Old 10-16-2003, 03:39 PM   #4426
Korey Harbke's Avatar
After mine broke in, it was super quiet. It takes a little time though. I put a little grease on the gears (not alot) and that helped too.
-Sushi Boy
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-16-2003, 06:59 PM   #4427
Just bought my evo III this week, I normally run a xxx-s g+ so I reaaly would appreaciate some input on a good sarting point for an indoor asphault track and we run foam tires on it like purple fronts and tan rears or tan fronts with majenta rears, I have the one -way in it now and the yellow sway bars so I just need a littel guidence on some decent set-ups for the car, I allready balanced the car on the scales with the lead so it just needs a good set-up.(good starting point) car feels good from where I have it but it is 3-4 tenths off my losi lap times from some unstability in the turns do to a squirmy feel from the soft set-up out of the box, suggestions are welcome.
Thanks Kash $
Kash is offline   Reply With Quote
Old 10-16-2003, 07:05 PM   #4428
gcooper's Avatar
Originally posted by Difuser
Coop between the pinion and bearing is correct yes.
For the ring you shim between the bearing and diff outdrive to center or move side to side ring=diff gear/ring gear.
It is a balance of which place needs to be shimmed in the box as before you get a feel for which shim needs to be placed where.
Difuser,
What side do you find you shim the most or is it a mix of both. Since you cannot look inside the gearbox with the gears what kind of feel should I be looking for.
Coop
gcooper is offline   Reply With Quote
Old 10-16-2003, 07:35 PM   #4429
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Thanks Kash $
I posted a good foam tire high bite asphalt setup a while back.
Basically it's blue springs, 50wt oil. Prolly needs the yellow swaybars
BigDogRacing is offline   Reply With Quote
Old 10-16-2003, 07:49 PM   #4430
blue springs all the way around or in the rear and whites up front, and does the oil retain stock oil pistons from kit or drilled out, if you got the mm on spacers inside your shocks that would be helpful (running 61mm-59mm foams for asphault) good spacer set up can give me a better overall droop to start with so I don't have to use those droop srcews.
thanks Kash $
Old 10-16-2003, 09:08 PM   #4431
Hold the shaft (no jokes here guys) and rotate the diff back and forth try to feel the "lash" and tighten up by shimming. The noise also increases quite a bit when even a hair tight.
The diff is most of it and you might find to remove the side to side play you need to put shims on both sides of the diff I think my front box has .1 on the battery side with .4 on the other and .2 on the pinion.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 10-16-2003, 10:20 PM   #4432
Wouldn't shimming the pinion allow for less of the shaft to mate with the pinion, possibly causing the pinion to strip inside?
jbackslash is offline   Reply With Quote
Old 10-17-2003, 02:12 AM   #4433
McLaren's Avatar
Are there any photos of the 3 piece drive shaft anywhere please?
McLaren is offline   Reply With Quote
Old 10-17-2003, 07:25 AM   #4434
rtypec's Avatar
Thumbs up Swervos
Hey Guys, FYI and incase you haven't seen it yet. You can buy two Futaba S9550 servos for your cars at Tower for $155. Incase you don't know what servo this is, it's the low profile one that most of us use. Good deal if you ask me as they sometimes cost up to $120 at your lhs. I just wanted to share this with you as I've ordered mine for the Japan trip (not planning on running servo savers hehe...well except for the $77.50 kind)
Tower Hobbies Futaba S9550 Servo
rtypec is offline   Reply With Quote
Old 10-17-2003, 08:36 AM   #4435
forty6's Avatar
rtypec, don't forget the $15 coupon on orders of $150 or more. Free shipping too if you are a member.
forty6 is offline   Reply With Quote
Old 10-17-2003, 11:27 AM   #4436
Hi McLaren
Take a look under the news section at Swebs RC
There's a photo.
Regards
SSL
SpineX-SSL is offline   Reply With Quote
Old 10-17-2003, 08:32 PM   #4437
stulec52's Avatar
Trader Rating: 26 (100%+)
Send a message via ICQ to stulec52 Send a message via AIM to stulec52
So,
how do you stop the front pinion gear spinning of the D shape on the shaft??
it has become so annoying on mine I drilled and pinned it, but that can't be the solution.
My fantastic car is being sadly let down by the drive train...
www.pmhobbycraft.ca/store/
www.tamiyaclub.com/
stulec52 is offline   Reply With Quote
Old 10-17-2003, 08:35 PM   #4438
Trader Rating: 28 (100%+)
the problem is most likely the drive shaft itself is rounded on its edge at the end.Even if it ever so slightly rounded,you need to replace it.This is the usual cause of stripped pinions.After you replace it,it would be wise to properly shim your tranny.I havent had a problem since.
racenut123 is offline   Reply With Quote
Old 10-17-2003, 08:38 PM   #4439
stulec52's Avatar
Thank you for that
not so much stripped though it's just that the pinion gear comes off the shaft at an angle and locks the front end up.
It only does it indoors on carpet with foams... I guess more traction? and more stress?
Also I am running the Kai chassis.. if the holes were out even just by a thou or 2 would this cause the problem?
www.tamiyaclub.com/
Old 10-18-2003, 02:19 AM   #4440
Hi
Where exactly do you shim yours? And how much?
SSL
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
