Old 10-09-2003, 12:57 PM   #4291
Originally posted by fowlerJr68
Where can u get one of those? How much do they go for? what advanage does this hopup provide?
STeve
I have one of them, just taken it off my car as my mate is going to make me a lighter one as that version is far to heavy. Rick
Rick Draper is offline   Reply With Quote
Old 10-09-2003, 01:25 PM   #4292
fowlerJr68's Avatar
where can u get them?
Steve
fowlerJr68 is offline   Reply With Quote
Old 10-09-2003, 01:36 PM   #4293
JohnA's Avatar
Originally posted by markp27
Just a quick look through the instructions - do you really put super-glue around the edges of all the carbon fibre decks? And is the filing down of the edges of the battery holes in the lower carbon deck necessary, when I want to use individual batteries?
Thanks, Mark.
Just do the bottom deck, no need to do the top deck & shock towers. If you use a Q-Tip (cotton bud) dipped in superglue you can do it without getting the stuff all over your nice new chassis.
For the battery slots get a good small file, diamond if U can and just take off the sharp edges of the carbon so it doesn't cut into the cells. Another way of doing this is to wrap some emery paper round an old cell and 'roll it' in the slot.
JohnA is offline   Reply With Quote
Old 10-09-2003, 03:13 PM   #4294
Default Surikarn Carpet Setup
Hi all,
Just got done building my car with the stock setup, yellow springs and yellow sways. Car looks real nice.
Anyone have a good setup for carpet, large track?
What are the gear ratios for stock (Trinity Monstor Stock) with the standard 96T Spur?
What is the gear ratios for mod (9 single) with the standard 96T Spur?
Any other tips would be appreciated.
Thanks.
savio7 is offline   Reply With Quote
Old 10-09-2003, 04:01 PM   #4295
Default Re: Surikarn Carpet Setup
Originally posted by savio7
Hi all,
Thanks.
I started with the kit settings and changed to the following.
Front-
Ride height 4.5mm
Spring Yellow Associated
Oil 50wt
Droop 1mm
Tires TRC Plaid frts cut at 59mm
Yellow sway bar
Toe 0 degrees
Rear
Ride height 5mm
Spring Purple Associated
Oil 40wt
Droop 1.5mm
Tires TRC Purple frt/rear cut to 59mm
no sway bar yet
D and B blocks to give 1mm toe(if not 1.5mm I forgot what it was)
Monster stock motor. 96t spur and 34-36 tooth pinion depending on tire size.
You have to play with the spacers in the front to fit the foams. They rub on the upper ball cup. I used a set of wider HPI hub clamps and 1mm spacers. Works great and the car is a rocket. I have put a diff in the front instead of the one way. I ony have a few problems with the car that I don't like. Like the diff to pinion gear mesh. They're not as smooth as a TC3. And I don't like how the rear shock tower flexes when you move the body mounts. I'll just stay out of the wrecks then. Ya right!
Downforce is offline   Reply With Quote
Old 10-09-2003, 06:13 PM   #4296
Originally posted by rtypec
Guys...I got some news. People are running prototype gears but at this time, they are strictly that...prototypes and might not make it to production unless they find the end all be all solution. Also, more interesting stuff is coming along. The Evo is evolving. I don't have any more info other than that.
wo..going to have EVO 4???
tsuiyuen is offline   Reply With Quote
Old 10-09-2003, 06:46 PM   #4297
rtypec's Avatar
My apologize for making it sound like there's going to be an Evo4...well duh, there is, I mean they can go all the way up to Evo7-8 according to the sticker sheet hehe.
What I meant is that there may be some new stuff coming along for the existing car.
Ugg. I feel like I'm in limbo. I don't know what car I'm going to run next month nor do I have a carpet setup...urk not a nice feeling. Hopefully things will pan out and I'll be dialed by then
rtypec is offline   Reply With Quote
Old 10-09-2003, 06:48 PM   #4298
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Rod, you can't run the EVO3S? I guess I don't understand...
BigDogRacing is offline   Reply With Quote
Old 10-09-2003, 06:55 PM   #4299
rtypec's Avatar
Hi BDR, I meant for the Tamiya Worlds. I don't know the rules yet, and don't know which chassis to run, motor, tires, etc., etc... I like to prepare for large races as soon as possible. You know the whole "rush rush rush so you can wait" type thing
Old 10-09-2003, 07:10 PM   #4300
Korey Harbke's Avatar
Just to let you know, Peter Robinson, a past Gt-1 champ said they had to use tamiya connectors, and no traction compound. Thats a little scary. For the tamiya connectors put com drops on them to make them work better.
-Sushi boy
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-09-2003, 07:15 PM   #4301
Rod do you think you can send or post a setup for socal for the evo3? I just got one and wanted to see where to start.
Thanks,
Drew
teamAE is offline   Reply With Quote
Old 10-09-2003, 07:29 PM   #4302
rtypec's Avatar
Do you have the standard Evo3 or the Surikarn version? I haven't run the EvoS at socal yet so I can't be of any help there. I'll repost the setup I've been using when I go into the office tomorrow.
Old 10-09-2003, 07:30 PM   #4303
ya its the OG one Thanks
Oh what about geting the drivetrain freer? Does it just have to brake in or is there something else I can do, also I saw you guys talking about puting shims on the diffs but on mine there is not move ment side to side?
Old 10-09-2003, 07:51 PM   #4304
that's good..have new pop-up parts....
but when will the news come out?
I'm looking forward to improve my TB EVO III
Old 10-09-2003, 08:28 PM   #4305
Downforce: Thanks.
Why did you switch from the one way?
What front diff did you use and does it fit without any modifications?
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
