Old 09-26-2003, 11:24 AM   #4051
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by V12
I didnīt had time for trying the Square screws now. But I know from other guys the Square screws are harder than the Tamiya titanium screws so they wonīt strip that easy. No word if there is a difference in weight.
But I have to say if I had a Surikarn I wonīt replace the screws.
I was just wondering if they would be as good as the Surikarn screws, might make a cheaper spare screw set...
Old 09-26-2003, 01:15 PM   #4052
Sorry to keep asking but what shimms for the tc3 gear mod do you use to go around the actual outdrive, can anyone give me a part number as im pretty stuck
thanks
Evo_Uk is offline   Reply With Quote
Old 09-26-2003, 01:31 PM   #4053
Ok, I'm have kind of a problem. I think I've tried allmost everything to fixs the oneway gear stripping......But unfortunately, I haven't had any succes. So if some one could liste all the things that works.......... it would be a great help.
Anyone have any succes with the alu gear?
(V12: I'm still working on your idea....thanks)
Take care
SSL
SpineX-SSL is offline   Reply With Quote
Old 09-26-2003, 02:08 PM   #4054
thanks
I dont have part #'s for the shims, but just call Tamiya and ask them for the shims you need.
Old 09-26-2003, 02:39 PM   #4055
V12
V12's Avatar
53588 is the # for the 10mm shims
V12 is offline   Reply With Quote
Old 09-26-2003, 03:46 PM   #4056
There ya go I still havent figured out how to navigate Tamiya's site, I cant find anything more than spare parts for the wild willy 2
Old 09-27-2003, 06:38 AM   #4057
cheers you guys are the best
Old 09-27-2003, 09:41 AM   #4058
1shnot's Avatar
Default HELP!!!!!!!!1
HI GENTS......
In my club we started 2 classes for stock. one is reg class and the other one is "pro" class
diffence is reg class is 5min and pro is 8mins, and i'm having problem with run time.
first 6mins I'm very punchy but the rest.........
spur 100
pinion 32
matched 3300 1.189
please help!!!!!!!!
1shnot is offline   Reply With Quote
Old 09-27-2003, 10:37 AM   #4059
Try different compounds on your brushes, you will lose power once the batteries start to dump though, no getting around that without going to a lithium pack
Old 09-27-2003, 10:38 AM   #4060
Also, work on your drivetrain and make sure there's as little resistance as possible, less drag will help your runtime.
Old 09-27-2003, 10:46 AM   #4061
make sure your belt isnt overtitened.
randy you sold your evo3 yet?
what happens if you like the evo3 best.i dont think youll be able to get another one
trf racer is offline   Reply With Quote
Old 09-27-2003, 11:13 AM   #4062
Roger's Avatar
Default bulkhead or ring gear ?
Is it the drivetrain, bulkhead, or the front one-way ring gear that's causing the gear to strip due to impacts. I've seen numerous modifications on front one-ways fail. Have you ever thought that it's not the front one-way, but maybe the whole drive train system ?? True, its fast just like other shaft driven cars, but why is it just this car ? How come the TC3 or the yokomo SD don't have problems like the evo3 ?
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 09-27-2003, 11:27 AM   #4063
Sold my Evo 3 on Tuesday, if I do end up going back to the car, it wont be hard at all to get one...
Old 09-27-2003, 11:39 AM   #4064
1shnot's Avatar
Default HELP!!!!!!!!!!!!!!!
THANX RANDMAN.........
do you have any brushes you've had in mind? I've tried 4499 reedy 767 yesterday i've tried 4450(crosscut) .
i was thinking it was my gear ratio...........
please help.....
Old 09-27-2003, 12:39 PM   #4065
A hard compound brush would be the place to start (I honestly dont know all of the different brush #'s out there) but basically stay away from silver. You may also want to gear down a little bit and see if it helps. If you're overgeared, you'll kill your runtime.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
