Old 10-21-2003, 02:32 PM   #4486
Trader Rating: 28 (100%+)
Just counted the teeth on both gears.Its 2.6 not 2.66 so you may have to recalculate if you already havent.
racenut123 is online now   Reply With Quote
Old 10-21-2003, 02:43 PM   #4487
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
He may have been mistaken from when we were discussing using the TC3 gears because if you use the TC3 oneway gear you get 2.66.
BigDogRacing is offline   Reply With Quote
Old 10-21-2003, 04:22 PM   #4488
black-knight's Avatar
no your right 2.6 it is, ive always worked of 2.6 aswell, but someone (to remain namless lol) convinced me otherwise.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 10-21-2003, 07:02 PM   #4489
You guys scared me....
I thought after seeing BK's post I was undegearing for my track.
Old 10-22-2003, 12:08 AM   #4490
rtypec's Avatar
Does this sound correct?
2.598
rtypec is offline   Reply With Quote
Old 10-22-2003, 05:54 AM   #4491
Default Motor Screws
Anyone have any tips on how to get to those motor screws. It's seems really hard to get to the screws and tighten them. Also makes setting the gear mesh more difficult.
savio7 is offline   Reply With Quote
Old 10-22-2003, 07:15 AM   #4492
Default Re: Motor Screws
Get a good ball driver - makes working the motor screws easy as pie!
The Hudy 2540 Allen Wrench + Ball Repl. Tip 2.5 x 120 mm is a good choice.
ARC MotorSports is offline   Reply With Quote
Old 10-22-2003, 08:47 AM   #4493
Thanks but my problem is that the lower suspension arm and the upper links seem to get in the way and it's an awkard anble to get to the motor screws. Will the Hudy tool really resolve this?
Old 10-22-2003, 09:00 AM   #4494
i use the red TRF tool set ( ima show off ) but with that the motor screw driver you can skrew at an angle.
try popping out the suspension then do it or squeez the suspension, should help get to it easier
Tarnjit
Evo_Uk is offline   Reply With Quote
Old 10-22-2003, 09:42 AM   #4495
Rick ,
coudl you please write a review or post your thoughts on the tech raceing prop shaft please, is it worth the investment?
Old 10-22-2003, 09:48 AM   #4496
Default Motor mount screws.
Ball driver will let you get at it very easily.Taking off the suspension is a horrible waste of time.Compressing it to gain access is a very good idea.Just buy a ball driver.
Old 10-22-2003, 10:10 AM   #4497
Thanks will try it. It just seemed really hard to get to the mtr screws and was a real pain with the allen wrench. Is there any specific brand that I should get?
Old 10-22-2003, 11:33 AM   #4498
Originally posted by Evo_Uk
Rick ,
No idea what its like in use, i fitted it to my evo 3 looked at it to check the fit and pulled it off again as the whole lot is far to heavy. Rick
Rick Draper is offline   Reply With Quote
Old 10-22-2003, 11:42 AM   #4499
Default savio7
Hudy........Or a Thorp by MIP. Man its so nice to have one so its simple and easy to get at te screws at almost any angle.
Old 10-22-2003, 12:17 PM   #4500
gcooper's Avatar
Originally posted by Pirvan
Hi Guys, have a Tamiya Sponsored race coming up. But after messing ard with setup today, i noticed Sorex 36R(Hard insert) on the rear and Sorex 32R (medium insert) on the front provided the best combination. I was wondering if anyone has any advise on how to 'relate' this to Tamiya Type A or B2 tyres? Cos Tamiya is the only tyres we can use.
Jeff
Jeff,
The Tamiya As are around a 27 and I am not sure what the B2s are? Well any way As don't really like higher temps. Usually 24C is about it. They tend to get greasy in hotter temps. B2s are a thicker carcas and tend to like hotter temps. I would not mix tire types due to As, Bs and B2s come in at different temps. Play with tire inserts front and back to get the desired balance.
Coop
gcooper is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
