Tamiya TB-Evolution III
#4621
i love my car! no need to cheer me up
SD .. gear problems yey!
Tarnjit
Tarnjit
#4622
How many degrees or front/rear camber do you usually set on the TB EVO 3?
#4623
When i race outdoor i normally use 1.5 - 2 degree camber all around
#4624
Originally posted by Suradaj
When you guys put on the bevel gear, there are numbers on them. There are two molds that TAMIYA have for those bevel gears. The one with the number "2" is the better mold. More true and it also helps a bit with the striping problem. Try not to use the one with the number "1" on it. The mold on that is slightly off.
Interesting thing is the number 1 gears arenīt available as spareparts. At least I havenīt found any.
There are some number 1 gears not running true but not all of them. The one Iīm using since long a time doesnīt make that problem.
Another thing is the play some people have at the drive shaft. My number 1 gear donīt have any play, itīs a real tight fit. When I have to remove the drive shaft for changing the main gear itīs not that easy because of the tight fit. But the number 2 gear at the rear is a little lose. But thatīs not much of a play. Iīm using it since I built my EVO3.
#4625
I got a lot of nice gears and information from Jimmy J a while back. And that was the information that was relayed from the builders of TAMIYA, Japan about the bevel gears.
#4626
wow , i never noticed the 1 or 2 on the pinions!!
just looked at the 2 spare bevel gears i brought , out of the packet i got two number 1 pinions. looked thru all my spares and i have a few 2s and a few 1s.
so theoretically, runnind a 1way in the front. number 2 pinion in the back and 1 in the front,
how about running a diff in the front aswell? what pinions would you recomend
cheers
Tarnjit
cheers
Tarnjit
#4627
What is the difference between the two pinions? surely it can't be that much???
If the angle is different, does that have an affect on the way the front and rear gear boxes work? I'm taking my evo apart right now lol.
#4628
lol just did it!
from what i noticed when useing pinin 2 in the front it reduces the play to virtually nothing, with pinion 1 there is a tiny bit of play.
right, PLEASE PLEASE dont tell me this is the one way fix and tamiya new this all along!
#4629
cheers
Tarnjit
cheers
Tarnjit
#4630
one of a kind!
well i kind of had no option . the track i run at has a very tight sharp hairpin, yeah it is possible to do with the oneway and do good but its alot easier with a diff especially if you are racing as u can slam the brakes
just noticed i have loads of number ones and only 1 number 2!!! who wants to trade =-)
Tarnj
Tarnj
#4631
As the front and rear gearbox is the same this shouldnīt make a difference but I think the ringgear makes the difference.
#4632
OK OK OK ARR
im oficially the worlds most confused man.
just looking at all my pinions ive had , i got 6 pinions.
4 came with the kit and 2 i just brought.
i have 5 Pinion1s and 1 Pinion2
i had this thought in my head maybe you guys got it wrong and its actually the Pinion2 for the one way and Pinion 1 for the diff as i brought 2 spare packs of bevel gears and got 1s.....
then i thought!!! wait a seconD! i just put the new pinions on my drive train and the pinions out of the packet were a 1 and a 2!!
that means with the kit i was supplied with pinion 1s only and i got my pinion2 in a spare pack of bevel gears.
this is crazy?!!??!
i have a feelin its just a number becasue they got bored of the number 1 or something
this is crazy?!!??!
#4633
Evo_UK- they are the same mold just different material. And don't get too excited- they both fail. I believe one might last a little longer than the other, but neither will fix the problem.
I thought I would have the ultimate fix by now, but my guy hasn't called. Not even sure he's working on it. TO be honest, I'm getting a little tired of waiting.
#4634
Guys it is not the holy grail of fixes. Jun commented on it back in May. But also said it is a .00000000001 part of building the car. (Very Small) As far as different molds it is the EDM method of how Tamiya makes any of their parts molds. It is cool to watch but every mold is slightly different. Someone at the factory noticed there is a slightly different tolerance between the two molds. Shimming the box is still the best and most reliable method. Also as BD said it is still not foolproof and the gears will fail under extreme load.
As far as different material, #1 and #2 are the same material just for mfg. tracking, the molds are numbered same as any mass mfg will have so parts can be pulled if a mold is bad. There is no specified part to get in the kit or in a parts bag they just pull the parts needed when packaging. The F201 uses the same crown gear material and molds. If you are in search of the elusive #1-#2 in their natural habitat.
Cheers
Cheers
#4635
Cheers
Cheers
