Old 10-15-2003, 04:40 PM   #4396
gcooper's Avatar
Originally posted by Difuser
Coop, on my side I very rarely go through the 1-way gears in the car. Where I noticed the gears stripping is on dot jumps and hard wall brushes where the axle catches the barrier. In other words on high load high traction hits. I also watched how I am driving to help the gear last longer(note not fool proof). I found that with the diff properly shimmed it almost always eliminates the stripping that does not mean shim the diff today and in 6 months it will be the same perfect lash. It means checking between race days and re-shimming as neccessary.
I have heard the rumor on the gears also but no official word on them yet. As far as the uber gearboxes special material gold plated blah blah blah. There are always special parts for the big guns look at Masami's gold SSG car at Reedy. The boxes in question are nothing special the material might be slightly different but not by much the special machine work you could do yourself with an hour and a dremel just not as pretty. The things looked like any other box, just a slight bit of relieving to free the bearings up. Nothing to help support the gears. As it was the special rear hubs Dave and Jimmy ran on the first days were off the car b the end of the weekend because they were just to hard on the outdrives
Dan,
Do you shim between the shaft bearing on the shaft gear and what size do you use? Is that where the shimming primarily goes moving the shaft gear into the 1-way gear?
Any pictures of the dremel at home work?
Usually I stay on the line don't hit anything. If I go off a dot I let off the throttle. The 1-way is probably the only part of the car I don't like.
Didnt you factory drive for Yokomo or am I getting you mixed up with someone else? Too many names, so little time.
Coop
gcooper is offline   Reply With Quote
Old 10-15-2003, 05:09 PM   #4397
Trader Rating: 28 (100%+)
Default Difuser.
I noticed you have team trf as your sig.Are you no longer driving for Yokomo,or are you back to driving a tamiya.I hope I am not being nosey.By the way,your right,the trf boxes are nothing special.How did you like the penguin rc backing plate?Much better?All I know is the Oneway Jurgen madefor me is awsome.No more worrys.Thanks! By the way,you rule at MINI!
racenut123 is offline   Reply With Quote
Old 10-15-2003, 06:05 PM   #4398
Steevo's Avatar
EVO buy it now and drive it the car is worth it just find your own way that you prefer around the very minute issues. How many national and world titles has the car won with this oh my god freak out problem.
Dan
I too have shimmed the one-way and find that I rarely go through pinion or bevel gears now days.
The Surikarn Limited is the best car I have ever had. From day one, even with the out of the box set up, it was awesome. The one way issue is a little annoying to say the least but once you get it right you will be so happy with the car..
Steevo
Steevo is offline   Reply With Quote
Old 10-15-2003, 07:16 PM   #4399
Jekyll's Avatar
I raced my Surikan for the first time and it is the best car I've owned. Dialed right from the box. However, I am having a hard time getting the kit gears to mesh properly (pinion & spur). It is much more ackward them my TA04. Any suggestions? Also, does anybody know what the largest 48 Pitch spur gear that will fit?
Jekyll is offline   Reply With Quote
Old 10-15-2003, 08:10 PM   #4400
Default Largest Spur Gear
72T / 48 pitch is the biggest so far we can put in without touching the upper deck
Anthony
Anthony Yuen is offline   Reply With Quote
Old 10-15-2003, 09:22 PM   #4401
McLaren's Avatar
Is there a lightweight (graphite) propeller shaft for the TB EVO 3 out there?
McLaren is offline   Reply With Quote
Old 10-15-2003, 09:29 PM   #4402
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Yea, i wanna know toooo. Coz like the stock alum., its heavy man.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 10-15-2003, 09:34 PM   #4403
McLaren's Avatar
I heard that there is a lightweight TB EVO 3 propeller shaft somewhere, but cannot find where or where I found in Japan is not in stock
Urgently looking for lightweight TB EVO 3 propeller shaft
Old 10-15-2003, 10:28 PM   #4404
racer's Avatar
does anyone know where i can get these in red?
any help would be appreciated.
Thanks!
racer is offline   Reply With Quote
Old 10-15-2003, 10:32 PM   #4405
racer's Avatar
found this on someones website. here is a picture of a carbon fibre driveshaft for the Evo III
Old 10-15-2003, 10:32 PM   #4406
Coop and Race Yes I am driving an EVO again and you have the name correct.
I shim both the pinion and the ring. It takes time to do it properly by taking things apart so much but it is the only way to get it correct. You also get a feel for hom much a box or gear needs by doing it. I shim the diffs also as the pinion wears you have to to keep the gears from skipping under braking. As for shim size I believe it is the 5mm shim set it comes in .1,.2,.3 sizes. Also with the assembly and reassembly be careful not to over tighten the 3 screws holding the case front on.
JFC I think Tech has one but I can't remember either.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 10-15-2003, 10:37 PM   #4407
McLaren's Avatar
So ... which website to visit / buy from the lightweight propeller shaft, please?
Old 10-15-2003, 10:48 PM   #4408
racer's Avatar
try rainbow10, they might have it not for sure though.
Old 10-15-2003, 10:58 PM   #4409
McLaren's Avatar
From rainbow10 it is out of stock anyone else?
Old 10-16-2003, 02:45 AM   #4410
McLaren's Avatar
If the carbon fibre is not available, can you please advise where to buy the Tech Racing 3-piece drive shaft?
Thanks a lot guys!
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
