Old 10-14-2003, 06:11 AM   #4366
black-knight's Avatar
R/C Tech Charter Subscriber
Originally posted by trf racer
so what car do u drive adz?
adz = xray....how boring... lol
better get this thread back onto TB Evo 3 talk.....
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 10-14-2003, 06:13 AM   #4367
Anyone run lubricant on the Evo3 diff gears? like "white lightning" dry lube?
Old 10-14-2003, 06:18 AM   #4368
lol.xray what a joke.
the transmission is crap compared to the evo3 and 414.
i dont run any lubricant in my evo3 but if i did id probably run oil instead of grease.
trf racer is offline   Reply With Quote
Old 10-14-2003, 06:21 AM   #4369
adz
adz's Avatar
As BK said, Yes i do drive an Xray... brilliant car!
BUT... I'm currently testing an Evo 3 and as it turns out it's a pritty
damn good car but i think i need to sort out the slightly binding and brittle drive train and i will probably end up using it instead
im amazed on the amount of corner speed it has in comparison
to the xray.
both cars are definatly not boring. maybe a corally... is... LOL...
adz is offline   Reply With Quote
Old 10-14-2003, 06:35 AM   #4370
McLaren's Avatar
Any idea where to get the following:
Lightweight (such as titanium) Wheel Axle for the universal shafts of the TB EVO 3
McLaren is offline   Reply With Quote
Old 10-14-2003, 06:37 AM   #4371
try www.rc-square.com
Old 10-14-2003, 07:19 AM   #4372
rtypec's Avatar
Thumbs up Ti Axles and other goodies
Tamiya has just released some Lightweight Titanium Axles:
Tamiya Tokyo Hobby Show-New Items Report
Look at all the new goodies!
Here's the part number for the axles:
Item 53681 Titanium Wheel Axle for Assembly Universal Shaft
This is on page 12 along with other new stuff.
rtypec is offline   Reply With Quote
Old 10-14-2003, 10:31 AM   #4373
markp27's Avatar
Send a message via ICQ to markp27
Another question for you guys:
When I take a hold of the wheels (front or rear), I can pull and push them out sideways about 1 or 2mm. It seem the dogbone adaptors are too long - it this normal (without the wheels it's the same - 1 or 2mm sideways movement, so it's not that the wheels are loose)
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 10-14-2003, 10:45 AM   #4374
rtypec's Avatar
You can use these to shim any slop in the wheel axles. Don't shim too much or you'll bind the axles.
Item 53586 4mm Shim Set 10pcs. x 3 types
Item 53587 5mm Shim Set 10pcs. x 3 types
I forgot which ones are for the axle. If anybody knows, please refresh my memory.
Old 10-14-2003, 10:46 AM   #4375
d
Evo_Uk is offline   Reply With Quote
Old 10-14-2003, 11:17 AM   #4376
V12
V12's Avatar
Cheers, Mark.
1 or 2mm seems a little bit much to me. Maybe it seems so but I canīt believe itīs really that much.
Iīm using just one of the thickest 5mm shims on each wheel axle. I think the thickest shim is 0.3mm and goes between outer bearing and the 2mm pin.
V12 is offline   Reply With Quote
Old 10-14-2003, 11:36 AM   #4377
markp27's Avatar
Just to make sure we're talking about the same thing here are some pics
The first with the axel pulled out.
Old 10-14-2003, 11:37 AM   #4378
markp27's Avatar
And the second with the axel pushed back in.
I think the gap is more like 0,5mm
Cheers, Mark.
Old 10-14-2003, 11:46 AM   #4379
V12
V12's Avatar
Yes itīs exactly the same. So a 0.2 or 0.3 thick shim should work also for you. #53587 for 5mm axles.
If youīre buying in Germany the link below to Friedel is about the cheapiest shop for Tamiya.
Old 10-14-2003, 12:00 PM   #4380
markp27's Avatar
Thanks for the info! I only live half an hour away from Friedel - frequent customer sozusagen
Man have I got a list of goodies to get from them
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
