Old 10-14-2003, 12:14 PM   #4381
Trader Rating: 28 (100%+)
Anyone seen the Prototype gearboxes tamiya gave to their factory drivers?I maybe getting a pair but wanted to know if they are any different in dimension.I know the material is different anits suppose to be machined.Any other differences?
racenut123 is offline   Reply With Quote
Old 10-14-2003, 12:22 PM   #4382
V12
V12's Avatar
From what I have heard so far only difference is they are graphite reinforced but not machined.
V12 is offline   Reply With Quote
Old 10-14-2003, 06:40 PM   #4383
i can't see any news of Prototype gearboxes...
where do you guys know about that??
i really want to improve TB3's performance..
i had just ordered Tech Racing center shaft jar~
tsuiyuen is offline   Reply With Quote
Old 10-14-2003, 07:12 PM   #4384
Cant buy them.Sorry.Only made for trf drivers.Just got lucky .Who knows.They may not help at all.But I may never know as I have not had a problem since buying the oneway from Jurgen
No more strippy my gears anymore.
Old 10-14-2003, 10:26 PM   #4385
oh...i see~~~
then any news about new pop up released?
Old 10-15-2003, 02:15 AM   #4386
black-knight's Avatar
R/C Tech Charter Subscriber
Originally posted by adz
As BK said, Yes i do drive an Xray... brilliant car!
BUT... I'm currently testing an Evo 3 and as it turns out it's a pritty
damn good car but i think i need to sort out the slightly binding and brittle drive train and i will probably end up using it instead
im amazed on the amount of corner speed it has in comparison
to the xray.
both cars are definatly not boring. maybe a corally... is... LOL...
good to hear i'm building my Sugarkane Evo3 this Saturday
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 10-15-2003, 10:09 AM   #4387
How can I order a Jurgen one-ways?
And anymore word on how well the penguin plate is working?
jbackslash is offline   Reply With Quote
Old 10-15-2003, 10:15 AM   #4388
The penguin plate works great from the running I have done with it
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 10-15-2003, 12:28 PM   #4389
gcooper's Avatar
I guess I am confused on the 1-way thing. Someone said on a previous post that the 1-way problem has been solved.
I really don't think it is solved if the part that fixes the problem is sported by a TRF driver, not mass produced and only available to TRF. I don't think it is solved if the part has to be picked up via a different manufacturer. What happens to the guys that race the Tamiya series with after market parts....
In my experience using the 1-way backing plate does not seem work, maybe it does but, you can still chew em.
I have seen some good pictures in the past on other fixes. What and how are some of the fixes that people have made that seem to work with these soft & bad 1-way gears.
details, details, details & pictures if you please......
Coop
gcooper is offline   Reply With Quote
Old 10-15-2003, 01:28 PM   #4390
You can see his products under the news section at SWEBS RC , there you can also send an email for more info.
Take a look
SSL
SpineX-SSL is offline   Reply With Quote
Old 10-15-2003, 02:11 PM   #4391
moshmike's Avatar
Just raced last night with my EVO 3se and the new penguin front one way plate and it worked great! I got stuck in a heat with a couple of new guys and it held up unlike at the TCS nats. Went through 4 out there> Well worth the 6.99!!!!
Evo's finished 1,2.
My most high tech car is a TA-03.
moshmike is offline   Reply With Quote
Old 10-15-2003, 02:21 PM   #4392
ok guys im stuck now!
im planing on giveing my drivetrain a nice update.
Firstly get a 3 piece propshaft as hopefully the pinions should have a nicer fit.
Then im not sure weather to get the penguin backing plate or the One way from GGermany as it looks sweet. I want a fix to last me good and proper and i can use it in nats next year.
Is it worth getting a Spool aswell?
Last question is it worth doing nothing and waiting for a new Evo? ( please say no )
any1 tryed the spool
Evo_Uk is offline   Reply With Quote
Old 10-15-2003, 02:55 PM   #4393
Coop, on my side I very rarely go through the 1-way gears in the car. Where I noticed the gears stripping is on dot jumps and hard wall brushes where the axle catches the barrier. In other words on high load high traction hits. I also watched how I am driving to help the gear last longer(note not fool proof). I found that with the diff properly shimmed it almost always eliminates the stripping that does not mean shim the diff today and in 6 months it will be the same perfect lash. It means checking between race days and re-shimming as neccessary.
I have heard the rumor on the gears also but no official word on them yet. As far as the uber gearboxes special material gold plated blah blah blah. There are always special parts for the big guns look at Masami's gold SSG car at Reedy. The boxes in question are nothing special the material might be slightly different but not by much the special machine work you could do yourself with an hour and a dremel just not as pretty. The things looked like any other box, just a slight bit of relieving to free the bearings up. Nothing to help support the gears. As it was the special rear hubs Dave and Jimmy ran on the first days were off the car b the end of the weekend because they were just to hard on the outdrives
EVO buy it now and drive it the car is worth it just find your own way that you prefer around the very minute issues. How many national and world titles has the car won with this oh my god freak out problem. I watched Surikarn blow up 3-5 of the TRF special spools at Reedy and one of the TRF engineers ended up taking some of our spools back with them.
Dan
Old 10-15-2003, 03:09 PM   #4394
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i thought id mention... i have hardly ever had any trouble with a diff in the front, till a lil while back. stripped both of the small gears in the box. a lot of that cam form the looseness of the bearings in the gearboxes. after about 5 months running every weekend, the bearings for the driveshaft have a lot (!) of slop as they sit in the boxes. like the holes are too big. that will allow for plenty of deflection causing the gap to be too large... any ideas?
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-15-2003, 03:41 PM   #4395
Replace the boxes if you are racing the car every weekend they just take too much abuse. I think the parts tree is about 12.00 You could also try Teflon tape around the bearing but to me it would be too much of a pain. My first EVO the I replaced the both boxes after 4 months racing 2 times a week.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
