4718
f1larry's Avatar
Default Re: Re: Re: Re: RSJ Raceways (formerly Venture Raceways)
Coop
I talked to Rick about that. He is definitely open to the idea. I will be lobbying for one and I know there are other TCS racers that run here as well. I think he would have a great turnout and I don't think it will affect Trackside at all. It would give us a second TCS race in the Midwest and I know I would race at both and so would every one else. There could be one early on the schedule and one later on the schedule closer to the Nats. I know if people show up with their F1 cars he will run a class for them.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Tamiya TRF 415|TA05 v2|TA05|TL01RA|TL01|M05|M06|F104 Pro|F103RM|RM-01|RM Mk.5
Custom Racing Stickers
2012 TCS Race #170 "The Track" @ Harbor Hobby Best of Show Mini Pro
Old 11-05-2003, 09:11 AM   #4719
can anyone tell me a good setup for carpet with t27 tires.
12t motor limit.
thanx
trf man is offline   Reply With Quote
Old 11-05-2003, 09:40 AM   #4720
please i need a good set-up.
Old 11-05-2003, 09:57 AM   #4721
V12
V12's Avatar
I donīt think very much people will use the T27 tires. But there is a very good carpet setup for rubber tires developed by German Champion Marc Rheinard. Usually itīs my basic setup and I work from there depending on track and tires. You can find it here http://www.swebs.dk/
itīs the setup for CS27 tires
V12 is offline   Reply With Quote
Old 11-05-2003, 10:08 AM   #4722
its a control tyre.
i tried getting on ur site before but it wasnt working.
Old 11-05-2003, 10:15 AM   #4723
V12
V12's Avatar
I just tried and it was working for me. Hereīs the complete link http://www.swebs.dk/evo3-ger-nats-carpet.pdf
I know itīs a control tyre. We have used this one also two or three years ago. Unfortunately itīs not a slick tire and doesnīt have very much grip when compared with newer tires. But I think there will be no setup specially for the T27.
Old 11-05-2003, 10:21 AM   #4724
ok thanx.
that looks almost standard apart from some small minor things
Old 11-05-2003, 10:25 AM   #4725
V12
V12's Avatar
If this setup doesnīt work at all maybe you could try it here http://www.rcracechat.com/forum/
Itīs an UK based forum maybe you could ask there at the touring car or Tamiya section regarding a setup for the T27 tires. I know the T27 was used in the UK also as a control tire but Iīm not sure if they still use this tire.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
