Old 10-02-2003, 08:26 AM   #4171
izzyracer's Avatar
Trader Rating: 27 (100%+)
Originally posted by rtypec
Hey Izzy, thanks for the congrats man. I look foward to going to Japan and seeing where it's at. I'll work on the setup sheet soon and post it here.
Take care!
p.s. I heard somebody shot a video of the last main. I wonder if somebody could post it. It'll be interesting to see how nervous I was...you can see the car dart around down the straight because of HRS+Nerves=Swerving hehe
Aaarrggh, not me!
Izzy
izzyracer is offline   Reply With Quote
Old 10-02-2003, 08:36 AM   #4172
V12
V12's Avatar
@ racenut123
so you finally got the oneway. Im glad its working for you as good as its working for me. As there is no track near my home I had about 40 runs only with this oneway since now but Im still using first ring gear and also first pinion gear with it.
V12 is offline   Reply With Quote
Old 10-02-2003, 08:46 AM   #4173
Registered User
Suradaj's Avatar
I saw racenut123's new oneway last night. The unit is sweet~! Looks like it will work really good.
Also talked to Jimmy J about the front bulkheads. He said that the TAMIYA Team builder taked about 20-hours to build each bulkhead for each driver. The team bulkheads are made out of the same material as the harden 414 arms, very nice. Now only if they where availible for us guys.
Suradaj is offline   Reply With Quote
Old 10-02-2003, 09:43 AM   #4174
Windtalkers's Avatar
Send a message via ICQ to Windtalkers
tamiya is really killing me wif their new stuffs....... cool and excellent.
has any1 got the red tools set yet???
Originally posted by Evo_Uk
WA LA
Windtalkers is offline   Reply With Quote
Old 10-02-2003, 09:46 AM   #4175
Default Re: Re: Re: Frustration
yah... i did shim up the one end of the one way... find it kinda loose... the 3 bearings securing the shaft.... seems like it's goin on a merry go round.. so found a very thin layer of double sided tape and round up the bearing.....
still experiencing problem esp after crashes..... will try another way out of this misery......
yah man..... i actually own 2 SL and heck, still love the car after much trouble......
cya
Originally posted by High-Speed
I was running 19T and experienced the same problem. I fixed the one-way gear problem[by shimming] then started having problems with the inside of the bevel pinion gear stripping out. I noticed that the drive shaft is too short, narrows at the tip, and has play, so the tip of it doesn't go into the front pinion all the way like it does in the rear which will cause it to strip. I shimmed the drive shaft to help keep the drive shaft tip as far up in the front bevel pinion as posible for more bite , but the shaft still needs to be a little longer. It still strips, but not as qwik as b4. Plus my driving got a little better...hehehe, but novice driver or good driver the car should still hold up IMO. After all its a Tamiya! I'm hoping the Tech-Racing shaft ends will fit into the front bevel pinion better than the Tamiya shaft and solve this problem.
I shouldn't have to spend 4300 yen on a gotdam shaft after paying $375-$400 for a race ready kit. Just my 2 cent
Still love the car tho
Old 10-02-2003, 09:52 AM   #4176
Default Re: link mounts
the ones that are sold now on the shelf are blue in colo..... not sure whether it comes wif the conversion kit or not..... but it's sure hella expensive investment....
Originally posted by tamiyadriver
i think the upper link mounts are part #53628... not sure of the color tho...
Old 10-02-2003, 10:11 AM   #4177
Randy Caster's Avatar
Trader Rating: 46 (100%+)
WA LA
wow, looks cool, but why would you want to ditch the RED
Old 10-02-2003, 10:12 AM   #4178
I think that's White Lightning or some other spray on lubricant or maybe grease. They look like that even though they're not stripped.
I may have to get a few of them there pengiun carbon plates. They look a lot lighter than the aluminum one that I'm running now hehe.
That one-way is trick. It's great to see one-way gear solutions being developed and being made available to the general public.
Hopefully it's the grease, otherwise that one way doesn't do the trick
Old 10-02-2003, 10:24 AM   #4179
Registered User
Suradaj's Avatar
My friend bought the red tool set, pretty much looks like the blue tool set. I have the blue tool set and the tips break easy(Mainly the 1.5mm). Also striped one of the set screws on the handle. Not very good. They look nice though~!
Old 10-02-2003, 10:25 AM   #4180
You're the first person I've heard of having a bad time with the tool set, I thought it was supposed to be the highest quality stuff out there... Can you buy replacement tips?
Old 10-02-2003, 10:32 AM   #4181
Trader Rating: 28 (100%+)
Some people are so skeptical.Especially when they don't own the car anymore.
I say again,No problems so far,EVO3 OWNERS.
racenut123 is offline   Reply With Quote
Old 10-02-2003, 11:00 AM   #4182
I'm only skeptical because of how that gear looked, if Rod is right about the grease, than it takes care of the question...
Old 10-02-2003, 11:10 AM   #4183
Iam thinking of getting the tool set.has antone got the price?
now were is evoracer? could you find out about this?if so i will make it your worth wile like before.
trf racer is offline   Reply With Quote
Old 10-02-2003, 11:16 AM   #4184
I believe the price of the red tool set was in the range of $150.
Old 10-02-2003, 11:21 AM   #4185
hey does big dog do all your bodies?
anyone no who makes the bad boy front lights?
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
