Old 01-17-2003, 05:05 PM   #436
beyond interested.......tell me more - I am drooling
capricess is offline   Reply With Quote
Old 01-17-2003, 06:45 PM   #437
Trader Rating: 24 (100%+)
Hey J,
I'll buy a kit from you and I don't even have my car yet!!! But that whole "nobody would know the difference" thing has to go. How about......... J-craft ?! I think guy's in the US would buy them as long as quality is up to par and you were honest to say they're" patterned after" someone else's "unavailable in the U.S." parts.
Evoracer is offline   Reply With Quote
Old 01-17-2003, 07:04 PM   #438
Trader Rating: 28 (100%+)
Default I want one too!
count me in!
racenut123 is offline   Reply With Quote
Old 01-17-2003, 07:19 PM   #439
Cat
I'll get the same design as Kai version kit in these few days, may be post some photos there when i rec'd them.
i'm sure that it will be easier for those tb 3 user to change spur gear.
Cat is offline   Reply With Quote
Old 01-17-2003, 07:23 PM   #440
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
me 2 ...
dun forget once u get accustomed with building cars try making up ur own design ...
then go big into the market ...
but of course make it at a lower cost so it will give other rc manufacturers some preasure to reduce theit price
imataquito is offline   Reply With Quote
Old 01-17-2003, 07:35 PM   #441
Trader Rating: 17 (100%+)
Send a message via AIM to AQuionIV Send a message via Yahoo to AQuionIV
Hey I would want to see that Kai Chassis version you are talking about. If you're saying 100 or less, then I will send you money right now.. heheh.. And I too don't have my Car yet=P.. But yea, please e-mail me if you plan on putting this chassis on production. Thank ZJ=)
AQuionIV is offline   Reply With Quote
Old 01-17-2003, 07:37 PM   #442
Default 414M2?
Can you make the chassis for the 414M2 too?? that would be great if you can. Thanks
Old 01-17-2003, 07:37 PM   #443
Cat
Default Kai version TB3
enjoy it
Old 01-17-2003, 07:46 PM   #444
Aluma's Avatar
hey guys, i did some calculations... stock core motor(26K rpms) with 61/24 pinion on an evo2 runs about 27mph. with the two speed thing, it would jump to 34.6mph...almost an 8mph increase! wow...60 bucks might now be too bad. Imagine an 10turn motors 35K rpms plus the twospeed...UUUUU
Oh, the guy thats selling on ebay is hi_iq
Aluma is offline   Reply With Quote
Old 01-18-2003, 12:04 AM   #445
Originally posted by black-knight
I had some runs with my Evo III, but my 414WCR is the better car, and it's the car i put all my efforts into for Modified racing.
Things that are not so good on the Evo III?... 1. too much chassis flex 2. Std cell reataining system not good for use with saddle or ladder packs.
I've also found some issues with the car after a few more runs, front one way diff gear tends to strip on impact, leaving high spots in the drive train.
Going to a full time 4wd setup might be easier on the gear since the ball diffs will have some play in them which can absorb most impacts. A bigger bumper to absorb the shock would also be useful Of course it would help not to crash into anything in the first place
Having said that, in terms of performance it has a slight edge over my 414m2 in terms of punching out of corners. Top speed is more or less equal. I'm only running a stock motor on a loose ashphalt track so chassis flex isn't a big issue. In my opinion, the car is good but not good enough to ditch a 414m2 for.
I'll be doing the opposite of BK and putting more time into the Evo3 instead of my 414m2 though. Not because the 414m2 is rubbish but because I prefer a punchier car.
But yeah the stripping of the gears is annoying. I've already placed an order for 10 more diff gears
itchynads is offline   Reply With Quote
Old 01-18-2003, 12:18 AM   #446
black-knight's Avatar
R/C Tech Charter Subscriber
yes, in stock the shaft drive would be an advantage. while drving my Evo i did notice it's punchy response!
10 gears WOW, i ordered a couple of packets with my car, not knowing that the kit included some spare.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 01-18-2003, 04:56 AM   #447
KINGZJ's Avatar
Send a message via AIM to KINGZJ
Basically I have a friend that is purchasing the kit (has one coming and I don't know from where or how) I was going to try and offset the price of the kit by having some made up to sell. I am not saying it is going to happen I just wanted to know how many people would be interested in it. Of course I would have pics of it and everything.
KINGZJ is offline   Reply With Quote
Old 01-18-2003, 05:11 AM   #448
Hehe I've already used up all my kit spares
Old 01-18-2003, 09:44 AM   #449
Default Stripped gears
The issue with the front oneway gear is that you can't overtighten the gear on the one way{will warp it slightly} unit nor leave it loose enough to allow the mounting screws to back out causeing play.Also check you gear box and make sure its snug.I know some will say it binds but this is not a tc3 and you need to snug up the halves together.Not overtighten just enoughto where your sure the halves wont sepperatefrom one another .Also check your sway bar mount and make sure its not overtightened.This will cause the gear box to also warp,so tighten until its snug and then back it out 1/4 turn.I also noticed that you need to use shorter screws for the sway bar mount as the ones that tamiya uses will cause the one way to bind because its actually hits the one way gear because its too long.I stripped a bunch of gears and spent a while trying to figure it out.The gearbox is plastic which is prone to easy warping so be really careful setting it up and you shouldn't have any more problems.One last thing and this is not a slight on anyone but LEARN To DRIVE!Quit hitting stuff. Any car is prone to breaking if its abused.....except maybe an xray!
Old 01-18-2003, 10:57 AM   #450
KINGZJ's Avatar
From time to time you are going to strip one out. all the tb's have this problem they have had it from the begining. Just have to keep spares
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
