Old 11-03-2003, 10:51 AM   #4681
well im not going to buy one! I have some left over C/F from making a chassis for another car and was going to make about 12 or so and maybe sell em. But if penguinr/c has em in stock then I dont think I'll bother.........
eidt: I looked on their site and cant find one?
stumper is offline   Reply With Quote
Old 11-03-2003, 11:12 AM   #4682
stonedgti's Avatar
Trader Rating: 15 (100%+)
You can get one from here: http://64.70.208.72/speedtechrc/85.html
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 11-03-2003, 11:40 AM   #4683
Trader Rating: 28 (100%+)
How did it work out for yu gearge?
racenut123 is offline   Reply With Quote
Old 11-03-2003, 11:48 AM   #4684
stonedgti's Avatar
The Penguin plate helped a lot, but I still managed to strip the gear. But I had to hit the walls a lot to do that. The way I hit it, it would've broken other parts on other cars. So I'm happy with the outcome. Really good $7 mod.
Old 11-03-2003, 11:58 AM   #4685
markp27's Avatar
Send a message via ICQ to markp27
In some of the German forums I've been reading, someone came up with a solution which involved placing a bearing in the part A8 (where the shaft drive goes through before entering the front gearbox).
The idea was that it stabalises the shaft. The proposed solution stated that you must put a little CA glue on the outside ring of the bearing to hold it into part A8.
Everyone who tried this fix had no problems afterwards.
Anyone tried this here?
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 11-03-2003, 12:11 PM   #4686
Ooj
Send a message via ICQ to Ooj Send a message via MSN to Ooj
does anyone have the part numbers for a complete set of rubber sealed bearings? I have an original evo 3 and its time to replace the bearings and I want the surikarn rubber sealed ones. I also need a part number for the 3mm bottom deck.
edit.....dont worry i found the numbers over at speedtechrc
Ooj is offline   Reply With Quote
Old 11-03-2003, 12:18 PM   #4687
Try this link for the chassis set. Good value with the Aussie dollar so high....
http://cgi.ebay.com/ws/eBayISAPI.dll...&category=2565
CustomfibreR/C is offline   Reply With Quote
Old 11-03-2003, 12:23 PM   #4688
Ooj
Are the surikarn shock towers exactly the same as the original shock towers minus the section for the upper links? The shock holes have not been changed to a different geometry/angle have they?
Old 11-03-2003, 12:23 PM   #4689
GTMilenko's Avatar
hey guys, i just put the 3mm chassis on my EVO and there is a step between the front bumper mount and the chassis, which isn't very good when it catches on something, is the surikarn bumper mount different? does anyone have a part no.?
thanks heaps
GTMilenko is offline   Reply With Quote
Old 11-03-2003, 12:25 PM   #4690
thanks heaps
no the bumper mount should be flush with the lower deck.
i have no part numbers as my manuel is at my nans. i think.
well i hope it is.
trf racer is offline   Reply With Quote
Old 11-03-2003, 12:47 PM   #4691
Not sure about the Angles etc. I think they are the same but have not had the original ones to compare..
Old 11-03-2003, 12:54 PM   #4692
Ooj
I need some more help with part numbers again. My caster block pins (the long pins that the wheelbase spacers and ball thingos go into) are bent.
I need some part numbers but I have so far seen 4 or 5 different part numbers for what I think are the equivalent pins for the ta04,414x and evo 2/3. I think some of these sets come with some other things i dont need??
Old 11-03-2003, 02:25 PM   #4693
GTMilenko--
The part number for the Surikarn kit front bumper is 0445987.
Ooj--
A friend of mine has the EVOIII and the Surikarn EVOIII. He compared the shock towers off each kit. You are correct in assuming that the only difference is the deletion of the camber link mounts on the Surikarn towers. Everything else matched up perfectly (according to him).
If I read your post correctly on the long hinge pins (the ones that connect the arms to the inner blocks where the wheelbase spacers go), just use the part number off the kit's instruction manual (50990).
I have both the Surikarn EVOIII and the 414M. I bent one on the Surikarn car and replaced it with extras that I had when I got my 414M. They are identical, yet the part number for that item listed in my 414M manual is 9805741.
I cannot comment on whether the hinge pins listed on the 04 are the same or not as I do not own that car.
However, if you look at the arms that are used for the 04, they are used in the 414 series and the EVO series as well (same part number too, 53427 as listed in both 414 and EVO manual). Thus, I would probably say that the 04 inner hinge pins would more than likely fit your EVOIII.
Hope this helps,
DT
Dennis Tom is offline   Reply With Quote
Old 11-03-2003, 02:35 PM   #4694
The TA04 inner hing pins are shorter than the 414/evo 3 ones. The outer ones are the same length. Rick
Rick Draper is offline   Reply With Quote
Old 11-03-2003, 02:48 PM   #4695
stonedgti's Avatar
There has been a lot of talk about Tamiya making bevel gears with stronger materials. Does anyone know if this is true and if so, when will they be releasing them?
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
