Old 10-29-2003, 06:56 PM   #4636
hierog's Avatar
just got my penguin backplate in today!! should i add any additional shims to the front oneway bulkhead? i only have the 2 silver shims as shown in the instructions. BTW, i have completely stripped 2 gears now, after 30 or so runs. so, i'm hoping this bigger backplate does the trick
hierog is offline   Reply With Quote
Old 10-29-2003, 07:13 PM   #4637
Default Re: Light weight products
Originally posted by McLaren
Hi guys
Please find following more details regarding the lightweight stuff:
- G STYLE TB20003 TEAM BOMBER EVO3 LIGHT WEIGHT CARBON CENTRE SHAFT
- SQUARE STB-50A TB EVOLUTION 3 TITANIUM WHEEL AXLE
In our track we use a 21 turn motor, which is pretty fast! Our lap times are only 1 sec less than those using modifieds. With the front differential I found the car handles better, is actually faster and after more than 40 runs, never changed a gear
Never used any shims either
With all these lightweight stuff, I had the possibility to add the titanium gear boxes (front & rear) and a cooling fan to the motor and am still under the 1.5 kg ... 1.499 to be exact (complete with electrics/wheels/body)!
McLaren
Thats a good tip...
Where I can get that Propeler Shaft???
colt99 is offline   Reply With Quote
Old 10-29-2003, 08:12 PM   #4638
hierog, every box and diff is different there is no magic number that works every time. If you have the 10mm shim set just keep changing out shims until you feel a slight bit of lash between the 2 gears. You might have to shim the crown gear also to get the proper setting.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 10-29-2003, 11:59 PM   #4639
markp27's Avatar
Send a message via ICQ to markp27
Default Balancing chassis
Hi Guys,
How do you guys go about balancing the chassis and what do you use to correct the weight differential?
I want to test my Surikarn at the weekend and want to make sure that I've got the chassis balanced.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 10-30-2003, 01:59 AM   #4640
Steevo's Avatar
Hi guys,
Just ordered a metal lathe today for my home work shop.
You know what I'll be working on making once it arrives .
I have a design for a new One-way which I can't wait to try out as well as a whole heap of other great Items....
Steevo
Steevo is offline   Reply With Quote
Old 10-30-2003, 04:28 AM   #4641
Default Re: Balancing chassis
Originally posted by markp27
Hi Guys,
Cheers, Mark.
Use the stick on wheel weights for your 1:1 car.
Downforce is offline   Reply With Quote
Old 10-30-2003, 06:06 AM   #4642
Default What picht is the correct
What do you think picht 48 or picht 64 for the Evolution III Surikarn is the best option???
Old 10-30-2003, 06:12 AM   #4643
64DP, quieter, more efficient.
you can also get a wider varitey of overall ratios without changing the actual size of the spur/pinion that much
..so I THINK you can also get more overall ratios with 64 aswell.
Evo_Uk is offline   Reply With Quote
Old 10-30-2003, 06:19 AM   #4644
Thanks a lot....
But why I will have more overall ratios with 64???
Old 10-30-2003, 06:32 AM   #4645
becasue the teeth are alot smaller, with the evo there is limited space so say haveing 40 teech with 48 on a spur then going up to 50teeth that would be a big increase in size and you proberly wont fit it.
with 64 if you did that the spur wouldnt increas in size much.
if i were you, Ditch the kit spurs, they are very poo. weak matierial , too thick and dont seem to mesh very nicely ( it does but it can mesh alot better.. ) and get some RW spurs in the same sizes 90 and 96, then buy loads of 64 RW pinions
Old 10-30-2003, 06:41 AM   #4646
Thanks a lot for your answerd Evo_UK
RW is the mark???
Old 10-30-2003, 06:45 AM   #4647
Evo_UK
You say teh RW Racing Spur??
Old 10-30-2003, 06:47 AM   #4648
yeah RW as in the make of spur and pinion
Their Spurs are very thin and great matierial meaning less resistance, better performance!
Their pinions are great aswell
Old 10-31-2003, 10:05 AM   #4649
So guys new is the TRF415 is in the making schedualed for january so we should be hearing about it very soon and its going to be tamiya's world car!
Guess what though, no info on the drive train so there is a chance it could be TRF's Shaft driven car! ( evo4 )
any news anyone?
Old 10-31-2003, 10:23 AM   #4650
rtypec's Avatar
I wouldn't exactly call that news. More like speculation at this point. We'll have to wait and see.
Did ya know that the Evo7 is coming out?
rtypec is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
