Old 10-09-2003, 09:34 PM   #4306
InitialD's Avatar
Default Re: Look what was on my doorstep this morning!
Originally posted by markp27
Mark, nice !
Hope to one day be able to do the same and join this thread. Not likely at the moment.
Enjoy !
Old 10-09-2003, 10:36 PM   #4307
Originally posted by savio7
Downforce: Thanks.
Why did you switch from the one way?
What front diff did you use and does it fit without any modifications?
One way-
I race stock and it scrubbs speed in the corners. I just put a rear diff in the front.
Downforce is offline   Reply With Quote
Old 10-09-2003, 11:09 PM   #4308
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by JohnA
Just do the bottom deck, no need to do the top deck & shock towers. If you use a Q-Tip (cotton bud) dipped in superglue you can do it without getting the stuff all over your nice new chassis.
For the battery slots get a good small file, diamond if U can and just take off the sharp edges of the carbon so it doesn't cut into the cells. Another way of doing this is to wrap some emery paper round an old cell and 'roll it' in the slot.
Cheers matey!
Unfortunately got some glue on the chassis already I'll get some Q-Tips!
Good idea about the emery paper!! I'll do that.
Do you bother to do the battery cell cuts outs with super-glue?
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 10-09-2003, 11:13 PM   #4309
markp27's Avatar
Default Re: Re: Look what was on my doorstep this morning!
Originally posted by InitialD
Mark, nice !
Enjoy !
Indeed!!
Just give your wife a big hint for christmas
Cheers, Mark.
Old 10-09-2003, 11:56 PM   #4310
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Absolutely!!! That's one of the ways you insulate the chassis from the batteries, also the glue will smooth the carbon a little more where it doesn't rub a hole in the battery shrink wrap near so easily. If you really wanna get trick, file the slots and glue them along with the edges of the chassis, then take some 800 grit wet/dry sandpaper and wet sand the edges. Then glue them again using thin CA. A coupel times and it will look smooth and shiny- very pimp!! One last thing, you can seal every carbon fiber edge on the car if you want. I did the top plate and the shock towers so they would all look consistent. I also sanded and smoothed the edges of everything. IT fairly time consuming, but if you're sitting around at work not busy, it's great to pass the time.
To fix the spot where you spilled CA on the flat part of the chassis, just go to the hobby shop and get some CA debonder. It should be with the CA glue in a similar bottle. It works a little slow so just keep rewetting your towel with the debonder and rubbing it into the glue. EVentually it will come right off!!
BigDogRacing is offline   Reply With Quote
Old 10-10-2003, 12:39 AM   #4311
Default Carpet setups for the Evo3 SE
Hi guys
Some of you asked for some carpet setups for the evo3. Well take a look at SWEBS RC . There are currently 2 setups for carpet, and more to come.
Hope they'll help you out.
SSL
SpineX-SSL is offline   Reply With Quote
Old 10-10-2003, 01:11 AM   #4312
markp27's Avatar
Thanks for the tips! But I don't think my boss would be too happy if I didn't fix the customer problems because I want to sand the edges of my chassis
I forgot about CA debonder! I'll get some tonight
Old 10-10-2003, 09:37 AM   #4313
rtypec's Avatar
Originally posted by teamAE
Rod do you think you can send or post a setup for socal for the evo3? I just got one and wanted to see where to start.
Thanks,
Drew
Drew, here's the socal setup:
rtypec is offline   Reply With Quote
Old 10-10-2003, 11:06 AM   #4314
thanks I know I wil be flying sat
teamAE is offline   Reply With Quote
Old 10-10-2003, 11:49 AM   #4315
markp27's Avatar
Default Surikarn build.
I've now finished putting super-glue on the edges of the carbon decks and other parts - great idea with the Q-Tips!!!
Now the fun of building the car has started.
Cheers, Mark.
Old 10-10-2003, 01:13 PM   #4316
rtypec's Avatar
Please keep in mind that the ride height is measured with Tamiya Setup Wheels. Actual ride hieght with tires and wheels would be something like 4.5mm.
Old 10-10-2003, 01:29 PM   #4317
markp27's Avatar
Default Suspension arm question
I've got the front and rear suspension arms on the lower deck now, but notice that they don't move so freely! Is this ok, or should I be sanding down the ends (where the rod goes through) to make them move easier.
If I lift one of the arms an leave go, it remains where I put it. I thought the would fall back down under their own weight?
I've double check the instructions and the parts I've used and they are correct and in the right order.
Cheers, Mark.
Old 10-10-2003, 01:33 PM   #4318
rtypec's Avatar
You've got a binding suspension. Loosen the screws that hold in the suspension blocks and retighten accordingly. Ideally you want no front to back movement and still keep it free. It takes a couple tries but is easy to do. Also, this is something you want to check after a hard crash
Old 10-10-2003, 01:39 PM   #4319
JohnA's Avatar
Default Re: Surikarn build.
Cheers, Mark.
Glad you got the tip (excuse pun) before you tried to do it out of the bottle. I messed up my first chassis like that years ago!
JohnA is offline   Reply With Quote
Old 10-10-2003, 01:56 PM   #4320
markp27's Avatar
Thanks, I'll give that a go :-)
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
